Moving into a tinyhome RV, no room for parts!
Almost ready to start living in the home on wheels, so all the random stuff I've been hoarding needs to go. I generally tried to use the low end of completed ebay listings for pricing, though I'm open to offers or bundle deals, etc. If I were selling on ebay I'd clean a few of them up, hopefully people here can look past a little grime. I'll include it in my description of condition and can send any part through the ultrasonic cleaner if requested. I'll be bumping with more items as I go through them. Shipping negotiable.
Suntour Barcon 7s. Lots of scuffs on outer sides of both shifters, otherwise good shape. Switches easily between modes. $25 SOLD
Suntoru Barcon 6s. Excellent condition, very small scuff on outside of one shifter. Switches easily between modes. $25 SOLD
Shimano 600 RD (RD-6100). Lots of scuffs on the hanger bolt, a little on the knuckle, light grime, but otherwise good shape. $15
Suntour XCD FD/RD. I was planning on pairing it with a set of the barcons. FD clamp is 28.6 I believe. Light scratches, light grime. $30 PENDING
Modolo Speedy brakeset. Some brake dust but should clean up nice. $20.
Shimano RSX brakseset. Dual pivot, recessed. Nice condition, just dusty. Decals perfect. $20
Suntour XCD FD. 31.8 clamp. Might actually be the match for the XCD RD now that I look at them again, I'll figure it out. Either way, one goes with the RD, the other is $5.
Suntour Cyclone (RD-6200). Most of the face decals have scuffed off, no hanger bolt, and the larger pulley wheel is not original. Dirty, but not many deep scuffs or scrapes, so should clean up nice. $10
SunTour MounTech II GTL RD. Wonky design with an extra knuckle for a crazy long cage. Missing some decals, light scuffing/grime. $40 SOLD
Schwinn Le Tour branded Schimano GT-420 RD. No hanger bolt and missing the bolt/nut that secures the cable. Otherwise great shape. $15
Quoted: 5888 Post(s)
Liked 3,471 Times
No pics of the tiny home RV? You know the drill. Pics or it’s not really happening.
Likes For bikemig:
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
PM on the MounTech
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Liked 3,471 Times
Those small parts could make swell wall art for your tiny home/RV but there's no way of knowing without pics . . .
Likes For bikemig:
Likes For degan:
Quoted: 2338 Post(s)
Liked 2,827 Times
As much as I like bike art I'm currently going for a more utilitarian set up, so no art or wicker furniture yet. Mostly because the PO did a number on the interior to the point where I had to completely strip it. Luckily he didn't mess with the mechanical side because it runs like a dream. It was the smallest RV they offered (21') with the biggest engine (6.4L V10). Weird combo, but I got it up to 85 and it had more left to give. My plan is to make it an overlander of sorts. Some lights, skid plate, chunky tires, bash bars, etc. The fact that its pretty much a regular E350 chassis means there are tons of parts out there that are pretty much plug-and-play, even if I went crazy and with a 4wd/manual trans conversion. Heres a pic of the exterior. The interior is all apart, running wiring for lights and solar, putting in a pocket door, etc. Its very dusty because I'm doing some waterproofing and I'm a little afraid to put my work to the test.
Likes For squirtdad:
I'm going to try to limit it to three bikes somehow. It really hauls @$$, lights up the dualies with ease and is legitimately faster then my parents Dodge V8 van which is just a van. I think at 21' its perfect for off the beaten path camping. I just need to see if I can squeeze more than 10 MPG out of it.
A couple more items. Pedals/cranksets coming soon.
Funky Simplex DT shifters with the one-sided clamp. This is what it came with when I got it, unsure of completeness. $15
Simplex Prestige FD. Some rust on adjustment screws, faded plastic. Otherwise functional and complete. 28.6 clamp. $10
Turbo saddle. Didn't get around to re-covering it. Foam is solid. $10
Might hold off on the cranksets for now because I might need a couple that I didn't think I'd need.
Shimano Deore XT pedals (PD-M735). Light paint loss in the typical areas, otherwise nice shape. $40
Sakae pedals (MTP-170). Light rust, good shape overall. $15
KKT Pro Vic II quill pedals. Light scuffing and grime, good condition overall. $15
Shimano pedals (PD-A550). Triangular 600 knockoffs. Light rust on toe cage, good condition. $10
SR SP-150 pedals. Reflectors are rough, cage slightly bent. One spins smooth, one is rough. $10
Ours is a 24' Class C, originally with a 5.8L (351W) but now sports a 505-inch stroked 460. Gets better gas mileage than before (12.6mpg vs previous 10.5) because of increased torque so engine doesn't have to work as hard. also changed from 4.10 gears to 3.73 because of more torque. Before it'd bog down on hills and downshift, now it grunts right on up with no effort - even towing a car behind!
Nice Cougrrcj , does it have that gurgle that stroked and cammed cars get? I'm also looking at changing the rear end ratio, which I guess makes a big difference. Whats your weight at if you don't mind? After I stripped it all out it was down to 7,000 lbs, another reason its surprisingly quick.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
PM sent for XCD derailleurs!
Nice truck.
Mine's a bit older I have the 460 and fuel economy is in the single digits. But I don't drive much.
I was living in a trailer before so I kept that to use as a storage/garage for my bike. I also take showers in there and stuff.
Unfortunately I don't have any facilities at the moment, the PO decided the toilet was in the wrong place and completely fubar'd the water storage systems. The back half of mine is going to be bike storage/workshop for the time being as well. Maybe a hot-tub later on.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I can't figure out what's going on with that Modolo Speedy brake set. It looks like it's nutted in the front, but the rear has a recessed nut on it. I need something in that short reach, to build up a '76 Rossin later on, after I finish the painting. Would you mind terribly measuring how much brake bolt extends on the rear brake, so I can figure out if I can use it nutted, without changing the bolt ? Drilling the rear bridge larger is not a possibility on this frame. Thanks. You can PM me when you get around to it.
Looks like they will fit in a post office flat rate mailing box pretty nicely. I'm still painting, so there's not a big rush on my end.
Edit: also the front bolt length, from brake to the end of it, just to be on the safe side, so I can measure if it will work on this (standard old school) fork crown, nutted on the back, without drilling. Thank you.
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...yeah, probably. Was just a shot in the dark. I can always scavenge some nutted length brake bolts and swap them out into some Campy brakes I have in the box. This was just less work, and I have some Modolo levers in the box as well.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
Footloose and fancy free eh? Now you can attend every bike ride in the country!
Anyone have a suitable bolt for this? It looks a bit rough but I am sure someone here wouldn't mind polishing it up and bit and maybe putting a few holes in it yes?
Sugar "Kane" Kowalczyk
FWIW
Be careful with sticking a bunch of money into a motor home. The boxes are built as cheap as possible (1x3 walls, staples and glue), and then plunked on a frame and exposed to twisting, bouncing, wind, heat, cold, driving rain at 60mph, etc etc. Near impossible to keep seams water tight under those conditions. Stay on top of it the best you can. The box is literally exposed to mini earthquakes every time you drive it. There is a reason those are a dime a dozen with 50,000 miles on them. One day you're buying t-shirts at the Grand Canyon, and the next day you discover a sponge soaked wall or ceiling with black mold. Not trying to be a jerk or scare you, it's honestly the reality with RV's. Be very frugal with throwing a bunch of money at it. They make boats look like a bargain to own, and you know what they say about boats.
Likes For sdn40:
FWIW
That's a nice one. If you can score a used cargo trailer you'll have a garage for all your bikes and extra water and stuff.
Likes For homeless in ca.:
