Trek 750: Upgrading component questions
Bikes: 68 Schwinn Varsity, 80"s: Univega Lawee,Fuji Espree,Centurion
Quoted: 8 Post(s)
Liked 5 Times
Greetings,
I picked up a 97 Trek 750 the other day and want to convert it for a gravel bike for a race my wife and I are tackling in the Lost Sierras next year.
The gears and teeth are pretty worn and "fin" like so I was looking to replace the front crankset and rear cassette and upgrade the derailleurs if needed. Currently the bike has Shimano STX components.
I'm not looking to do a 1x as I'm pretty happy with the current gearing. Would I be able to use a Sram S600 (42,32,22) or similar?
I am also going to need some drop 3x7 brifters. I read in another post that Shimano Sora ST3300 shifters would work but I wanted to see what others are using.
Here's the 750.
Thanks for any help!
Here's the 750.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
The new crankset may need a bottom bracket with a different spindle length. If you are changing the bottom bracket and crankset you may consider upgrading to external bearings/2-piece crankset. Shimano FC-MT210, T4060 or similar.
If you are converting to brifters/drop bars and replacing the whole drivetrain you can also rebuild the wheel with a different hub/get a new rear wheel and go 8 or 9 speed. The choice of 7 speed cassettes is not great. I really liked the 13-28 one, but Shimano stopped making it and most of the other ones. More choices if you go 9 speed.
I run Sora 3500 brifters with a 105 FD-5504 front derailleur, Microshift M46 rear derailleur, Shimano HG50 11-30 cassette and 48-36-22 Shimano FC-M590 triple crankset on my bike.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 8 Post(s)
Liked 5 Times
Thanks for the specs csport. I"ll research those options. I'd rather not throw a new rear wheel into the mix if I can find a lightly used HG-50 but availability looks limited.
I"m also not sure what size tires I can get on these rims but if I can't fit at least 40's I may go that route. What drops are you using?
Dedhed- Thanks for the link. Yeah, I've started reading that thread already and I'm about 5/300th of the way thru Great info though.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
The factory Matrix Vapor rims are, if I recall correctly, 15mm wide internally. I've had as wide as 40mm tires on my '97 750 and they worked very well. With a tire that much wider than the rim, you start to have concerns with getting brakes to open wide enough to clear the tire when adjusted correctly for the rim width, so I don't think I'd go much wider than 40mm for that reason alone.
Quoted: 1562 Post(s)
Liked 1,734 Times
My understanding is that the STX groupset is a MTB groupset and as such the FD is not compatible with road brifters.
If you want to stick with a 3X7 drivetrain, you can look for a RSX triple crankset and RSX FD. In addition to the RSX and ST3300 brifters, another choice for 7 speeds is the Microshift R7 brifters.
As for wheels, if it was me I would change out the rims to tubeless ready rims. For wide tires with low pressure, tubeless is best.
Quoted: 217 Post(s)
Liked 155 Times
I was trying to say that if you get 7 speed brifters you are locked into 7s which is dead. Replacing/rebuilding the wheel with a wider hub will let you go 8-11 speed (11 speed with a MTB cassette).
Another solution is to upgrade to 9 or 10 speed and run 8 of 9 or 9 of 10 on 7 using the current wheel: https://www.sheldonbrown.com/k7.html (you have a 7s cassette hub, not a freewheel, right?)
At some later point you can get a new wheel and run the full cassette.
Quoted: 514 Post(s)
Liked 450 Times
Understand that the spacing between chainrings is wider from road to MTB. And while you can get flat-bar shifters that work with road derailleurs, you can't get a left STI lever that will work with an MTB derailleur. And road brake levers don't pull enough cable to effectively actuate linear-pull brakes. But for the go part, if the rear axle spacing is 130 mm, I'd recommend a full Claris 8-speed kit. 8-speed freewheels are still available. But I don't have a solution for the stop part.
Quoted: 8 Post(s)
Liked 5 Times
csport- I have the freehub with cassette. (Shimano FH-R050 silent clutch) which according to the homework you graciously sent me (Sheldon Brown) means I could swap in a 9 sprocket cassette for the time being. Cool, I didn't realize that. I know you're running Microshift and Shimano deraileurs with Sora brifters so I guess compatibility isn't an issue?
hokyfied- I don't plan on going larger than 40 on the rims so that should work. I read once that you had issues with the beading on these Matrix Vapors.. any particular brands you liked that had better fitment?
Quoted: 217 Post(s)
Liked 155 Times
Freehub body for 7 speed cassettes is narrower, and it will not fit an 8-10 s cassette (unless you have an 8-10s freehub body with a spacer - most likely this is not the case). You can remove one cog from a 9s cassette and mount it on the 7s freehub you have, the article I linked has a section named "8 Of 9 On 7 -- or 9 of 10 on 7" near the end. You will need 9s shifters, and with this setup one shifter position will be not usable. If you ever get a wheel with a full 8-10s freehub and mount a full 9s cassette you will be able to use all shifter positions.
