wide feet, pedal extenders or wider pedals (platform)
Old 02-13-17, 09:24 AM
rumrunn6
rumrunn6's Avatar
Quoted: 3719 Post(s)
Liked 837 Times in 583 Posts
I use platform pedals w mini toe clips (no straps). the pedals do not extend far enough outward to support my entire foot width. any thoughts on pedal extenders vs wider platform pedals? want to continue to use the mini clips so wider pedals w/o holes to attach them won't work for me. been thinking about it now cuz I have a size 13 shoe & lately been wearing a roomy walking shoe w rubber covers so the shoe is a bit wider. here's a pic of one set of pedals to provide an idea of much wider I might need
rumrunn6 is offline
Old 02-13-17, 01:16 PM
cny-bikeman
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 480 Post(s)
I don't have a particular product in mind that would fill the bill, but how about using the clip/reflector mounting holes to attach a longer piece of metal, serrated on the working edge, to each pedal side? They could be mounted slightly outboard so as to avoid rubbing on the crank. Know anyone who works in a metal shop? Of course welding the pieces on is a possibility as well.
There's no such thing as a routine repair.
Don't tell me what "should" be - either it is, it isn't, or do something about it.
If you think I'm being blunt take it as a compliment - if I thought you were too weak to handle the truth or a strong opinion I would not bother.
Please respect others by taking the time to post clearly so we can answer quickly. All lowercase and multiple typos makes for a hard read. Thanks!
cny-bikeman is offline
Old 02-13-17, 02:17 PM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 383 Post(s)
I use these on all my bikes:
https://www.amazon.com/Bicycle-Pedal.../dp/B00W6E9YAA
They are available in 21mm and 27.5mm lengths, with 9/16" threading on both ends.
They also have a version for using 9/16" pedals in 1/2" threaded cranks.
nfmisso is offline
Old 02-13-17, 02:46 PM
rumrunn6
rumrunn6's Avatar
thank you. I ordered a set last night to try out. pedals are so expensive. but wondering what the 'best practice' should be. glad to know these are working just fine
rumrunn6 is offline
Old 02-13-17, 03:45 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2135 Post(s)
Liked 492 Times in 344 Posts
My wife has bad hip joints and needed wider pedal spacing. Extenders work fine for her.
JohnDThompson is offline
Old 02-13-17, 05:20 PM
cny-bikeman
Mechanic/Tourist
Quoted: 480 Post(s)
Actually, as the OP's complaint is partly the width of the pedal itself, a pedal such as that pictured above may be a good alternative.
Old 02-13-17, 05:34 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 20 Post(s)
Liked 528 Times in 395 Posts
I would not call those "platform" pedals, but perhaps bear-traps. The vertical metal all around will surely cut into your shoes/feet, while an actual platform would disperse foot pressure.
I would consider these pedal extenders, they're hollow with a hex opening at the back, made in america, prettier, and about the same price (perhaps cheaper, depending on amazon shipping).
I would also get some real platform pedals, I am quite happy with Wellgo MG-1 and MG-2, I got a pair of each from eBay for about $20/ea (although currently it looks like their going for more like $40)
PS is that shoe actually called "Tingley"? That must be how your feet end up feeling after a short ride in that setup!
RubeRad is offline
Old 02-13-17, 06:58 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1063 Post(s)
Liked 434 Times in 319 Posts
They are actually made by a company called "Tingley Rubber" which is near my old home in NJ. I always thought that they should be in the sex toy business with a name like that. Home Page Slideshow | Tingley®
dsbrantjr is offline
Old 02-13-17, 07:46 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2918 Post(s)
Liked 361 Times in 280 Posts
Actually, their products are quite de rigueur in a number of clubs on the lower east side.
Sy Reene is offline
Old 02-14-17, 08:39 AM
rumrunn6
rumrunn6's Avatar
I would consider pedal extenders and also get some real platform pedals
so pedal extenders AND platform pedals?
rumrunn6 is offline
Old 02-14-17, 09:19 AM
hankaye
Bikes: '95 Specilized StumpjumperFS
Quoted: 81 Post(s)
rumrunn6, Howdy;
Actually, after looking at the photo you posted with your boot bottom on the peddle
it does not appear to be much wider then the peddle itself. Once you consider that 13
is a length measurement, it's the letters that designate width. Once you get to the 3E
designation you start to find problems getting something that looks nice and fits comfortably.
I know as I have 4E feet in the same 13 length. As a reference, I can overlap the edges
of a 9" square floor tile, sideways, when I put my feet together with just my socks on.
As is, I get along just fine with "Normal" stock peddles.
