two brakes - One handle ??
Droid on a mission
Quoted: 319 Post(s)
Liked 281 Times
OK, We very rarely get newer used bikes in our shop but got in one the other day with a brake system I have never seen before.
It has a single handle but yet controls both the front and rear rim brakes via cables.
Not having seen this before, I am unsure what it is even called to look up help on repair/adjustment. It seems the brake cable travels from a floating pad of one brake assembly to the other brake assembly..
Can someone tell me what this brake system is called and possibly point me to some repair/ adjustment docs/videos?
Thanks
Thanks
Quoted: 94 Post(s)
Liked 151 Times
I recently came across such a bike. I believe it was a Jamis or a Hudson. The bike only had a right hand brake lever which engaged both front and rear brake sets. The rear brake has a floating brake pad that slides forward when it contacts the rim. The floating rear brake pad is attached to a brake cable leading to the front brake set which is actuated when it contacts the rim. As the floating brake pad contacts the rim it slides forward which pulls the cable which engages the front brake pad. The front brake set is normal. We asked the bikes owner about the brakes (which were weak at best) and he asked us to convert to a conventional system with separate brake levers. Some people need a brake system to operate with only one lever but I think the Double Barrel brake lever offered by Problem Solvers is a better option...
SE Wis
Quoted: 2751 Post(s)
Liked 3,407 Times
Common on tandem bicycles with 3 brakes. 1 drum and 2 rim brakes.
There are a number of ways to accomplish this.
https://problemsolversbike.com/files...le1-2_inst.pdf
Quoted: 1438 Post(s)
Liked 1,092 Times
Probably the simplest solution would be to convert the brakes to 2 separate levers as ARider2's customer requested.
Never knew that exists. I doubt it improves braking because your finger force will be split in half for each brake. I guess diverting braking force over 2 brakes helps cooling each brake, though. So the above tandem comment makes sense.
I first though it was for a person with just one hand to control front and rear. but on a bike, you want separate control over rear and front brake (unlike a car, where the driver only has 1 brake, but the computer uses electronic brake force distribution, ABS and VSC to control each of the 4 wheels individually)
Bianchi Goddess
Quoted: 2942 Post(s)
Liked 2,947 Times
FWIW DiaCompe used to, or maybe still does, make a drop bar style lever to control both brakes.
Sugar "Kane" Kowalczyk
Droid on a mission
Quoted: 319 Post(s)
Liked 281 Times
As you described. Is there a name of this brake system and any fine points for adjustment, like a youtube video. I checked Park Tool's site and didn't see anything covering iit? It might have been a Jamis bike, right now it is in the back of our storage unit so getting to it to check is a royal pain.
Droid on a mission
Quoted: 319 Post(s)
Liked 281 Times
I think I found it, check out this link
bike world news
Thanks to @ARider2 for pointing me in the right direction
bike world news
Droid on a mission
Quoted: 319 Post(s)
Liked 281 Times
It is called a Sure Stop brake system SURESTOP Brake System | Safer, Smarter, Simpler Braking
I also found two YouTube videos, 1st showing how it works and 2nd is how to replace the active pad
Edited to add a replacement parts kit
https://surestop.bike/replacement-parts/
Lol. they are afraid of the FRONT locking up? The front never locks up on normal surface, the rear will. and the added 2m of cable for the front brake (going to rear, then back front) adds so much friction and stretch that the front brake just will be a token brake. and ultimately you only use the force of one hand. That must be less overall braking power than than using the force of 2 hands.
elcraft
They are also in use for bikes designed for bicycle Polo. Since one hand is wielding a polo stick, the other must do double braking duty...
Quoted: 94 Post(s)
Liked 151 Times
We found the braking was weak with the one lever system, giving little or no front braking power and weak rear braking too but it was several years old and would probably have performed a little better with new pads and cables. Using separate brake levers and new pads had it working well again.
aka Phil Jungels
Frequently used by someone with one hand!
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Quoted: 1074 Post(s)
Liked 295 Times
While not necessarily a lockup by definition, it can quite probably feel like one.
And blaming lockup, inferior design is more acceptable to the ego than admitting to user error.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Found, but not purchased, at the local co-op. While it might not provide the best braking performance, depending on how the brakes are adjusted, for someone with a bum paw it might be just what s/he needs.
What I’ve seen happen though is a rider clamping down hard on the front brake, w/o being properly braced or positioned. Inertia then proceeds to drape the rider over the handlebar, at which point all semblance of balance and control is lost.
And this 2-brake contraption only gives HALF the brake force to each brake since you only use one hand, which happen to be half the hands you use on a normal setup. Yes, locking up may not be an issue, but stopping before you hit something will be an issue.
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,011 Times
My daughter was born with a short left arm, just below the elbow. I built this bike for her, a grip shifter for the rear and a thumbie for the front. A bar end on the left side lifts it up high enough for her to rest her arm on.
Likes For bwilli88:
Droid on a mission
Quoted: 319 Post(s)
Liked 281 Times
Nicely done
