Tips on increasing speed on hybrid
Old 04-11-19, 08:46 PM
grayslaker
Quoted: 16 Post(s)
Got back to cycling a year ago after 20 plus years. Riding a flat bar hybrid. FX Sport 4
Often my speed average around 12miles per hour on 30+ mile ride. Need tips to increase speed by another 3 or 4 miles. Not looking to race. But looking to ride at 15-16mph consistently
No suggestions to convert to drop bar please Ain't doing it. Got a decent high end flatbar that I can afford. Happy with comfort and capable of higher speed. Limitation mostly on me. Have decent quality 32m 700C tire. Weekend warrior for the past 1 year. Having tough time to average above 12mph mark
grayslaker is offline
Old 04-11-19, 09:15 PM
Skipjacks
Skipjacks's Avatar
Quoted: 1001 Post(s)
Liked 223 Times in 148 Posts
The most effective way to increase your speeds is to work on your strength.
Build up leg muscles by riding more and pushing harder. The muscles will come. The speed will follow.
Skipjacks is offline
Old 04-11-19, 09:25 PM
SlinkyWizard
Bikes: 2016 Trek DS 8.5, Giant Fastroad Comax 1 2018
Quoted: 42 Post(s)
Liked 12 Times in 3 Posts
Clipless pedals and shoes?
SlinkyWizard is offline
Old 04-11-19, 09:58 PM
ColonelSanders
ColonelSanders's Avatar
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1279 Post(s)
Liked 31 Times in 28 Posts
I would give these tyres ago, probably the "hybrid" tyre with less rolling resistance than any other.
Schwalbe Marathon Almotion Evolution Folding Tire - 28x1.50 Inches | 700x38C - Black-Reflex
ColonelSanders is offline
Old 04-12-19, 12:52 AM
KLiNCK
Optically Corrected
KLiNCK's Avatar
Bikes: 2012 Specialized Sirrus , 2012 Specialized Roubaix Comp
Quoted: 94 Post(s)
Liked 35 Times in 17 Posts
The easiest, most cost-effective, performance "boost" is often realized by reducing rotating mass ... installing lighter tires can make a noticeable difference.
I'd recommend a pair of Continental GP 4000s2, in the 28mm size ...awesome tire.
KLiNCK is offline
Old 04-12-19, 03:52 AM
DorkDisk
Quoted: 249 Post(s)
Liked 198 Times in 120 Posts
Work on your spin. Min 90 rpm should be effortless and sustainable for the entire ride.
DorkDisk is offline
Old 04-12-19, 07:01 AM
grayslaker
Quoted: 16 Post(s)
Thanks all for the suggestions. First thing I intend to do is install a bike computer and see if I continuously maintain 90rpm. If not will start making investments one after the other on tires and SPD to help me achieve it.
Currently I have Bontrager H5 hardcase ultimate 32mm. Little bit on heavier side. Love its puncture protection and comfort. 25% of my ride is on packed gravels and crushed limestone. So 32 is minimum I need. H5 hardcase does appear to have some rolling resistance for its size though. Appreciate recommodations that would also help me with both road and forest preserve trails
https://www.trekbikes.com/us/en_US/equipment/cycling-components/bike-tires/hybrid-bike-tires/bontrager-h5-hard-case-ultimate-hybrid-tire/p/09389/
Old 04-12-19, 07:18 AM
Helderberg
Helderberg's Avatar
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 149 Post(s)
Liked 98 Times in 43 Posts
Once you get the computer see what your speed is at the 90 rpm on a flat. That will tell you what your speed is at that rpm with your bikes gearing. Once you know what your speed is with your gearing. then you can consider if changing the chainring to a larger gear or the small gear on your rear cogs. I was surprised how much a 50 compared to a 48 in the large chainring made between my two bikes with the same 11 tooth rear cog. Just another idea but listen to the advice given in the previous posts first as I do not have the experience that so many others here have.
Frank.
Helderberg is offline
Old 04-12-19, 07:23 AM
daoswald
Quoted: 207 Post(s)
Liked 70 Times in 44 Posts
Tires, strength, aerodynamic riding position.
Slick tires will roll faster than treaded if all other things are equal. A stronger, more fit person will put out more power over the course of the ride. And aerodynamic position will further reduce the power lost to drag.
daoswald is offline
Old 04-12-19, 07:42 AM
finch204
Bikes: 2013 Trek 4.7 Flatbar Madone, 2018 Giant Roam 2
Quoted: 102 Post(s)
I was just reading about wind resistance and tire rolling resistance a few days ago. The conclusion was, at less than 10mph and less, the tire's rolling resistance matters. When riding at speeds above 10mph, rolling resistance is no longer an issue as it is the wind resistance that is the biggest thing slowing you down. That tells me that the only way to sustain a faster speed above 10mph, is to have stronger legs and to find a way to be more aero on a flat bar bike. Both of those have already been suggested by previous posters. Maybe switch your tires to 32mm Schwable G-One speed and slam your stem so you can get lower and more aero.
finch204 is offline
Old 04-12-19, 09:44 AM
leob1
Quoted: 247 Post(s)
Liked 48 Times in 31 Posts
Ride more.
leob1 is offline
Old 04-12-19, 01:49 PM
hokiefyd
hokiefyd's Avatar
Bikes: 2018 Giant Roam 2, 2018 Redline Zander, 1997 Trek 750, 1970 Peugeot UO-18
Quoted: 981 Post(s)
Liked 211 Times in 169 Posts
I think a better way for the article to state that would be that, above 10 mph (or whatever speed they claim), rolling resistance is not longer the predominant factor. I wouldn't say that it's no longer a factor...as it will continue to be a drag on your speed, and probably with an increasing amount as your speed increases. Rolling resistance's increase is linear, though -- wind resistance increases with the square of speed, so its influence ramps up much faster as speed rises.
hokiefyd is offline
Likes For hokiefyd:
Old 04-12-19, 02:20 PM
finch204
Quoted: 102 Post(s)
Correct, I was trying to paraphrase but ended up leaving details like that.
I searched for the article again and found it:
https://www.exploratorium.edu/cyclin...dynamics1.html
finch204 is offline
Old 04-12-19, 02:34 PM
Sal Bandini
Bikes: 2017 Sirrus Sport
Quoted: 402 Post(s)
You realize that the current speed to desired speed is 25%-33% improvement, right? I wish it were that easy to just change components and/or spin at 90 to get that increase. Your best way to get towards that goal is to reduce weight (yours) and just bike more to get your power up.
Sal Bandini is offline
Old 04-12-19, 04:16 PM
badger1
badger1's Avatar
Quoted: 1123 Post(s)
Liked 226 Times in 143 Posts
How often do you ride; how far?
The difference from 12 mph 'average' to 15/16 mph 'average' hasn't anything to do with 'equipment', within reasonable limits. Your bike is 'within reasonable limits' -- a perfectly good flat-bar road bike.
That difference simply comes down to cycling fitness, and cycling fitness can be acquired by, and only by ... riding ... lots. Assuming you are riding solo, and not in a group, then you need to structure things a little: do long rides at a comfortable pace, and then figure out how to 'up' your tempo. If you can sustain 60 rpm cadence in a given gear/gears over, say, 30 miles, then set yourself a goal to up the cadence to 70 rpm in the same gears; then to 90. That alone will increase 'average speed'.
In additon to that, set aside a day or two a week to do intervals. These are horrifying, but they work! Go out for, say, just an hour: ride for 10 minutes at an 'easy' pace/cadence, then go into a hard gear and pedal as fast as you can for one or two minutes. You'll feel sick. Back off -- easy pace for 10 minutes or until you don't feel sick; repeat for up to an hour, then go home and try to recover.
Before you know it, that 'average speed' will be on the up. If your rides involve hills, same thing: set aside a day or two for 'hill repeats': ride up a shortish hill as fast/hard as you can, coast back down. Repeat.
Caveat: if like many of us you are overweight, or have other health issues, make d__n sure you talk this over with your physician.
But at the end of the day, getting 'faster' on the bike simply comes down to putting in the work, or in sporting terms, the 'training'. Outside of trivial increments, you can't 'buy' speed on a bike.
badger1 is online now
Likes For badger1:
Old 04-12-19, 06:24 PM
Beavis5220
Bikes: BMC Alpenchallenge
Quoted: 7 Post(s)
This is your first step.....and pump them to 110psi. Also...Ergon GP3's......
Beavis5220 is offline
Old 04-13-19, 03:49 AM
DorkDisk
Quoted: 249 Post(s)
Old racer joke, "I would've won if I had just pushed a bigger gear faster."
DorkDisk is offline
Old 04-13-19, 07:22 AM
u235
u235's Avatar
Quoted: 394 Post(s)
Liked 79 Times in 56 Posts
The difference between 12 and 15 is a HUGE over 30 miles. Set goal for 13 first and push harder on your rides. If you hit a plateau, you'll need to provide someone far more info and stats for the next steps.
u235 is offline
Likes For u235:
Old 04-17-19, 10:16 AM
Korina
Happy banana slug
Korina's Avatar
Bikes: 1992 Specialized Rockhopper Sport, 2016 Giant Liv Rove Lite, 1995 Trek Singletrack 930, 1994 Trek Multitrack 750
Quoted: 643 Post(s)
Liked 297 Times in 210 Posts
Yep, ride harder and longer. I ride one gear up from easy, and it built my legs up amazingly; I can ride up hills that I used to have to do in stages. Ride as often as you can, and remember to enjoy the ride.
