Shimano 2x10 CX gearing limitations
Hello all,
I'm riding a 2015 Surly Straggler as a do-it-all machine that gets lots of miles, however I've moved to CO recently, and have discovered that loaded down, my 46/34-11/32 gearing may be no match for these Rocky Mountains. Currently set up with Ultegra 2x10 brifters, Ultegra LC RD, 105 FD, and the aforementioned gearing.
Does anyone know if it's possible to fit a larger cassette under the Ultegra LC RD? Or, will my crummy stock crankset take a smaller 30-32T ring up front? (can't remember the BCD, 110 IIRC).
Sadly, over the last 5k I've slowly pieced an Ultegra groupo together when I probably should've swapped over to the more flexible SRAM 2x10 setup to run a huge cassette and MTB RD with road brifters. Are there any other options? Shimano pulled a fast one with their 'new and improved' dynasis pull ratio, so now their Ultegra line is incompatible with their MTB RDs.
Looking to keep costs down, but ideally I think I should be running 50/34-11/36, or better. I have a full camp set, racks, pannies, bags, etc. and I definitely want to haul some of that gear through the mountains.
Sorry for long post. TIA.
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
The Wolftooth Roadlink (RoadLink ? wolftoothcomponents.com) would allow you to run an 11-40 cassette in the rear (look for Sunrace 10 speed 11-40 cassettes, they're very affordable) while retaining your Ultegra RD.
The Wolftooth Tanpan (Tanpan ? wolftoothcomponents.com) would allow you to run an MTB RD with a larger cassette, probably an 11-42, which is not a huge gain on the roadlink.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
1- as mentioned, wolftooth roadlink. I will eventually use one for an 11sp 105 group I have on a gravel bike im building. Totally inappropriate gearing choice for how I want to use the bike, but I really wanted to try a CX crank along with 11sp gearing and the 105 group. The wolftooth workaround will make it easier to use as ill have 46-34 mated to an 11-36 cassette.
2- your crank, assuming its 110(and it almost for sure is), cant have a smaller ring added. Technically, a 33T ring could be used instead of the 34T ring, but that ring is expensive and uncommon.
3- I would struggle with your gearing on the hills around me, so i cant imagine how bad I would do in the Rockies. Nothing more to add on this thought.
4- Have you thought about moving to a triple? An old(or new) 110/74bcd triple would give you some really easy gearing. You could have a 26T granny up front for bail out situations.
5- FSA has a Gossamer model crank that is 46/30 and can be paired with all the stuff you already have.
aren't you going beyond the capacity of most
rear deraillers?
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Hello all,
You might be able to replace the crank with a 104/64mm BCD 4 arm mountain crankset. You can't get chainrings smaller than 32 teeth for the middle ring but you could jigger the chainline so that you could run a 46 tooth ring in the middle position and a 26 tooth ring on the inner position. This would give you this gearing with your current cassette. I've also included using the 11- 40 tooth cog in the chart for comparison. Neither would be that pleasant to shift...lots of large holes...but it would be workable.
You could also use a 42 tooth outer with the 26 tooth inner for a bit tighter range while sacrificing the high gear. The transition from high to low would be a bit less jarring than the 46 to 26 shift.
If you really want to extend your range, however, a triple is the way to go. A 46/34/22 crank with an 11-32 would give you really good climbing gears and much smoother transitions across the range. But it wouldn't be cheap. You'd need a crank (and probably an outer ring), a new left shifter and a front derailer. I'd put the cost at around $400 depending on level of components.
Stuart Black
Stuart Black
I certainly agree with a triple being the best option for real world riding on a bike with baggage on it.
Unfortunately the costs are what they are.
bottom line is that triples just work better for riding with baggage on a bike, especially with gradients in any sort of mountainous terrain. The bike industry has been trying for years now to convince people that doubles are the bees knees, but it just aint so.
good luck with your dilemma and evaluating the pile of money involved.
Yes A triple crank allows a Lower low gear ratio.
the chain slack take up, may require a longer cage on the rear D.
Quoted: 3462 Post(s)
Liked 1,468 Times
Another vote for a triple.
