Wolf Tooth Geoshift on a Surly Karate Monkey
Is there any disadvantage to altering the geometry on a 2018 Surly Karate Monkey.
The headtube and seattube angles are retro compared to modern standards. I know it will make the reach shorter, but I have a short upper body for my height.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
What kind of fork do you have on it? I have the same frame—medium with a 120mm fork and a 70mm stem. The handlebar has 12° of backsweep, which effectively shortens the stem, otherwise I'd use a 50–60mm stem. I prefer a higher BB and shorter reach. With the medium length suspension fork, the HTA is less than 70°. I'm 5'9" and it does not hold me back, but that's my riding style on rocky central Texas chunk. The contact points on my bike are on the same place that I would put them on a "slacked out" bike.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Well the Geoshift is not going to steepen your seat angle, or increase the reach of the frame, both of which are key ingredients of modern geo.
As far as slackening the HTA.... keep in mind that along with slackening the HTA, you are also pushing the front wheel farther out. whether it is a plus or a minus depends on how you ride. You are going to need to lean forwards more to weight the front end. The steeper STAs and longer frame reach numbers on modern geo helps keep some weight on the front wheel.
