Bottom bracket lock ring spanner?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
I've watched the video on servicing bottom brackets and I know I need a crank puller and a lock ring spanner.
Does the spanner come in different sizes or will one size fit all my 1980 Japanese bicycles?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
I only use the Park hcw-5 lock ring spanner, and never really had much of a problem across a wide variety of vintage road bikes.
https://www.ebay.com/itm/Park-Tool-H...gAAOSw4oFcuJr2
Quoted: 4513 Post(s)
Liked 6,391 Times
Old school Sugino for 45 years.
The trick is to finesse it to get ring and cup off without damaging them, the frame, tools or you.
This is where many of us strongly disagree, for me the DS cup ALWAYS comes out as part of a correct and proper service regardless of weather I am just replacing the grease or replacing it for wear, I want it out to inspect the threads of the cup and BB shell and to be able to thoroughly inspect the bearing track in the cup, it also insures that it can and will come out when it has to in the future.
Likes For merziac:
Bikes: '86 Trek Cirrus 520, '85 Trek 620, '84 Trek 610
Quoted: 24 Post(s)
Liked 7 Times
If you have a Shimano bottom bracket, I would recommend the Park Tool BBT-7. I was disappointed with the fit of the HCW-5. Way to sloppy and loose. I was afraid to really torque on it. The BBT-7 fit much better. Better feel. May be different on other bottoms. Just my 2 cents. Good luck.
https://www.ebay.com/itm/Park-Tools-...oAAOSwq-JehP-B
Quoted: 767 Post(s)
Liked 1,898 Times
Do yourself a favor and go to McMaster-Carr. Measure the circle diameter of your lockrings and choose the one that matches.
Link: https://www.mcmaster.com/spanner-wre...on-the-side-7/
This is what you will receive:
About a 1/4" thick, and much less prone to slippage as those thin, stamped spanners. That one is the 45-50mm, as marked. Cost $22.22 It's one of my favorites.
Likes For BFisher:
Quoted: 1372 Post(s)
Liked 1,752 Times
Can't remember where I got this ring wrench but it works on bottom bracket lock ring/nuts as well as on head set...
Quoted: 7353 Post(s)
Liked 2,481 Times
@BFisher, thanks for the tip on McMaster Carr!
@randyjawa, that looks like a Hozan tool. I have one and like it. It has an increasing radius curve as you go from tip to handle, and it therefore can handle various different size rings.
Quoted: 702 Post(s)
Liked 672 Times
As previously stated, Mcmaster-Carr is an excellent resource. Their tools are high quality so you'll pay a little more. I have Campy and Sugino BB tools but mostly use my adjustable spanner from Mcmaster-Carr
https://www.mcmaster.com/5471a12
Liked 1,752 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Hozan BB pliers ftw!
Properly used, they don't slip off easily like the ones shown above. Also, with practice you can tighten/loosen the adjustable cup by squeezing hard on the lock ring, which catches the adjustable cup and allows you to turn it with one hand. Then loosen your grip to tighten just the lock ring. Back in my LBS days I could do a perfect adjustment and tighten the lock ring in 10-15 seconds after everything's hand tight.
Best of all, one tool fits all. They're advertised as BB/HS plliers, and can be used that way, but using them on a HS you're likely to bung up the HS a bit. They're also handy for gently crimping down lug and fork crown points when you're brazing a frame together.
funny you need one! I have 4!
I knew about two of them, but I cannot for the life of me remember where the other two came from.
Liked 1,752 Times
Post number 12 reminded me of an adjustable cup tool that I made many years ago. Case hardened tips and all. I still have it...
If all else fails just grab a 14" pipe wrench.
Likes For grizzly59:
Quoted: 3811 Post(s)
Liked 6,717 Times
The lock ring tool I’ve had forever has a hinged arm, making it versatile for a range of sizes.
Quoted: 3241 Post(s)
Liked 2,512 Times
If you're taking g out the fixed cup, and it's been in there a while, the best tool for removal is a vise. No need to clamp it. Make the fit snug like with an adjustable wrench. Slip the cup in while holding the frame, Turn the frame like you're turning a steering wheel. Works every time.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
VAR 302 New # BP-30200 Lock Ring Spanner
This is the best spanner I've found for loosening or tightening BB lock rings.
It fits OVER the lock ring surrounding both sides keeping it in place so it can't shift side to side. The heavy duty vinyl "Dip Seal" coating protects the paint on the BB shell.
These VAR # 16 Lock Ring Pliers work OK but if they slip slightly the "teeth" will bark the paint right off of the BB, worse than with a hook spanner.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
verktyg
Liked 1,238 Times
NO Best Fixed Cup Tool Is A VAR Or Campy
Used these at our shop in the 70's, borrowed them from LBSs over the years. $$$, not for everyone but back about 2007-2008 I figured that I did enough BB overhauls so I bit the bullet. No regrets!
NOTE! Tool is reversed - jaw should be on the other side of the BB! What do marketoids know?
verktyg
Chas. ;-)
Chas. ;-)
Liked 2,512 Times
NO! The best BB fixed cup tool is a VAR # 30 or Campy tool. Other companies like Hozan made or make this kind of tool too. When properly used, there is almost no chance of slipping.
verktyg
verktyg
verktyg
Liked 1,238 Times
Campagnolo strumento numero uno
AKA: BFH
verktyg
Chas. ;-)
Chas. ;-)
Liked 5,803 Times
verktyg
verktyg
verktyg
Liked 1,238 Times
Bad Lag I have Phil BBs in about half dozen bikes including one of them that I bought back in 1975 that's been in about 5 different frames.
The last 10 years or so I've been using Shimano UN-55 cartridges and Campy Veloce/Centaur cartridges on a lot of builds.
The Shimano cartridges are selling new for $15-25. I bought a bunch of the Campy BB cartridges for $15 a number of years back.
Last fall I switched the cranks of my 1971 Raleigh Competition beater for gravel grinding. When I bought the bike it had cast SR cranks. I mounted Stronglight 93 cranks to use smaller chainrings and used one of the Campy cartridges. It worked out fine.
The 71 Raleigh had a 66mm wide BB shell rather than the standard 68mm. I had to put two 1mm spacers under the fixed cup to get things to fit properly.
All set for gravel grinding...
verktyg
Chas. ;-)
Chas. ;-)
