Pace to Power or HR? Hotter Temperatures
Old 05-11-18, 09:44 AM
RFEngineer
Bikes: 2016 Hong Fu Gravel Bike, 2015 Motobecane Turino Team
Quoted: 74 Post(s)
I have a power meter, but I probably don't use it, or train with it, properly. It's more of an indicator of how hard I pushed on a ride, at this point. I have noticed my times suffering in the last few weeks due to it getting hotter outside. It seems to me that HR is a better indicator of how hard I can push myself, because the heat has such a great effect on how much power I can sustain. Is this typical, or do I just need to acclimate to the heat? Should I really pace myself to power? This is on a long, sustained climb: 30-40 minutes. Thanks!
RFEngineer is offline
Old 05-11-18, 10:32 AM
noodle soup
noodle soup's Avatar
Quoted: 4131 Post(s)
Liked 1,140 Times in 649 Posts
In hot weather(Phoenix Summers) HR is better to use as a guide. I'm sure someone will argue this, but they will be wrong.
noodle soup is offline
Old 05-11-18, 10:35 AM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Bikes: OPEN new U.P. Di2
Quoted: 981 Post(s)
Liked 133 Times in 88 Posts
I pace to Power UNLESS my heart rate is higher than usual given my power and cadence numbers. If my HR is elevated (or I'm having trouble making normal power at a given HR), I drink a lot more fluids and pace based on HR until / unless it returns to normal.
FlashBazbo is offline
Old 05-11-18, 11:45 AM
woodcraft
woodcraft's Avatar
Quoted: 1385 Post(s)
Liked 397 Times in 241 Posts
IME, power not that different, but HR substantially higher in hot weather.
woodcraft is offline
Old 05-11-18, 12:09 PM
caloso
caloso's Avatar
Quoted: 2205 Post(s)
Liked 848 Times in 445 Posts
I pace to power and feel, regardless of temperature. And yes you need to acclimate.
caloso is offline
Old 05-11-18, 12:36 PM
redlude97
Quoted: 1924 Post(s)
Liked 177 Times in 129 Posts
HR being elevated at higher temps is usually due to dehydration affecting HR and not the temp itself necessarily. So acclimate and carry enough water
redlude97 is offline
Old 05-11-18, 12:39 PM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1102 Post(s)
Liked 56 Times in 41 Posts
Pace to power! However, as some have noted, your HR doesn't not exactly correspond to your power output in all conditions / at all times, so modulate what you're doing.
Tweak as necessary, says I.
TrojanHorse is offline
Old 05-11-18, 07:46 PM
woodcraft
woodcraft's Avatar
I think of it as pumping more blood to dilated surface blood vessels to cool the body.
Old 05-11-18, 09:38 PM
robbyville
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 307 Post(s)
Liked 80 Times in 55 Posts
I live in Palm Desert CA, during the summers we ride at 6am and it’s generally already close to 90 degrees. I still try to pace to my power, but the reality is regardless of hydration that my heart will still often dictate my ride. But I do plan for my workout to be based on power...
robbyville is offline
Old 05-11-18, 10:08 PM
gregf83
Quoted: 1049 Post(s)
Liked 167 Times in 100 Posts
Perhaps for you but for me my HR is higher at the same power levels in the heat. I can sustain similar power but higher HR when it's hot.
Going up a long hill I mostly just go by RPE, particularly in the 2nd half.
gregf83 is offline
Old 05-11-18, 10:41 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4582 Post(s)
Liked 1,166 Times in 697 Posts
I note my HR usually elevated around 10bpm if temps are above 90º. HR recovery also slower, and resting HR slightly elevated. I still pace to power, but watch HR as recovery rate is my main check for hydration level.
DrIsotope is offline
Old 05-12-18, 01:24 AM
colombo357
colombo357's Avatar
Quoted: 117 Post(s)
Liked 20 Times in 9 Posts
Always pace to power because your HR fluctuation is neither predictable nor linear with temperature changes.
You should know your FTP. Dial it back accordingly on hot days, how much exactly TBD through experimentation. It should be proportionally less to your HR increase.
colombo357 is offline
Old 05-12-18, 04:52 PM
ddub
Quoted: 99 Post(s)
HR. Human Resources? JK. Power for me. HR is not really a reliable indicator of your efforts.
ddub is offline
Old 05-13-18, 06:31 PM
macca33
macca33's Avatar
Bikes: 2017 Ridley Noah SL - Candy Apple DA9000, 2011 CAAD10 Berzerker Ult6800, 2013 FOCUS Mares CX Ult6800
Quoted: 26 Post(s)
I'd say use your power data, but listen to your HR data, ie, if your HR is noticeably higher than 'normal' for any given power level/effort, then adjust your ride accordingly. I generally have a good idea when I'm crook or fatigued, as my HR will be high (relatively) for the power levels I'm producing.
Remember to drink plenty too!
cheers
macca33 is offline
Old 05-13-18, 11:11 PM
gurk700
Quoted: 151 Post(s)
Liked 8 Times in 5 Posts
Power meter = What you are doing
Heart rate monitor = How your body is responding to what you are doing
- You can push the exact same power in 2 different days and your body could respond very differently because you're flatter than usual, you are sleep deprived, you feel friggin' amazing, you are overcaffeinated, you got up from the wrong side of bed.
- Your heart rate could be elevated and you might think you are pushing yourself too hard when you aren't
Basically use both tools for what they are. HR can't provide you with the info PM can and PM can't provide you with the info what HR can.
If you absolutely have one tool, have the PM cause you can somewhat gauge how hard your heart is working. But have both tools. If you can afford a PM you can surely afford a cheap HR monitor.
gurk700 is offline
Old 05-13-18, 11:19 PM
gurk700
Quoted: 151 Post(s)
Also a note, no matter what people say, if you wanna train seriously, you NEED a PM.
Intervals with HR meter is a joke. You WILL get better the more hard rides you do but you WILL hit a wall at some point and you need data to train in specific areas of what you lack.
If you're a beginner, any kind of training will make you better. Don't let that lead you to believe PM is useless.
gurk700 is offline
Old 05-14-18, 07:22 AM
asgelle
Quoted: 541 Post(s)
Liked 95 Times in 64 Posts
Plus myriad other internal and external factors which may or may not affect your ability to sustain a given effort.
asgelle is offline
Old 05-14-18, 08:09 AM
OBoile
Quoted: 915 Post(s)
Liked 223 Times in 132 Posts
That's going a bit far IMO. I'm fairly certain all the pros from previous generations were training seriously despite the lack of PMs.
OBoile is offline
Old 05-14-18, 11:59 AM
gurk700
Quoted: 151 Post(s)
Yes, but they were limited. Maybe I worded it wrong but I guarantee you anyone on earth will go further with a PM than their full potential without one. If past generations used a PM, they would've gone further too. All relative.
You simply can't gauge your effort accurately without one.
That said not eveyone cares either and that's absolutely fine. You can be a strong rider who never checks PM. If you're not looking into getting even better or competing, there's no need for one.
gurk700 is offline
Old 05-14-18, 12:06 PM
noodle soup
Where is @Doge when we need him?
Old 05-14-18, 12:25 PM
OBoile
Quoted: 915 Post(s)
I agree with all of this.
I would say it's more about measuring output accurately. Effort is largely self judged.
I'd say you still don't need one... but, without one, you probably won't be as good as you could be.
OBoile is offline
Old 05-14-18, 12:28 PM
OBoile
Quoted: 915 Post(s)
Lift weights! Here's the next TT world champ:
Truly the Mountain that Rides!
OBoile is offline
nemeseri
"The 33"-Road Bike Racing
17
11-28-15 04:30 PM
greenlight149
Road Cycling
208
07-10-15 03:03 PM
daviddavieboy
13
06-04-14 04:23 PM
eugenek
Training & Nutrition
10
05-13-12 09:48 AM
