My power meter can give me torque information...what is that telling me?
Old 05-14-18, 10:25 AM
cthenn
Bikes: 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, 2016 Devinci Hatchet, Some BikesDirect MTB I never ride.
Quoted: 569 Post(s)
Liked 65 Times in 37 Posts
When I upgraded my computer to a Wahoo, one of the power metrics I could display is "torque". Does anyone know what one can learn from that value? There are several variations of the metric, the one I'm using is "last lap torque", but I really don't know what I'm looking at when I see the value. I think my plan is to learn through osmosis, as I try to correlate the value to how hard I pushed on a given lap, how I felt, etc. How is torque different or comparable to power numbers? Seems to be more or less correlated, the higher the wattage, the higher the torque, more or less, but I don't know how that metric might be useful in comparison to lap power. The values are usually in the low 2 digit numbers (20s-30s) for an effort in my Z4 range, but don't even know the units lol! 20 or 30 what, and is that a lap average number? I understand the definition of the word, and obviously the more power you put into the pedals, the higher the torque value will be, but I don't quite understand how or what to take from a given effort looking at that value vs just looking at power.
cthenn is offline
Old 05-14-18, 11:11 AM
tomato coupe
Quoted: 567 Post(s)
Liked 356 Times in 182 Posts
Simple, qualitative explanation: your power is your torque multiplied by your cadence.
tomato coupe is offline
Old 05-14-18, 11:30 AM
pesty
Master Sarcaster
pesty's Avatar
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
Basically, it's how effective you're pedal stroke is at delivering power all the way arround. Higher is better, I want to say that 30% and higher is pretty good. If you want a really detailed write up, look here: https://www.cyclinganalytics.com/blo...dal-smoothness
pesty is offline
Old 05-14-18, 11:41 AM
tomato coupe
Quoted: 567 Post(s)
The OP is asking about torque -- what you referenced is completely different.
Old 05-14-18, 12:03 PM
gurk700
Quoted: 151 Post(s)
Liked 8 Times in 5 Posts
/thread
gurk700 is offline
Old 05-14-18, 12:33 PM
RChung
Quoted: 368 Post(s)
Liked 184 Times in 78 Posts
This is true for most power meters. For Power Tap hubs, power is measured at the rear hub so power is (hub) torque multiplied by the wheel's rotation speed.
Knowing the torque can be useful for 1) checking the accuracy of your power meter, or for diagnosing problems; or 2) examining "QA" (aka pedal force and pedal speed analysis). Most riders never look at QA analyses, nor do they ever check the accuracy of their PMs, so most riders can just ignore the torque data field.
I do periodically check the accuracy of my PM, so I do like being able to get the torque value. Once I diagnosed a problem with a power meter by noticing that the product of torque and cadence (and a conversion constant) didn't quite equal the power; it turns out the cadence measurement was off.
RChung is offline
Old 05-14-18, 01:50 PM
tomato coupe
Quoted: 567 Post(s)
​​​​​​​That's why I emphasized qualitative -- my purpose was to give the OP a sense of how torque and power are related, without going into details.
Old 05-14-18, 02:08 PM
Racing Dan
Racing Dan's Avatar
Quoted: 891 Post(s)
Liked 65 Times in 53 Posts
You can develop a given power, say 200w, at any RPM you like. Just "mash" the gears more or less, dependig on what gear you have chosen. The touque value is a measure of how much you mash the gears. For the same power, RPM will go up and torque go down if you choose a light geat and RPM will go down and torque up if you choose a heavy gear.
Racing Dan is offline
Old 05-15-18, 09:38 AM
cthenn
Quoted: 569 Post(s)
OK, this dumbs it down enough to my level . On a short steep hill I did 300w at over 40 "torque units" while out of the saddle mashing at probably 65-70rpm whereas on other 300w efforts it can be closer to 30 if I try to spin it more. I'll probably keep the metric for a while see if it ends up having any usefulness for me.
So, what are the "torque units" shown?
cthenn is offline
Old 05-15-18, 09:57 AM
redlude97
Quoted: 1924 Post(s)
Liked 177 Times in 129 Posts
Are you measuring HR as well? If not you should be for it to be useful. See how your HR varies with the torque/cadence difference for the same avg power.
redlude97 is offline
Old 05-15-18, 10:56 AM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '05 Novara Big Buzz, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally
Quoted: 1046 Post(s)
Liked 28 Times in 15 Posts
Torque units displayed is Nm, or Newton meters.
If you're using analysis software that displays Torque Effectiveness, you might find the TE percentage useful in improving your pedaling technique. For example, a 75% TE would indicate that 75% of applied torque is going towards moving the bike, while the remaining 25% is you working against yourself by keeping pedal pressure on the upstroke. Obviously, you'd want to see as high a TE percentage as possible.
chaadster is offline
Old 05-15-18, 11:28 AM
Racing Dan
Racing Dan's Avatar
Quoted: 891 Post(s)
There are several different ways to express torque. Pound foot, lbs ft, is common in the US, but if you set it to metric then Im betting it will display SI units. That is Newton metre, Nm. If you can make it show power, torque and RPM all at once, Im betting you quickly learn how they relate.
Old 05-15-18, 02:01 PM
RChung
Quoted: 368 Post(s)
It depends on your power meter, and whether your head unit is set to display in SI (metric) or Imperial units. The metric unit is Nm, the Imperial unit is foot-lbs.
You don't need HR for torque information to be useful.
Here's a plot that shows cadence and crank torque for the same guy in three different types of races. The plot is from here.
RChung is offline
Old 05-15-18, 02:58 PM
Abe_Froman
Abe_Froman's Avatar
Bikes: Marin Four Corners, 1960's Schwinn Racer in middle of restoration, mid 70s Motobecane Grand Touring, various other heaps.
Quoted: 9346 Post(s)
Liked 53 Times in 47 Posts
Probably foot-pounds, which is a pretty simple unit. It's the amount of force exerted on a bolt by a 1 foot long wrench with a pound of weight sitting on the end of it.
Abe_Froman is offline
Old 05-16-18, 05:19 PM
cthenn
Quoted: 569 Post(s)
Cool, brilliant info in here, thanks! I'm gonna look more into torque effectiveness, does that require a L/R PM, because mine is left-only. I think I've experimented with that and pedal smoothness on the Wahoo data fields, and nothing shows up...
cthenn is offline
Old 05-16-18, 06:31 PM
Dean V
Quoted: 902 Post(s)
Liked 96 Times in 64 Posts
I don't recall anyone using Horsepower as a unit for power measurement for cycling, so why would there be a readout of ft/lb?
It would be like your car speedo reading out your speed in mph and distance in kms at the same time.
Dean V is offline
Racing Dan
Electric Bikes
14
09-11-18 01:11 PM
Damien09
Road Cycling
5
03-23-16 01:41 PM
torque cyclist
Road Cycling
111
08-14-14 05:22 PM
mcafiero
Road Cycling
8
09-28-11 05:35 PM