When I saw your photo I saw that there is only a minor amount of overlap. That can
be normal as there is a border around the outside of the shoe where there is no foot.
If you were to place your sock covered foot on top of the peddle, does your actual foot
overlap the peddle? If not then I wouldn't worry about it.
hank
hankaye is offline
Old 02-14-17, 10:51 AM
rumrunn6
rumrunn6's Avatar
Originally Posted by hankaye View Post
If you were to place your sock covered foot on top of the peddle, does your actual foot overlap the peddle? If not then I wouldn't worry about it
hmmm, ok thanks for that, I'll check that out
rumrunn6 is offline
Old 02-14-17, 02:49 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 20 Post(s)
Well, platform pedals for sure to distribute pedal pressure evenly around the foot. Extenders only if you have out-turned duckfeet like me, and your heels are always hitting the cranks or the chainstays (or you twist your feet out to be like normal people, and get IT band pain)
RubeRad is offline
Old 02-14-17, 03:21 PM
rumrunn6
rumrunn6's Avatar
I don't have turned out feet but I do sometimes (rarely) have heel strike. this winter my left knee has been acting up. haven't fully diagnosed it yet
rumrunn6 is offline
Old 02-14-17, 05:20 PM
bikeman715
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
Quoted: 85 Post(s)
You can try Bicycle Pedals Mks Sylvan Touring 9/16 . they are a little wider and longer than the pedals you have in your photo . Something like these , Bicycle Pedals Mks Sylvan Touring 9/16 | eBay
bikeman715 is offline
Old 02-14-17, 09:26 PM
sunburst
sunburst's Avatar
Bikes: Giant, Trek, 6x Peugeots, Specialized, Nishiki, bike friday
Quoted: 118 Post(s)
Liked 15 Times in 12 Posts
My favorite pedal. I've got two pairs and need to buy two more for my current builds. I match these with large plastic Zefal half-clips. These work perfectly with my old Shimano Mtn bike shoes. Now all I need is a NOS pair of these shoes as mine are 15 years old.
sunburst is offline
Old 02-14-17, 09:33 PM
bikeman715
bikeman715's Avatar
Quoted: 85 Post(s)
My too . I have them on all of my bikes .
Old 02-14-17, 09:49 PM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 1,190 Times in 620 Posts
Black ops pedals are another option:
wgscott is offline
Old 02-14-17, 11:37 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2351 Post(s)
Liked 10 Times in 10 Posts
rumrunn6, Howdy;
hank
Hank....you are killing me here......
ped·dle
ˈpedl/
verb
verb: peddle; 3rd person present: peddles; past tense: peddled; past participle: peddled; gerund or present participle: peddling
try to sell (something, especially small goods) by going from house to house or place to place.
"he peddled art and printing materials around the country"
synonyms:sell, sell from door to door, hawk, tout, vend; Moretrade (in), deal in, traffic in
"they are peddling water filters"
  • sell (an illegal drug or stolen item).
    "certain youths who were involved in theft and drug peddling"
  • derogatory
    promote (an idea or view) persistently or widely.
    "he criticized his fellow candidate for peddling risky ideas"
ped·al1
ˈpedl/
noun
noun: pedal; plural noun: pedals
  1. 1.
    each of a pair of foot-operated levers used for powering a bicycle or other vehicle propelled by the legs.
  2. 2.
    a foot-operated throttle, brake, or clutch control in a motor vehicle.
SquidPuppet is offline
Old 02-14-17, 11:40 PM
SquidPuppet
Another vote for MKS Sylvan Touring. I wear size 13 shoes and these work very well. Grip is really good to.
Old 02-15-17, 12:38 AM
ColonelSanders
ColonelSanders's Avatar
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1279 Post(s)
Liked 31 Times in 28 Posts
Where dem toe clips gonna go?
ColonelSanders is offline
Old 02-15-17, 03:00 AM
AdvXtrm
AdvXtrm's Avatar
Bikes: 2016 Novara - Safari
Quoted: 384 Post(s)
These are my choice, and I see no need for any toe-clips the way these things stick to your shoes.
VP Components VP-Vice Pedals
AdvXtrm is offline
Old 02-15-17, 08:53 AM
rumrunn6
rumrunn6's Avatar
birthday coming up. worth a try. the item shows as 1 x 5 x 10 inches but how wide is the part your shoe sits on?
rumrunn6 is offline
Old 02-15-17, 09:04 AM
rumrunn6
rumrunn6's Avatar
nice looking too. still need to measure my current pedals, but how wide is the part your shoe sits on?
rumrunn6 is offline
Old 02-15-17, 09:06 AM
rumrunn6
rumrunn6's Avatar
what does the part your shoe sits on measure?
rumrunn6 is offline