Korina is offline
Old 04-18-19, 12:32 AM
canklecat
canklecat's Avatar
Quoted: 3540 Post(s)
Liked 1,035 Times in 694 Posts
Easiest free speed is to get more aero. Lower position. Snug fitting, less flappy clothing.
Then tires. The size -- 700x32 -- doesn't matter much if the tires are sluggish. I recently switched my hybrid from Continental Sport Contact 2 700x32 back to Conti Speed Rides (700x42), and picked up another 1-2 mph just from the tire switch. The specs seem similar -- similar weight, etc -- but the Sport Contact 2 tires felt harsh at full pressure and sluggish at a comfortable pressure. The Speed Rides are better tires overall, faster, better grip, more comfortable and more versatile. I use heavy, puncture resistant tires on my errand bike/comfort hybrid, but I don't want them on my fun bikes.
That's good for a little more speed without major modifications or switching to a road bike.
I also switched my hybrid over the past few years from the original flat bars to riser and now albatross swept bars. The albatross bars are comfortable and more versatile, with upright position on the grips and more aero in the forward curved part of the bar. That's my casual and group ride bike. Over the usual 20-50 mile rides I average 12-14 mph.
Better physical conditioning can help a bit. But the faster we go, the more wind resistance becomes a greater factor. Beyond around 14 mph it takes a lot more energy just to overcome wind resistance, whether lack of aero positioning or headwinds. Makes more difference than bike weight, rotating wheel/tire weight or the type of tire. That's the advantage to a drop bar road bike. But I don't always want to ride my road bikes so my compromise was albatross bars on the hybrid.
canklecat is offline
Old 04-18-19, 12:57 AM
a1penguin
a1penguin's Avatar
Quoted: 130 Post(s)
Liked 8 Times in 6 Posts
Originally Posted by badger1 View Post
How often do you ride; how far?....
This! How many miles a week are you riding? For a long time I was commuting and doing 60 miles per week with 9 miles each way to and from work. Not very fit. I started doing 20 mile rides on the weekends and one day during the week I detoured coming home from work for another 20 miles. I mixed in some elevation (I suck at hills for sure). This improved my fitness and I started doing 40 mile rides and then longer. I try to ride a metric century (100 km = 62 miles) every month. Riding more is the key. Do intervals. Ride longer rides. In six months, you'll notice a big difference. A road bike with drop bars will be more aerodynamic riding position, wheels will probably be lighter and it might even make a noticeable difference is average speed.
a1penguin is offline
Old 04-18-19, 01:09 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1908 Post(s)
Liked 479 Times in 331 Posts
When I was trying to bump up my fitness I tried really hard to improve my average speed on the bike computer, and my time around a 12 mile lake loop. I suppose today I’d be using a power meter. Health issues slowed me down and I quit “training” per se.
I was always improving by a few seconds at a time but the only sudden quantum leap like you desire came with a road bike... a very racy one.
Darth Lefty is offline
Old 04-18-19, 11:12 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7131 Post(s)
Liked 625 Times in 419 Posts
Cool Air resistance of your chest, sitting up is part of the problem.
Part of Mr Merckx, setting his Hour Record , was location .. lower air density of Mexico City , at altitude.
Inverse; a Friend's mother was on Bottled Oxygen As many with Smoking history people are ,
she moved from Colorado to the Salton Sea basin which is below sea level, in southernmost California ,
and with greater air density got off the bottled O2..
air resistance is greater the faster you try to go .. It's better if you were shaped like a fish..
fietsbob is offline
Old 04-19-19, 07:49 AM
rumrunn6
rumrunn6's Avatar
Quoted: 3718 Post(s)
Liked 837 Times in 583 Posts
short answer: look at the speedo less
long answer: I wanted to do the same thing 10 yrs ago but with a worse starting point than you have now. got lots of good suggestions here ... wound up modifying that bike a lot! & it did indeed get faster. but eventually, I just wound up with a modern drop bar road bike
rumrunn6 is offline
Old 04-19-19, 09:16 AM
prj71
Quoted: 1027 Post(s)
Liked 43 Times in 36 Posts
Originally Posted by leob1 View Post
Ride more.
Lots of responses in this thread but this one is the best one.
prj71 is offline
