Used 90's RSX vs modern Tourney for a 7-speed rebuild?
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 89 Post(s)
Liked 110 Times
My apologies if I haven't posted this in the right forum - couldn't figure it if it fits best here, or bicycle mechanics, or somewhere else.
I'm acquiring parts to rebuild a 1992 Trek 790 hybrid with drop bars. It currently has a 7-speed drivetrain. Assuming I don't change that, and I want to install a brifter at minimal cost (I'm not sure I'll love the bike once built up, and if I do love it I can upgrade components later): am I better off finding used parts (a good candidate donor bike with 7-speed RSX showed up on Craigslist), or buying new 7-speed Tourney?
Death fork? Naaaah!!
If in good nick RSX would be preferable to Tourney (I've used both), but I would take Microshift over either. The double paddles just work better for me.
Top
Top
Expired Member
Quoted: 3773 Post(s)
Liked 5,725 Times
Research "8 of 9 on 7." You'll likely find a good selection of better used Shimano shifters or new Microshift.
Clark W. Griswold
Quoted: 4456 Post(s)
Liked 4,125 Times
Would rather have good working vintage shifters or modern Microshift over anything Tourney. The only Tourney I would ever consider running would be a UN-300 bottom bracket or 70s vintage tourney brakes on some odd project but in that situation I wouldn't actually. The B.B. sure but the brakes no.
Quoted: 1618 Post(s)
Liked 1,809 Times
I lean towards the RSX groupset because it's silver, and looks better on an older bike. The RSX groupset is also very versatile. The RSX cranks come in 110mm compact double, 130mm double, 110/74mm triple and 130/74 triple.
The Tourney brifters do have one advantage though- there is an indicator telling you which gear you are on.
