Quality water bottles -- need suggestions
I have ordered the Travel Kuppe and it has already been delivered this morning (Amazon same day). Fits well, although in the attached letter the founder recommends carbon cages to prevent rattling. From the sound of it “carbon” sounds expensive so I’ll see if some of the plastic cages that I have to do the job.
Otherwise the bottle looks like a quality product. I’ll give it the field test and come back with impressions
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Originally Posted by Sy Reene;[url=tel:22101672
22101672[/url]]You might be able to hack a fix by putting some black electrical tape on the cage or bottle where the contact points might rattle.
Here is something I have noticed.
I fill 2 polar type bottles with ice from home then top off with water, so probably 1/4 water 3/4 ice. I drink from one until it is empty. a lot of times there is a couple small pieces of ice rattling around after I drink the last bit of water. But when I grab the second untouched bottle, all of the ice has melted and the water is cold but not ice cold. The higher percent of water to ice warms faster.
So now on a hot day I drink 1/2 of first bottle then switch out and start drinking from second. With this method I can have ice water for nearly 2 hours.
Likes For Razorrock:
I do something similar.
3-4 ice cubes in a 32oz insulated vacuum steel bottle, topped off with refrigerator temp water. Stays cold for 3-4 hours.
I also freeze a regular 500ml water bottle to use as an ice pack for snacks. When that melts I have an “emergency” 500ml bottle of cold water. Usually don’t need it but it’s there just in case.
Clark W. Griswold
Quoted: 4328 Post(s)
Liked 3,949 Times
Another vote for Camelbak Podium bottles. I like the Ice bottles in that line, I believe they use Aerogel for the insulation which is pretty light and works really well. I do put ice in the bottles if I need it colder and if I need it really cold I will freeze a bit of water in the bottle but because the Ice bottles work well I tend not to do that so I have more water to drink.
I have used a lot of bottles over time and get a lot of free ones but I still would pay money for a Camelbak over 20 free bottles.
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
The best bottles I've used are the Camelback "Podium" and Triplex (not widely distributed outside Europe). I'm not a big fan of insulated bottles; total volume is more important than the temperature of the contents, and effective insulation significantly decreases volume capacity. While the Midwest doesn't get as hot as Arizona, our humidity is far higher here, which means sweating doesn't cool you as effectively as it would in Arizona.
Thinking of our Hmong families (from Laos, in Southeast Asia), I've found the elders will not drink cold water even on the hottest days. The need for cold drinks seems to be a cultural affectation, not a physiological necessity.
Likes For JohnDThompson:
Originally Posted by JohnDThompson;[url=tel:22104891
22104891[/url]]
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Yeah, as Gresp15C said, here at BF you often get what you don't ask for. So here is my 2¢
I don't use insulated bottles at all. My reason is that the insulation takes up space I rather have in fluid. To a lesser part it adds weight and bulk that I'd rather not carry on long rides.
I am not particular about the temperature of the drink that comes out of them even when I ride in 100°F temps or better. I'd think really cold water would make me get stomach cramps when cycling hard. And I've always believed that cold water takes longer to get absorbed by your body. Since I put most of my carbs in my bottles, I don't want to hinder that process.
Old fart
Liked 3,394 Times
The Hmong are indigenous to an area with year-round high heat and humidity. Drinking ambient temperature water keeps them well hydrated without a need for cold fluids.
You may have a preference for cold fluids, but that's all it is. Adequate hydration is far more important than the temperature of what you drink, and my preference is to carry sufficient fluids and not worry about the temperature of said fluids.
I've got a couple of Polar insulated bottles that are probably 7 or 8 years old now. Insulation is so-so, but they are adequate, cheap, and take abuse. I fill them about half full with ice, and the liquid stays cool for about 2 hours on a moderate day. Only complaint is that the cap does not seal that well, and sometimes leaks onto the frame.
Likes For MNebiker:
Quoted: 383 Post(s)
Liked 690 Times
Advocatus Diaboli
Liked 1,531 Times
Likes For Sy Reene:
Likes For Gconan:
Advocatus Diaboli
Liked 1,531 Times
https://cyclingtips.com/2021/01/bivo...cusing-on-air/
Pennylane Splitter
Bikes: Yes
Quoted: 1779 Post(s)
Liked 1,434 Times
Depends how you define 'quality.' I use the standard water bottles found in bike shops, Walmart, REI, and other similar places. I don't particularly like the drinking methodology necessary while riding so I'll occasionally stop and take a 'chug' on a long ride. It works for me, so that's my level of quality. I also use the freezing half-filled water bottles in the freezer method for keeping cool water on hand, too.
Those Nalgene water bottle holders shown above look interesting. Anybody have a link to a website where they can be purchased? (I've got lots of 1-liter bottles).
Likes For skidder:
Quoted: 83 Post(s)
Liked 64 Times
Polar. Fill full with ice, then h2o and chill for a few. It will still be cool at 1.5 hours even at 100 degrees. In heat you should be drinking at least one bottle per hour so 2 will usually cover until you can refill or take a break.
Quoted: 980 Post(s)
Liked 776 Times
Other HOT Riding Tips.
Pour Ice Water on the back of your Neck
Entering a Convince Store look for an open Beer Cooler.
Place the Top Side of your hands on the Ice or Cold Cans.
This cools your blood as you leave them there.
We do have some Walk in Beer Coolers.... SO NICE.
That’s just as silly as it is nasty and didn’t fly even pre-pandemic.
Quoted: 340 Post(s)
Liked 275 Times
I found an older Contigo by the side of the gravel bike path. It had been there a month, and maybe because of Covid, no one picked it up. I was not too proud to take it home when I saw it a second time. Would you believe the water inside was still cold?
Nah. It was dry, so I sterilized the heck out of it and put it back in service. Keeps ice for 8 hours outside. Good design. steel insulated body. No leak plastic top, I hear they cost about 20 bucks.
Likes For Doc_Wui:
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1349 Post(s)
Liked 1,243 Times
My hands are always clean , I wear Gloves
Fred "The Real Fred"
Quoted: 680 Post(s)
Liked 947 Times
Additionally the sport tops fit other bottles.
