Canti Frame with Big Clearance
Quoted: 286 Post(s)
Liked 262 Times
I know that CX frames were often built around the 33mm tires for racing, and many can clear 35mm, though I was wondering if there are specific frames for use with Canti’s that can clear up to 40mm tires w/o fenders?
Sunshine
Quoted: 10967 Post(s)
Liked 7,494 Times
https://blackmtncycles.com/frames/monstercross-frames/
50mm tire clearance.
There are various frames thru the years that have the clearance too, so most will be used.
Surly Cross Check
Trek 750 multicross from the 90s
etc
Etc
Surly Cross Check
etc
Etc
Likes For mstateglfr:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Yes, the Monstercross would be the prime choice if they are ever back in stock. I wanted one but dicked around until they were gone. I ended up with a decent Bianchi Volpe that clears only 38 in back but easily 43 in front. It's actually a very nice ride on dirt roads and performed better than the rider on a recent excursion I'd call more mtb than gravel.
Likes For shelbyfv:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
A new Cross Check frame shouldn't be too hard to come by - several shops near me at least have them in stock, like these guys:
https://aroundthecycle.com/collectio...nd%5B%5D=surly
I have Nano 40s on mine, but plenty of folks go wider than that.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I can run 700 X 43mm Gravel King SKs on my Black Mountain Monster Cross with fenders.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
A super budget option if you're searching through your local listings is a Retrospec Amok. For a cheap fixie company offering, it's good. Rides very close to a Surly CC, except with annoying dropouts. Clearance for true 45mm tires. I got mine from Amazon returns years ago solely as a low-trail experiement after I found a fork with a short steerer I wanted to use. Absolutely love it, proof it doesn't matter what name is on it; it's how it rides.
That being said, the craftsmenship is pretty bad. The canti bosses are brazed evenly, but the housing stop is positioned to make it harder to setup brakes. The gussets are crooked under the DT, the cast dropouts are so poor that the B-tension screw doesn't hit right. Stock fork was crooked.
https://www.bricklanebikes.co.uk/fra...0&pageNumber=1
BLB Hitchhiker. 700x42mm.
Bit of weight in the frameset. Cromor.
Went there looking for the yellow NOS 54cm? Fort Cross Foco frameset, but someone has grabbed it.
https://www.lfgss.com/conversations/356502/
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Heck, I just built one up for winter from an old mountain bike. What more should I want? gotta love those gorgeous Klein frames - Trek should really bring them back.
Likes For chas58:
High Plains Luddite
Some folks like to call Cross Checks "obsolete" but I sure like the used one I bought in 2020. I'm running 700x42 tires with plenty of room to spare.
My wife has a mid-'90s Specialized Crossroads hybrid with a steel frame and cantilever brakes. We have 700x40 on that bike but I don't think it would take any wider without rubbing at the chainstays.
Sunshine
Liked 7,494 Times
I have 0 interest in Trek, but would absolutely consider a frame like that.
Quoted: 284 Post(s)
Liked 313 Times
EDIT: I predict on 5-10 years Surly will STILL offer the Cross Check frame
Likes For pbass:
Liked 415 Times
Likes For chas58:
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
My old Voodoo Wazoo from the 90’s had no problem with 43’s.
It was definitely ahead of its time in a few respects.
If you use mini V’s, you might have to deflate the tires to get the wheel on.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I’ve run 44’s under 55mm fenders on my Cross Check, you could probably squeeze 48’s or 50’s in there
Likes For Germany_chris:
