Air cell cushion saddle cover
This might be a fringe/cringe question but is there anything similar to Airhawk or WildAss motorcycle covers for bicycles? People say they are better than gel covers. Another thing would be reduced weight.
Edit. Found Vanten air cell cushion for bicycles on amazon.
Quoted: 18412 Post(s)
Liked 15,533 Times
Love the text.
Quoted: 6963 Post(s)
Liked 10,962 Times
Likes For Koyote:
Quoted: 6193 Post(s)
Liked 4,808 Times
People riding motorcycles don't constantly move their legs up and down. So comfort isn't going to translate well between the two.
Likes For Iride01:
Liked 15,533 Times
Heh. I think what they tried to say is that the high temperature and "sultry" can cause those problems. Clearly something got lost in translation.
Theoretically it should help for the pressure sores around the sit bones. People say it makes them feel disconnected from motorcycle during technical sections. Some of them have a thin gel pads on the top, so one can always deflate it on the go if needed.
Quoted: 4400 Post(s)
Liked 4,849 Times
I think you would be much better off buying a new saddle if your current one is uncomfortable. A cover sounds like a poor solution.
Likes For PeteHski:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
See Rule #61.
Likes For Badger6:
Liked 4,808 Times
However when I rode very little because I worked and didn't make time to ride, I tended to like cushiony saddles. That was just for 20 minute rides in the neighborhood and at a slow pace. As careers slowed down for me I began to ride more and more. That cushiony saddle just made more places for my skin to rub becoming sore and irritated.
Remember on a bicycle your legs are constantly going up and down rubbing on the saddle. If you ride long, you don't want your legs plowing through the cushioning of the saddle as they move.
Likes For Iride01:
If you haven't tried it and acquired some data, then it's just hypothetical. <grin>
Liked 4,808 Times
Only 2 years ago I was able to ride on a hard leather saddle for 9 hours per day even after winter break. Now at different location tried Brooks, Selle Anatomica and nothing feels right, only Lepper Concorde with softened leather and plain gel cover on top of it seems to provide proper width and curvature which feels supportive, but after 1-2 hours it starts to feel too painful on the sitbones, so had no other choice but to look for new solutions. The Vanten air cell cover feels like something is constantly poking in you. Seems wierd since inflatable air cell cushions are used to prevent bed sores on wheelchairs and such. Bicycle saddles must be the hardest thing in the world to get right.
You claim of pain in your sit bones just has me believing that your butt just hasn't gotten used to the saddle. Did you take some time off from riding? My butt goes through that briefly for about two weeks or so if I haven't ridden in a while. Or even if I ride an unusually long ride after only doing short rides for a while.
Perhaps your cushion isn't letting your sit bones adjust like they should. And if that is your issue, then it can be quite painful to sit on the saddle for a week or so. However if this is muscle pain or skin irritation, then that is not going to go away if you don't find the issue.
Likes For Iride01:
Quoted: 383 Post(s)
Liked 690 Times
Years ago, I purchased a Brooks. I came home from a long ride quite "damaged!" A bikie friend along on the ride suggested that since he commuted 10-15 miles each day, he'd use my saddle for a month. He did a wonderful job breaking it in. Unfortunately, it succumbed many years later to getting slammed by a pickup truck after said pickup truck slammed into me. For a year or so, I had cut holes in saddles to accommodate the smashed left sitting bone (I left my butt mark by indenting the entire side panel of the truck about 3 inches. It was a "good" collision. I also sat on foam at home and at work for a long time. Generally, got over it but more recently that sitting bone does protest too much. Still playing with solutions.
No they aren't really hard to get right. Just costs money to be trying to find the right one for you. Also your perceptions change as you go through the process and what was once important becomes less important.
Liked 4,808 Times
A four hour ride every two months will make my butt hurt too. I wouldn't even put much hope in any saddle ever being right for you. A recumbent bike seems to me the way to go if you want to make that infrequent ride with little pain.
Likes For Iride01:
Although even recumbent is famous for recumbut which probably feels the same way as sitting in your bed for a relatively long time. I think the only way to cycle long distances would be possible only when periodically swapping out recumbent for upright bike. Also tried the Manta saddle but it feels unsafe due to lack of nose and the edge of it seems to press too much at the back of the thighs which cuts of the blood circulation.
Quoted: 1034 Post(s)
Liked 1,290 Times
The disconnected feeling on a motorcycle occurs when the user puts too much air in the AirHawk. The trick is using very little air, just enough to take the pressure off the sit bones and tail bone, without actually lifting those areas off the seat. That being said, I am not sure how well it would work on a bicycle. On a motorcycle seat, there is a larger area, enabling the weight to be spread out over a larger area, thereby taking the weight off the sit bones and tailbone when the AirHawk is used correctly. With this pad, since the main point of contact is actually the sit bones, I really do not see how it would work effectively.
With water it might whick away the heat too much below certain temperature though. Gell is something in between water and solid so it doesn't feel too hot during the summer when not exposed to direct sunlight and not cold during the winter.
Quoted: 532 Post(s)
Liked 621 Times
