Recommended Saddle
Recommended Saddle
I feel a little pain when I sit on a saddle on my bike. Is it because the saddle is too narrow? It has a little cushion. Which saddle would you recommend? There are so many on the market especially in my local biking store.
WALSTIB
What's your riding style, what's your bike and what's your budget? Then fun can begin. Hope you have years.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,646 Times
One of the best ways to approach this is to ask your LBS if they have take-off saddles for demo. Many do. This will allow you to try a lot of different styles without buying them first. Your anatomy will dictate the correct saddle width. Seat comfort is one of the most difficult things for cyclists to nail down, because what works for me may not work for you.
Likes For Paul Barnard:
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Plus I would also caution OP that the presence of padding, cushioning, etc., has no real bearing on whether a saddle will be comfortable. I learned the "soft way" that when you bottom out the padding (not hard on a cheaper saddle) it will begin to hurt. I initially has a saddle that was great for a 12 mile ride. By 16 miles, it was a bit uncomfortable, but at 20 it was awful. I switched to a Brooks Cambium (no padding) and it is fine. I would also recommend that whatever you choose, get a good seat post that allows fine adjustment of tilt and consider fore and aft or setback capability of the saddle rails and/or setback of the seatpost itself as this can be an issue for some.
Likes For Bill in VA:
Thanks guys. I have a Diamond Back mountain bike. The saddle according to the picture below seems the cushion is very thin.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
The key is starting out for shorter rides, taking a day off, and very gradually increasing the time that you're on the saddle. Short rides are 6 miles or so. Work your way up to twice that in a few weeks. As your fitness improves, more of the weight will be on your pedals and less on your saddle. You'll be fine.
Quoted: 365 Post(s)
Liked 419 Times
(Me pulling a number out of my rear...)
98% of saddle problems have nothing to do with the saddle. They are due to either (a) lack of fitness; or (b) poor saddle position (height, tilt, fore/aft) - which can also be due to a poor fitting bike (can't get the saddle positioned correctly if the bike is too big/small, or stem is too long/short, etc.). Lots of people waste lots of time and money looking for a different saddle when it has nothing to do with the saddle.
If your butt is not conditioned to long periods of time in the saddle, your butt will hurt no matter what saddle you are riding. If the position of the saddle is incorrect, your butt will hurt no matter what saddle you are riding. Do yourself a favor and rule these factors out before you go looking for a different saddle. I know it's not as fun as looking at cool bits of gear, but it is far more likely to lead to a solution.
