1972 Schwinn Super Sport Conversion?!
Hi all! Need your opinion. I picked up a 1972 Super Sport (Kool Lemon) from Facebook for $75 earlier this year. Original brooks saddle, cleaned it up. New bar tape. New tires. Basics.
Have the itch for a project and have been pondering options! Found another bike today that could be a source for parts. Here's the details:
- Throne TrackLord Bike Frame (too small for me)
- Velocity 700c wheels
- Miche Crankset (Single Speed)
- FSA Stem
- FSA Handlebars
- Look Pedals (Would resell)
- Adamo Seat (Would resell)
- Profile Design Tri Bars (Would Resell)
Could I simply put on the 700c wheels, adjust original brakes, use TruV Bottom Bracket, put on the Single Speed Miche Crankset and call it a day?
I guess if the brakes didn't fit I could swap out the handlebars, brakes etc as well.
I think there's enough here to resell and recoup the new bike cost ($200).
I know this would lighten up the Super Sport quite a bit. Worth the trouble?
Goals for this bike are something fun to ride for fitness and family rides. Would be throwing a baby on the back from time to time.
Thanks for the input!
- FSA Stem
- FSA Handlebars
- FSA Stem
- FSA Handlebars
- FSA Stem
- FSA Handlebars
Quoted: 1062 Post(s)
Liked 665 Times
Does the Super Sport have a one piece crank? That might affect your options unless you got an adapter for a modern bottom bracket.
I recently got a 1972 Varsity frame, and decided to wear the one piece crank with pride.
- The wheels should fit, but if the originals were 27", your brakes may not reach.
- Track hubs are 120mm wide, measured between the outside of the lock nuts. Your existing hubs are either 126 or 130mm. The rear dropouts will be spaced the same, so you would need to either add spacers to the new wheel's axle or re-space the frame.
- The Schwinn probably takes an English-threaded bottom bracket, so if that's what your bottom bracket is, it should fit. The crankarms and chainring may or not may not clear the chainstay, though.
Sheldon Brown's site is the bible for this kind of thing. He has a good page about fixed gear conversions here and the rest of the site is full of useful info, too.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
^^^ A minor correction, rear dropout spacing for multi-speed road bikes in 1972 was 120mm, which is the same as track bikes. The dropouts were also semi-horizontal, making them ideal for a single speed or fixed gear conversion. As to the wheels and cranks, definitely 27” and one-piece (Ashtabula).
