Need help with pedals/shoes: clipless vs toe clips vs platforms
I currently have a cheap set of regular pedals that can accept toe clips, but I don't use them. I looked at clipless pedals but can't figure out how they work. What are some brands of clipless pedals that I should look at? I do all road cycling, with some gravel/dirt riding but nothing that I'd consider mountain biking.
What kind of shoes do I need, and how do the cleats work?
Are toe clips better/easier to use?
Will I need to buy another pair of shoes just for cycling?
What happens when I am trying to find the side of the clipless pedal that accepts the cleats? Do I just spin the pedal? Wouldn't that slow me down each time I had to start up from a stop?
Buffalo
All depends on what type of clipless pedal you go with.
I would say no.
If you want clipless, yes.
If you have single sided pedals, yes.
Not necessarily.
Hope this helps.
I would say no.
Not necessarily.
Hope this helps.
Buffalo
Missed one.
Depends on what type of clipless and how much you want to spend.
Buffalo
Quoted: 8288 Post(s)
Liked 9,067 Times
If you want to try clipless you will need shoes and pedals. You also have to decide between road or mtb style. Mtb style shoes are easier to walk in and usually the pedals are the same on both sides.
You can spend a little or a lot either way.
You do know that the cleat on the shoe snaps onto the pedal, and you release by twisting your heel out, right?
In my opinion toe clips suck and I was glad when clipless pedals came out.
I just went through this process myself. Here is what I learned:
--You mentioned gravel/dirt. If you are going to be walking around in your cycling shoes, I would highly recommend mountain bike shoes because they will have extra grips to walk on. Road shoes are just the cleats and a heal with a slick sole.
--Some pedals are two sided and some are not. However, single sided are usually weighted so the clip side ends up I believe.
--Major brands I looked at were Shimano, Look, and Speedplay. There are more though, so don't necessarily limit yourself to those three.
I have only mentioned clipless because that is what suited my needs. It really depends on how far you are riding, why you are riding, and what you want to accomplish. Clipless would probably not be the best for short commuting rides.
Bikes: 2010 Specialized Allez
Lots of threads on this. Search is your friend. Another one seems to pop up regularly.
-What are some brands of clipless pedals that I should look at? I do all road cycling, with some gravel/dirt riding but nothing that I'd consider mountain biking.
Shimano's mountain pedals(Shimano SPD) will work well if youre stepping in mud regularly. Theyre double sided so maybe getting in is easier.If not, Shimano SPD-SL(road version) will suit you. I have these and like them a lot. The road version has wider platforms to distribute the pressure more. Less sore feet. Theyre one sided, but weighted so they sit at an angle, Slip the nose of the cleat in, and step down. youre in! to get out, twist your heel outward. you're out.
Other good brands are Look Keo(similar to shimano SPD-SL) and Speedplays(double sided)
-What kind of shoes do I need, and how do the cleats work?
If you buy at a local shop, they'll set you up with everything you need. certain shoes work with certain pedals. There is some compatibility between them, but I'm not the person to ask. Only ever used SPD-SL's, and am very happy with them. I highly suggest buying local. you dont want to spend the money and find out the shoes don't fit! Pretty important to have shoes that fit you perfectly.
-Are toe clips better/easier to use?
Easier at the very first maybe. You'll fall once when you come to a stop with clipless. Sit with your shoulders in a door jamb or against a wall and practice clipping in and out. Clipless will also be easier buying local because they will set up the cleats on the shoes for you(theyre adjustable). It looked too complicated to me at first to get a good position. Not hard though. Clipless are much better overall. They secure your foot, you can effectively use more of the pedal rotation for power, and I found super high cadences(130rpm) feel much better/safer than on toe clips.
-Will I need to buy another pair of shoes just for cycling
Yep. But with the extra vents keeping your feet cool, its definitely worth it. Plus the bike shoes are meant for biking. It can be annoying if you're commuting by bike. I take a backpack with walking shoes and my bike lock if I am commuting. On this note, (this is to the best of my knowledge, various parts may be incorrect) Shimano makes a SPD verson pedal with a platform pedal on the opposite side, so for rides, you use clipless, commuting you can use the platform side with regular shoes.
-What happens when I am trying to find the side of the clipless pedal that accepts the cleats? Do I just spin the pedal? Wouldn't that slow me down each time I had to start up from a stop?
SPD-SL's sit like / so you put the nose of the cleat in the top of the pedal, and step down, no pedal flipping. When you're(i was) new to it, sometimes it might take a try or 2 to get in. After some practice, it'll take just one try. some people can do it without looking. i haven't mastered that yet. With Speedplays or Shimano SPD's i THINK it just sits level. not too sure though. As far as slowing you down, maybe for .5 - 3 seconds, then you can take off like a rocket. With Clipless you can pull up on one pedal, while pressing down on the other when you're standing. It means you can accelerate in a higher gear without problems, which can save you a shift or 2. Once clipped in, you can accelerate just as fast as cars. Well, I can, but light weight is on my side. unless its a lead foot next to you.
Also, climbing out of the saddle is much easier on those super steep grades is easier for the same reason as accelerating.
Clipless is definitely the way to go. Pricey at first, but WELL worth it. My 105 level SPD-SL's and basic shoes ran me about $200. Best upgrade I've done.
Another alternative would be power grip, if you don't want to spend $200 or ride with regular shoes.
I use clipless for my mtb, but for the road bike, I use power grip because I like to walk normally when I am at the break. If you are racing, then definitely clipless is a must.
This is some great feedback!! I took down lots of notes, did some searching, and talked to some of the hardcore bikers at work for more feedback. They recommended I try the SPD pedals/cleats. I ordered the SH56 multi-directional cleats with a pair of Shimano A530 pedals to use with Shimano's M087G shoes.
Quoted: 67 Post(s)
Liked 83 Times
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Rather than ask on a forum. visit a good bike store and ask a salesperson. Try some on and see how the cleats/shoes work and the various pedal systems.
Do you live near a good road bike store?
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
The A530 pedals happen to come with SH51 cleats (standard release), so he won't have to spend that twenty bucks. :-)
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
Another vote for the Shimano dual sided pedals like the A530. I've got them on both my road and my touring bike and love them. I ride with walkable MTB shoes and sometimes will clip out in stop and go traffic and ride the flat side, then flip-n-clip when I get open road. Some people complain about having to flip the pedal, but with a little practice it becomes intuitive. If you miss the flip, big deal, pedal on the flat a few strokes then flip again. It's also nice to be able to jump on the bike and ride comfortably in street shoes for recreational rides with the family, or quick errands.
I talked to some of the road bikers/racers at work and they also prefer the platform/SPD pedals for the same reasons mentioned by Myosmith. One person had the Wellgo versions on his Pinarello, so that was enough to convince me to try that style on my bike.
Yeah, I did get the SH51 with the A530 pedals. I read lots of glowing reviews of the SH56 though, so I thought I'd try them first. The main difference seems to be the tail end of the cleats. The SH56 is shorter, so it probably makes it easier to release.
Do I want to start with the pedal tension set on maximum or minimum?
Shimano said that their M087G MTB shoes would come with the cleat nuts, but a few reviews said that the clea nuts were missing with their shoes. I did not get cleat nuts with my SH56 or with the A530/SH51 box. It seems weird to me that Shimano is nickel and diming by not including cleat nuts even with the cleat replacements.
stole your bike
I like pie
I like pie
The Left Coast, USA
