The frame doesn't fit pass-around game
#2251
tantum vehi
Quoted: 1168 Post(s)
Liked 993 Times
[QUOTE=mhespenheide;23088165]
Not looking!
mountaindave , There's a 60cm Serotta in that color scheme over on Pinkbike that's been listed for ages. It might even be in Spokane, if I remember correctly.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#2252
Listing a few frames that I'm not using at the moment.
First up: I have what was sold to me as a 55.5cm 1976 De Rosa frameset. I say "what was sold to me as" because I have not done research to verify the date myself yet and I didn't see any serial numbers to make identification a closed case. The seller is very knowledgeable and reputable so I have no reason to doubt him. Happy to share more details privately to back up the seller's legitimacy (just don't want to out him on a public post). It was repainted in Italy and they did a good job. There is a paint blemish on the inside of the chainstay. No dents. Comes with a campy headset and bottom bracket. I have to verify this but I think the dropout spacing was 124mm? I don't know why that number sticks out in my head though so I really do need to verify it - I haven't spent a ton of time with this frame yet.
I'd really like to trade this for a 70s or earlier De Rosa in a bit larger of a size - 58-62cm, with 60/61 being the sweet spot. I'm also open to trades for similar caliber Italian or French bikes from the 70s or earlier, or high-quality steel frames from noteworthy American builders of any era (paging Bruce Gordon ). Could be open to other stuff as well, but those are currently my main interest areas. Particular interest in French constructeur bikes of any size, but for the very nice French bikes, I have some things to offer of a higher caliber than this one.
Many more photos available for interested parties.
#2253
Next up is what may be a 1982 Trek 730. This is a frameset that I haven't been able to definitively identify yet. The serial number is 025360, which makes it a 1982 Trek 730 according to the vintage Trek website, but there are a couple things that don't align with that ID.
First, there is a second Trek decal on the downtub, which the 730 did not have. Usually only the very high end Treks had that decal treatment. Second, there are double eyelets on the fork, as well as a mid-fork braze on, presumably for a rack. There are no double eyelets on the rear dropouts, however. So maybe the fork was replaced? But the paint appears original, and it would have been a hell of a color match if the fork was swapped. Could be a 720 fork from the same year, which had the same color. But that still doesn't explain the downtube decal....
I have not really dove into this frame yet. There is a dent on the top tube consistent with a handlebar hitting it. Does not appear to me to be serious or concerning. I checked the stem to make sure it was not seized, but that is the extent of work I have done to this. Have not even wiped it down.
I could be convinced to trade this for a range of things, preferably in a 59-61cm seat tube range.
#2254
Bikes: many
Quoted: 1455 Post(s)
Liked 1,404 Times
#2255
tantum vehi
Liked 993 Times
Not even if someone obstructs your view with it?
https://www.pinkbike.com/buysell/3177295/
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#2256
I'm looking for a 130mm spaced, 60-61cm road frame to put on a direct drive trainer. Could do 126mm as well and cold set it. Open to completes as well, but starting the search for just framesets. Open to a range of things, but preferences start with lugged steel, particularly lugged steel that has touring or relaxed geometry. Would definitely consider nice frames that need a repaint, but also open to frames in good shape. What I have on offer to trade would depend on what bike you had to give up. I also have quite a few vintage components to trade if the frame on offer was of a lower tier.
Anyone got anything good?
#2257
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 520 Post(s)
Liked 433 Times
its an 84 or 87 Merz.
it was beat to heck when I got it.
I’ve made some repairs and covered it with plum SprayBike and expensive 2K clear.
if you’re interested I can send you many details.
https://www.bikeforums.net/g/album/28780430
#2258
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1243 Post(s)
Liked 3,598 Times
It’s on the large size for me, but let me check to see if it’s a 60.
There were 135 Confentes, but only one...Huffente!
#2259
Quoted: 1957 Post(s)
Liked 2,029 Times
1973 Raleigh Competition 21.5”
I believe very low miles but stored improperly. The rust is removed,California approved chemical paint removal, it got an OA bath and the BB has been chased at the lbs. Top tube is 57 ctc and I can make it work but I WANT TO TRADE FOR 1973 23.5.
The F&F are hanging and waiting for me to paint and transform it into a John Deere Green, boat hauler with a 22/32 double unless I can trade. I’ll post pics if anyone has a med lg 73 Comp.
#2260
Bikes: cheap Schwinn Regent (fixed gear); 80's Miyata 310; 1963 Schwinn Typhoon klunker
I have an eighties Raleigh mixte bike -- 19"/49cm? Broken down to frame and a box of components at this point, but I have everything that came on the bike. Looks like just under 100mm fork spacing (96mm?) and 130mm frame spacing (which is kinda weird -- I was expecting 120 or maybe 126mm...). Wheels are 27 x 1-1/4. Ten speed. And, of course, cottered cranks (and I have a 73mm spindle that I was going to try to use with original BB cups to install a different crankset, a la Sheldon...). Happy to swap with someone who really wants it. I don't think I can post pics yet bc I'm new to forum, but happy to DM pics if anyone's interested.
I'm looking for pretty much any old steel road bike in the 22-23"/57-58cm range to convert to 1x or SS or hacked fixed gear. Prefer English threaded BB, but not that picky. Not even really afraid of cottered cranks anymore. I'm in the Chicago area (North Shore).
Likes For cityjake:
#2261
Mid 80's Nashbar "Terra XT" cro-mo frameset. This was possibly their TOTL frame as it had full Deerhead XT on it.
Measures 17.5" from center of BB to top of seat tube. It's in excellent condition, hardly ridden and really only one scratch on it. Tange headset.
Too small for me, would trade for an equally nice road or mountain frameset in a slightly larger size. Can send more/better pics if interested.
#2262
buy my bikes
Quoted: 520 Post(s)
Liked 433 Times
while I am in no one looking for ANOTHER 26in wheeled trail bike, I do have this Meile I recently regreased and repalced the cables and housings on. Presently I have my studded ice tires on it.... now that our 2 weeks of icy weather are over...
https://www.bikeforums.net/g/album/30555250
I also have an '89 Bianchi I would like to unload. It's presently sitting in my son's detroit appt.
POSSIBLY - I might be able to get my hands on a sized up StumpJumper sitting at my LBS. He's trying to get me to haul it away. It's a little rough. I think it's white. If you're interested, I can see what we can see!
Rattle canned Bianchi - clears only a 2in tire... barely.
#2263
any success in your quest ?
https://www.gringineer.com/blogs/gri...anchi-catalog/
#2264
buy my bikes
Quoted: 520 Post(s)
Liked 433 Times
No takers yet. Not sure I want a frame that's too rough unless it's something special. That Bianchi might make a fun resto project though. What was it originally?
Pic below of the original purchase. I still have the original seat and bars (Celeste).
I replaced the cables with yellow, as shown. I thought I had more photos. I can try to dig up if you are so .... Inclined (see what i did there....)
Besides only clearing a 2.0in tire, I think it's a decently basic frame. Or maybe a basically decent frame - lugged, I think double butted tubing. Cannot recall the flavor of steel. It might be in the catalog you linked, which does show the Incline.
cheers!
#2265
- Bianchi Incline
cheers!
cheers!
#2266
Quoted: 355 Post(s)
Liked 817 Times
Reposting this very good condition aluminum Trek 58cm frame. Replacement steel threadless fork and headset.
Would love to find a decent quality older (26”) mountain bike frame. Medium size, steel or aluminum, 1 1/8” headtube, sloping top tube preferred.
Also have a decent parts stash to trade.