Quoted: 8 Post(s)
Liked 5 Times
Thanks for the lengthy explanation csport. I'm still wrapping my head around these conversions between road and MTB and this really helps a lot.
We're packing up the Airstream today and heading up to the Gorge to see DMB so I'll have to report back once we return and I have some time to finish this build.
Thanks again everyone.
Really Old Senior Member
I included the exploded view of your hub, the 8 speed version of the same hub, an "old style" 7 speed hub and one of the semi newer 8 speed hubs.
Your hub is "the odd man out" compared to the last 2 docs (and beyond)
You can see how the FH bodies attach very differently on your type vs the 2 other types. I'm NOT up on the latest stuff, so it probably gets worse with all the different diameter through axles etc.
Anyway, study the docs and I think you'll find them somewhat informative.
You could have a new hub installed on your current rim. Spokes should work lengthwise. The wheelbuilder may not want to use used spokes. Frequently the threads are so corroded, you simply can't get a good feel on tension which results in frustration and a less than good job. Think of having to twist a spoke a 1/3 of a turn before the nipple releases. I'm too old and cranky to not use new spokes & nipples. It makes it MUCH easier to build a "good" wheel with nice even tensions.
What's the drop out spacing?
Liked 762 Times
Spacing on this bike is 135mm.
Regarding tires, yes, I have had trouble finding ones that "fit nicely" on these wheels. I've been happy with Continental Speed Rides (those are the 40mm tires I referenced earlier). They're labeled "700x42", but they inflate up to about 39-40mm on those rims.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Matafuna A number folks are mentioning that the your existing front derailleur won't be compatible with road shifters. Why not universally true (I have a '93 XT FD running happily with a 3x Tourney shifter), it is true most of the time. You can use your mtn/trekking FD with road shifters if you install a Shiftmate. Works fine.. (I'm surprised this isn't more well-known as it's an easy work-around)
Jtek ShiftMate Gear Shifting Adapter for Shimano Campagnolo and SRAM components
As for brakes.. install a set of cantilever brakes..they play well with road shifters and are easier to run with wider tires. There's lots of vintage stuff around, or pick up a set of Tektro CR510s or CR720s. Cap them off with Koolstop pads and you're good to go.
Quoted: 576 Post(s)
Liked 1,003 Times
Greetings,
Here's the 750.
Here's the 750.
Quoted: 5888 Post(s)
Liked 3,471 Times
You could find a set of 7 speed indexing bar ends (rather than brifters) and keep your existing derailleurs. That's what I'm going to do with a '93 Trek 750 I picked up recently. I wouldn't be so quick to change out parts if they are still serviceable but I like reusing parts. YMMV.
High Plains Luddite
Nice bike. I'd love to pick one up someday.
I prefer a friction shifter for the FD on a triple, but I had a '96 Specialized Allez for a few years with Shimano RSX 3x7 brifters. They worked very well once cleaned and lubricated.
Quoted: 8 Post(s)
Liked 5 Times
Its been 9 months since I posted about this build and we are finally starting to see Spring-like temps up here in Sierras so I wanted to update this thread about the Trek Multi-track build.
I replaced the front straight bar with a Ritchey Comp Beacon drop handlebar. Replaced the bar shifters with Microshift 3x7 brifters and a Microshift rear derailleur. And put on a new front chain ring and rear Shimano cassette S. Also added WTB Raddler 44's, a new chain and have some new pedals and an Ortlieb rack and panniers on the way.
We went out for a 15 mile ride around Lake Almanor yesterday and I was very happy with how it rode and how comfortable it was!
I have a question about front derailleur options. I'm currently using a Shimano 105 FD 5504 and it has some fitment issues. In order to get the correct clearance on the outer ring and also be able to push the chain onto the inner ring I've had to shave some material from the bottom of the cage in order to clear the frame. I realize I'm trying to mate mountain and road components here but has anyone found an alternative that has a smaller cage or work around?
I was looking at the Microshift's Mezo 3x7/8 (FD MD20) as an option. Here
Has anyone tried this particular setup or have a suggestion?
Likes For Matafuna:
Quoted: 502 Post(s)
Liked 436 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
He needs to find a Road type ft. der.with a shorter cage, but still a triple.. this may not be easy.
Quoted: 502 Post(s)
Liked 436 Times
I think it's part of the issue.
Yes - a 42 t big ring is 20 mm lower than a 52 t.Although I don't see a problem with shortening the cage as he has already done - maybe take a bit more off, tidy it up and weld a piece across the gap. Maybe I'm missing something (again).
Liked 739 Times
And not everyone has a welder handy or a friend to bribe into welding a rather thin derailleur cage.. Also, welded Chrome looks like crap.
Quoted: 8 Post(s)
Liked 5 Times
I installed the Microshift Mezzo today and it certainly fits better with a cage curvature that matches the size/angle of the triple and doesn't come close to hitting the frame.
Thanks for all the info and helpful suggestions!
