Old 01-18-20, 06:30 PM
  #7926
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
Originally Posted by RobbieTunes
Frame is fine as all get out. 2 Options (OEM is not part of my schtick).
A: Sub-17 lb. Ironman. Which starts with the frame, can't change that. Kestrel EMS fork, Innicycle headset/steerer. Carbon crankset/Ceramic BB, DA7900 DT shifters, Modolo aero composite brake levers, Zipp 343 wheels, Tufo tubulars, Ciamillo calipers, Specialized FACT seatpost holding acarbon saddle, Chinese carbon stem and bars. DA9000 RD/FD. Would really be close if it didn't make it, cassette might be the tipping point.
B: Normal. Black Ultegra 6700, black FSA wheelset. Same carbon cockpit and perch, probably stick with OEM steel fork.
Probably 19 lbs.
Suggestions welcome.
Hammer bike or Easy Rider? Maybe set it up by how you intend to use it
seypat is offline
Old 01-18-20, 06:32 PM
  #7927
top506
Death fork? Naaaah!!
top506's Avatar
Bikes: Seriously downsizing.
Quoted: 559 Post(s)
Liked 629 Times in 280 Posts
Probably 19 lbs.
Go for the touchdown. I had issues with the 'OEM' parts from the moment I saw it. Save the bars, though. I never saw another pair like it.
Top
top506 is offline
Old 01-18-20, 06:48 PM
  #7928
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
Liked 178 Times in 105 Posts
A: Sub-17 lb. Ironman...cassette might be the tipping point.
Make it fixed gear and you save a lot of weight.
TriBiker19 is offline
Old 01-18-20, 09:04 PM
  #7929
Classtime
Classtime's Avatar
Quoted: 1949 Post(s)
Liked 2,010 Times in 1,109 Posts
Where is the picture of this '88 Expert. Dig the backward compatible DA 9000.
Classtime is offline
Old 01-18-20, 09:10 PM
  #7930
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
Check out the red and white in my group photo. Not a good picture, though. Family was too big and no one felt like smiling.
Old 01-20-20, 02:20 AM
  #7931
TXsailor
Bikes: Origin-8 Lactic Acid Giant Escape 2 Centurian Lemans 12 Kuwahara Tandem 1989 Ironman Expert 1988 Ironman Master
Quoted: 241 Post(s)
Liked 82 Times in 59 Posts
I'm going to look at a 56 cm Miami Vice tomorrow. Wish me luck.
TXsailor is offline
Old 01-21-20, 04:40 PM
  #7932
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
And.......? Did it follow you home?
Old 01-22-20, 02:41 AM
  #7933
TXsailor
Quoted: 241 Post(s)
It did! No pictures yet but it looks like all the rest of the MV bikes. It came with two other steel bikes, a Specalized Hard Rock Ultra and a Bianchi Main Street. They are in fair shape and after being freshened up will likely go to grandkids. The MV also came with something I don't like but I took it anyway. It has a lovely fluted seat post that is very stuck in place. I took it anyway because I'm a idiot. Other than that it needs the usual for a old neglected bike, some touch up, tires, cables etc. It has a couple of little rust spots on the top tube cable guides but other than that is rust free.
I didn't even get to talk to the seller except on the phone. He works nights and wouldn't be up until after I could get there. He said the bikes will be on the front porch just put the money under the mat. He also told me the seat posts were free and that the Centurion was aluminum. Of course he was wrong on both counts.
I probably won't do much with any of them for a few weeks as I plan to work 6 days a week until March 31 then retire. Then I plan to finish the Ironman I am building for my daughter and start some new projects.
I can't figure out why but it feels smaller than my Purple Haze. They are both 56 cm. Maybe because it has 20 mm tires on it?
TXsailor is offline
Likes For TXsailor:
Old 01-22-20, 08:18 AM
  #7934
madpogue
Quoted: 2363 Post(s)
Liked 1,749 Times in 1,191 Posts
Nice! I've made a couple CL scores that way, but small stuff, bike tires, winter boots, etc. Not three whole bikes.
Seems like that fluted Sugino "measure this" seat post was stock on a LOT of IMs. On the plus side, the flutes give you a place to squirt in some Fluid Film, PB Blaster, or whatever is your favorite bust-it-loose elixir of the day.
And pics of the Hard Rock are also mandatory, on the appopriate thread.
So is the stem the same as on your Haze? Crank arm length? It'd be interesting to put them side by side.
madpogue is offline
Old 01-22-20, 10:37 AM
  #7935
TXsailor
Quoted: 241 Post(s)
I'll get some when it quits raining and warms up.
Actually the stem is 20 mm longer. I am guessing the crank arms are 170 but haven't looked, the PH has 172s on it. I haven't rode it and won't till I get the post out so the littler feeling is just from loading and unloading it. The only other thing that is different is the tires so it must be those little short 20s My PH has 25s on it.
TXsailor is offline
Old 01-22-20, 05:03 PM
  #7936
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
TXsailor's Purple Haze is my inspiration for the rascalous gifted IM.
Hoping to achieve that same bad-ass look.
Settled on 6700, because, well, it's all here and all black.
(I'll use my DA down tube stuff and old-school 10sp tubulars to blaspheme a couple of Italian frames).
Only inbound items are the BB and an Innicycle adapter.
The "image" choice is made:
I'm going with a carbon seat post, and white saddle, as the frame is red in the rear.
I'm going with a carbon modern stem on the Innicycle, carbon bars, and red wrap, as the bike is white in the front.
Still pondering: white unicrown OEM fork or a Kestrel EMS fork, which I'll paint white to match the bike, or leave carbon under clear coat.
I can toss a Centurion fork crown decal on it if I have to, as I'd remove the EMS fork's decal. Being wider, there's room for the 88's squiggles.
Performance choices now are sort of between go-fast around here (flat) vs. climb in other places (not flat):
0. Braze-on FD with adapter, or 31.8 FD with shim? I have no idea.
1. 53/39 crankset vs. 50/34. It's not like I don't have other climbers.
2. Short cage RD vs. Long cage. It's not like I don't have other climbers.
3. 11-30 cassette vs. 11-28. It's not like I don't have other climbers.
4. FSA 400 clincher wheelset vs. Zipp 343 tubulars.
The FSA's (from Spaghetti Legs) are about 35mm deep, actually widen out from the brake track.
The Zipps have that bad-ass factor I so admire on TXsailor's 'Haze.
Bottle cage choices come after the bike is built. There's red, there's white, there's black.
My goal is to take a bike everyone said was snazzy or pretty, and make it look a little bit like "you are NOT meeting my sister, mister."
What sayest the Empire?
RobbieTunes is offline
Old 01-22-20, 05:37 PM
  #7937
seypat
So the frame is red/white? Go "out of the box" and put a Sante group on it. Find a wheelset to go with it and there you go. Something different.
seypat is offline
Old 01-22-20, 05:59 PM
  #7938
madpogue
I thought only IT geeks living in their parents' basements started lists with zero. Oh, wait....
0. The shimmed FD will look a little less... adapted. Otherwise, I'd just go with whatever works better with the crankset you choose.
1. 53/39 seems more "in keeping". OTOH, that's not really what you're going for.
2. Long-cage would look out of place, I think. Esp. if you choose the 11-28.
3. Def. 11-28 if it's not gonna be a go-to climber. Just a W@G, but the would the 11-30 require a long-cage?
Overall wrt. gearing, I'd go with one extreme or the other, that is, 53/39 + 11-28, or 50/34 + 11-30. It's either gonna be a flatlander or a climber, either combination in between would be just middle-of-the-road. Then pick the mechs based on the range.
Don't you get that reaction no matter what you ride? Or on foot, or whatever?
madpogue is offline
Old 01-22-20, 07:03 PM
  #7939
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
Originally Posted by seypat
So the frame is red/white?.