Some bike shops have a bucket of used vintage parts in the corner somewhere (price often negotiated). If your bike has the fitting for a downtube friction shifter (I assume it does), you could use a friction shifter for your front derailleur while you decide if you like using a triple. Then if you want a different shifter later, deal with that at that time.
I am running a brifter for my rear, a friction downtube shifter for my front (a vintage Huret shifter) on my rando bike with a square taper Campy road triple. I often use vintage front derailleurs that were designed for doubles on my bikes with triples, such derailleurs are cheap and easy to find.
I have no idea if your rear derailleur would take up all the slack, on my derailleur touring bike when I am on the smallest chainring I can't use the two smallest rear sprockets - but those two gears are badly cross chained so I would not want to use them anyway.
Lance A (yes I know he is quite ridiculed now) used to use a downtube friction shifter on the front with a rear brifter, tell people you did that to make the bike lighter like Lance did.
Quoted: 598 Post(s)
Liked 283 Times
There are only 3 manufacturers of a 46-30 crank that I'm aware of, one makes use of an external bottom bracket (Sugino), the other two need a square taper bottom bracket (IRD and Velo Orange). With a standard 10 speed 105 gs derailleur, I can get a 11-34 cassette to work nicely without too much manipulation of the B screw but I can't go any lower than that (30x34) 23.6 gear inches. Sugino will allow you to create a lower double crank but they are extremely pricey and at that point, I would just buy a cheaper mountain bike crank and work from there. An XT triple of 48-36-26 and an 11-34 cassette only gives you ONE lower gear combination vs. the double of 30 x 34 above. Is it worth it ? That's up to you to decide but otherwise you're going mountain bike drive train and/or changing out the 26 for a 24t which can get you a little lower.
Quoted: 188 Post(s)
Quoted: 233 Post(s)
Liked 165 Times
SunRace MX3 10 Speed Shimano - SRAM Cassette | Chain Reaction Cycles
Quoted: 188 Post(s)
That was correct until this year. Check out the Sunrace MX3 10-Speed 11-40.
edit: nevermind, it's for a 1x10
Quoted: 233 Post(s)
Liked 165 Times
I may actually be wrong about it being able to be used in a 2x10 drivetrain. Is there a reason why it can't be used with a double up front?
Edit: Wolftooth's Roadlink compatibility section states: "11-40: Single or Double Chainring (front rings can be no more than 14 teeth different e.g. 48-34)" and people on other sites are reporting running 50-34 cranksets with 11-40 cassettes.
.... An XT triple of 48-36-26 and an 11-34 cassette only gives you ONE lower gear combination vs. the double of 30 x 34 above. Is it worth it ? That's up to you to decide but otherwise you're going mountain bike drive train and/or changing out the 26 for a 24t which can get you a little lower.
gearing-wise as the current setup, unless you
fork out even more for new rings?
get a deore 22-32-44 and be a happy camper.
Sunshine
Liked 7,496 Times
Sunshine
Liked 7,496 Times
Im sucked in right now because im building a new gravel bike and decided to go 11sp to try out the newest goodies.
The speed incompatability combined with the insane bottom bracket options has driven me nuts.
Anyways, not sure if this FSA 46/30 is just an OEM crank for now or what.
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
Liked 8 Times
SRAM and Shimano both make 46-32's, that's what I use. It would be fairly simple to pair one with an extended range cassette. Praxis makes a 11-42 cassette for 10-speed that would be happy tied to a long-cage derailleur.
FSA AFTERBURNER MTB Bike Crankset + BB30 Compact Double 170mm 42/27T X-10s $96
https://www.amazon.com/AFTERBURNER-C.../dp/B015T3ZSRC
Quoted: 598 Post(s)
Liked 283 Times
Quoted: 188 Post(s)
Yea, but again, that's not the Holy Grail, 46-30 of which I have climbed mountains and sailed the seas for. That's just a cheap mountain bike double that you can find being sold by any homeless guy in an alley. Find thee the FSA 46-30 and you shall be knighted (even made king if can be found for less than 200 clams)
Sugino OX601D crankset
edit: It is a 10speed crank though...
Quoted: 188 Post(s)
edit: I guess I got lucky as I see the 170mm are out of stock..
Liked 4,222 Times
Stuart Black
Stuart Black
