Tire pump....or CO2 cartridge?...Which works better for you?
Just curious, I can't seem to find a mini pump that works satisfactorily for me, I had a slow leak and was carrying a regular sized pump to top off the pressure until I had time to change the tube and it got me thinking about those CO2 cartridges...any insights?...beyond me being to lazy to change my tube right away....
Quoted: 3376 Post(s)
Liked 5,526 Times
"mini pump that works satisfactorily" -> Lezyne
Pump for *reliable* air source.
CO2 if you need to get back on the road in a hurry, i.e. group ride or racing.
CO2 is a *supplement* to a pump, not a replacement.
Older than dirt
Bikes: Too darn many.. latest count is 11
My answer is "both"
I use this because it's small, works well and is pretty much the best of both worlds. More than anything what I have to carry is minimal.
https://www.genuineinnovations.com/bi...-wind-mtb.html
Bikes: '06 Trek 1000, '09 Gary Fisher Supercaliber, '10 Trek XO2
I just use CO2 and save the pumping for home. If I am commuting somewhere I bring and extra tube and cartridge in my pack.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
I carry CO2 and a frame pump. I usually use CO2 when I get a flat because it is so much quicker. The pump is for backup. I started carrying it after I got two flats in one day and ended up walking 4 miles in my cycling shoes.
I am a caffine girl
Bikes: 2012 Stumpjumper FSR Comp...2010 Scott CR1 CF...2007 Novara FS Float2.0...2009 Specialized Hardrock Disc...2009 Schwinn Le Tour GSr
I only carry a Topeak Morph Road G pump. I used to carry a CO2 also until I got the Armadillo Elite All Condition Tire. If given a choice between the two, I choose the pump since I also use that to top off my Airzound horn.
The topeak road morph works great for road or mountain bikes. Has a gauge and a piece to put your foot on. The nice feature is a small hose that allows you to pump without moving the tire valve around.
Bikes: Trek SU100, Surly Cross Check
Topeak road morph is what I tote. The problem with CO2 is that it'll slowly expand as the gas warms up, increasing the pressure by much more than you expect.
Lio Fralop
Bikes: '95 Klein Attitude w/XT & '05 Klein Aura w/Ultegra
I prefer a mini-pump for my bike that has lower pressure tires (like 50ish), but co2 for my higher pressure tires (like 100psi).
Ditto on the Topeak road morph Now, if you're asking about CO2 vs practically any other pump (except my floor pump at home), I'll take CO2. The road morph really works that well for me, though.
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
I'm a manual guy through and through. https://www.crankbrothers.com/pumps_alloy.php works for me.
But then, I also choose hand crank windows and manual door locks in a car if available.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
The problem I have with CO2 is that once you use them, you're done. That's it, no more. If you carry 2 CO2s and you get 3 flats in a ride, you're stuck bumming a cartridge or pump off one of your buddies. (Plus I see a lot of CO2 cartridges littering the roadside on popular local routes because people can't be bothered to carry their empties to a trash bin.)
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
Bikes: Tons
Using the ideal gas law (PV=nRT), which is not very ideal, but gives us a rough estimate, we assume that at room temperature (295 Kelvin) with 100 psi (689.47 kP) in a 700x28c tube (1.26L, 0.00126m^3), we can determine that there is roughly 0.3545 mol of whatever gas you use.
Now, using that same amount of gas (0.3545 mol) in the same tube, at the freezing point of water (273.15 K), we can determine that the pressure has now changed to 92 psi (638.90 kP). Now, warm up that same gas to the boiling point of water (373.15 K) we determine that the pressure has now changed to 126 psi (872.797 kP) that seems significant, but do your tires ever reach 212 degrees Fahrenheit?
Using the ideal gas law, and what we know, we can derive that for every one degree Celsius change, the pressure changes by 0.339 psi.
Now of course, I don't know what temperature the CO2 comes out of the cartridges, but it can't be that cold, can it?
I'd hardly call the few PSI that it would increase significant. The pressure would increase more from the tube getting warmed up due to just riding around on asphalt and it would do that regardless of what gas you use.
Quoted: 52 Post(s)
Liked 17 Times
Mini's were OK for lower pressure tires, though the ones I had weren't very durable. Now I have a Crank Bros Alloy pump and a Topeak Road Morph. Both are quality pumps but the Road Morph works much better. It's the closest thing to a floor pump (other than a floor pump) that I've used.
I also have a CO2 Inflator that I carry instead for triathlons or any other event that requires a quick repair and minimal storage. I've never actually used it except to test it.
Bikes: Tons
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
Another Topeak Road MorphG user.
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Bikes: Trek 830 Mountain Track Drop bar conversion
It might be a lot of pumping, but it'll get you there.
Thanks for the replies, I'll have to check that one out. My Planet Bike pump is rated for 110 psi, but the compression fitting popped off the valve before I hit 80. Could have been user error.
Quoted: 5 Post(s)
Liked 7 Times
My Road Morph G had no problems with bringing my 28mm tires up to 115psi, and I helped a guy with a 130psi tire once. It's a lot of work, but it will get the job done.
- Mandi M.
- Mandi M.
I am a caffine girl
I used to have trouble pumping my 700x23 to 100 psi with the Road Morph, but that's because I was treating it like a regular hand pump pressing it on my body instead of flipping out the tab and holding it on the ground with my feet. Duh (oh, so that's what that thing is for). That was a while back. Now I can inflate tires to 100+ psi with ease. I even beat this guy one time in the parking lot who had trouble pumping pass 90psi with a cheapy Bell floor pump with a digital Gage. He was impress how much faster I got his tires to 110psi.
Bikes: 2002 Litespeed Vortex - 2007 Trek Madone 5.9 - 2004 Redline Conquest Pro - Specialized S-Works Festina Team Model - 93 Cannondale M 800 Beast of the East
Shimagnolo is living in my head..... Everything he said is exactly what I would have said.