Yes.
Old 01-22-20, 07:17 PM
  #7940
Classtime
Classtime's Avatar
It is going to look great. But, is an 11/28 badass? Please discount my opinion since my deepest wheelset is CXP33/7700 but I think you need a 12/23. It is my favorite 10 speed cog set.
Old 01-22-20, 07:25 PM
  #7941
seypat
Yes.
Sweet! I still have the white Superbe chainrings on my red/white one.
seypat is offline
Old 01-22-20, 09:20 PM
  #7942
TriBiker19
Just call me Carrie
TriBiker19's Avatar
Quoted: 308 Post(s)
I want to touch up the white paint on my ‘89 Ironman Master “Blue Smoke”. What’s the best method to remove the surface rust? What paint color is my closest match?
Old 01-22-20, 09:26 PM
  #7943
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2155 Post(s)
Liked 3,404 Times in 1,205 Posts
What's the ONE group you (better still) own that's period correct and the baddest stuff a racer could buy at the time?
Yep, that's right. Dura Ace 7400, either 6 or 7 speed. Freehub style if you can find it.
Boom.
rccardr is offline
Old 01-23-20, 01:56 AM
  #7944
TXsailor
Quoted: 241 Post(s)
I'm blushing that the one & only Robbie Tunes is inspired by my Purple Haze. It has the look he likes by total accident. I liked the color and wanted a frame I could put more modern parts on so I bought that one on the bay sans wheels. It had a Exage MTB group set on it that I really didn't like. I was given the Dura-Ace crank so I found the rest of the drive train on the bay. I bought the brakes from Robbie. The wheels came off my carbon bike that I rarely ride. Here is a picture for reference
TXsailor is offline
Old 01-23-20, 10:06 AM
  #7945
RobbieTunes
Quoted: 378 Post(s)
Hotter'n'Hell 100...Ironman....
Chances are >50/50 that I'm going. I'd ride an Ironman, for sure.
Old 01-23-20, 10:12 AM
  #7946
TXsailor
Quoted: 241 Post(s)
Chances are 100/100 that the Iron Maiden & I will ride it unless its snowing
TXsailor is offline
Old 01-23-20, 10:23 AM
  #7947
madpogue
Yeah, nice enough on an entry-mid-level MTB, but on an IM?
Still have any bits of it?
madpogue is offline
Old 01-23-20, 12:09 PM
  #7948
seypat
HNH100? Really? I guess if it is a bucket list kind of thing you should go for it. I spent enough time sweating my a$$ off there back in the day. If you are thinking about it, you better get your accommodations settled now. If you still have military connections, you might find accommodations at Sheppard AFB or the Army base in Lawton, OK. That is some uninspiring landscape In the wasteland that is the TX/OK border area. Where TXsailor lives is nicer terrain. How many would be in your group? I have one brother that lives there. If I made the trip, we could stay there. If I didn't make it, you could probably still stay there. My father is having a pacemaker put in on Monday. Maybe I need to take a trip back. Maybe not. The HVAC company next to me in the business park just hired a former Air Force serviceman from Oregon. He spent 2 years at Sheppard AFB. He said it was the worse place he had ever lived. If you are going, you might as well start listening to some Red Dirt Country now to get yourself acclimated to the area culture.
Just to put it out there, how many TX Ironmen/ladies would be going to that event?
seypat is offline
Old 01-23-20, 12:15 PM
  #7949
RobbieTunes
Quoted: 378 Post(s)
Will there be 3 generations there, or is your daughter more sane? Wonder how we can
get more....
Old 01-23-20, 12:21 PM
  #7950
RobbieTunes
Quoted: 378 Post(s)
Just to put it out there, how many TX Ironman would be going to that event?
I'm afraid if I tell people I know you, I'll get sent to Oklahoma,
but will check on accommodations. My group will include at least 2 but likely 6. They do this every other year. I am "the new guy."
