Tire width different front - rear question
Old 07-19-19, 06:52 PM
Beachgrad05
Just Keep Pedaling
Beachgrad05's Avatar
Bikes: 99 Schwinn Mesa GS MTB, 15 Trek Domane 5.9 Dura-Ace, 17 Trek Emonda SL6 Pro & 18 Bianchi Vigorelli
Quoted: 249 Post(s)
Liked 52 Times in 32 Posts
I recently had an issue with Continental tire. They sent me a replacement but in 23 not the 25 it replaced. Rather than deal with trying to send back for a 25 I wonder if I can use it on bike with other tire being 25.....if so...better to have 23 on front or back?
I rode motorcycles and front was skinnier than rear tire so am guessing ok to use 23 on front and 25 on back.
A friend just told me they run 23 on back wheel and 25 on front for “stability on descents as well as speed”. This person doesn’t like descending steep grades. Has vertigo.
So what would be best overall for handling and safety?
Beachgrad05 is offline
Old 07-19-19, 07:16 PM
surak
surak's Avatar
Bikes: Specialized Roubaix, Canyon Inflite AL SLX, Giant Contend SL Disc 2, Priority Continuum Onyx, Santana Vision, Kent Dual-Drive Tandem
Quoted: 370 Post(s)
Liked 135 Times in 85 Posts
I had a 23c in front when I wanted fender clearance. I swapped it for a 25c after deciding some fender rub was better than the sketchy handling I experienced with the 23c in urban environments.
surak is offline
Old 07-19-19, 07:42 PM
DaveLeeNC
DaveLeeNC's Avatar
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 320 Post(s)
Liked 76 Times in 51 Posts
When the 23 that I have on the rear wears out, I plan to replace it with a 25. But 23 is the biggest that fits on the front, so I will be riding 25R and 23F.
dave
DaveLeeNC is offline
Old 07-19-19, 07:47 PM
znomit
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Scott Sub 35
Quoted: 269 Post(s)
Liked 199 Times in 100 Posts
I'd put it on the front because the comfort and handling is more important there.
znomit is offline
Old 07-19-19, 07:52 PM
Beachgrad05
Just Keep Pedaling
Quoted: 249 Post(s)
Put 23 on front?
Old 07-19-19, 07:57 PM
znomit
znomit's Avatar
Quoted: 269 Post(s)
Originally Posted by Beachgrad05 View Post
Put 23 on front?
Sorry for mixing that up, no put the 25 up front. There are benefits to going both ways though, so the correct answer is of course "it depends".
https://www.sheldonbrown.com/tires.html#mixing
znomit is offline
Likes For znomit:
Old 07-19-19, 07:58 PM
ridingfool
Quoted: 84 Post(s)
Liked 18 Times in 16 Posts
when I use 2 sizes I always put the 23 on the front and never seems to be a problem. I'm also a heavier rider so prefer a 25 on the back
ridingfool is offline
Old 07-19-19, 08:06 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 711 Post(s)
Liked 283 Times in 211 Posts
I run two different sizes on my two of my bikes.
I have 28R 25F on one bike and 25R and 23F on another. Never had an issues. I try to stuff the largest tires on my road bikes I can and this is what I can do on two particular bikes with good enough clearance. I would run what you got and don't worry about it. When it wears out buy what you like.
sdmc530 is offline
Old 07-19-19, 08:11 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4609 Post(s)
Liked 1,197 Times in 710 Posts
TWENNY THREE ON FRONT BECOZ MOAR AERO!1!
But for reals, in my case it would be the 23 in the front because I wouldn't want to pump my rear tire to like 110psi.
For most folks, it probably makes no difference. If your wheels are wider than 18c, it's gonna mount to about 25 anyway.
DrIsotope is offline
Old 07-19-19, 08:13 PM
Beachgrad05
Just Keep Pedaling
Quoted: 249 Post(s)
Thanks everyone. Think I will go with my initial instinct of 23 on front. As an Athena I think I prefer the 25 on rear wheel. Doubt I would experience handling issues. Have experience with 23’s on bike before switching to 25’s. Plus motorcycle experience with front being not as wide on my sport bike.
Old 07-20-19, 02:30 AM
canklecat
canklecat's Avatar
Quoted: 3562 Post(s)
Liked 1,065 Times in 716 Posts
For awhile last year I ran 23 front/25 rear. No problems. Ditto on my hybrid, 32/35. No problems with handling.
I've since switched back to 700x25 front and rear on one bike, both 23 on the other, and 700x42 on the hybrid. But that's just because I settled on tires I liked better for comfort. Not an issue with handling on turns.
canklecat is offline
Old 07-20-19, 02:47 AM
ooga-booga
lead on, macduff!
ooga-booga's Avatar
Quoted: 619 Post(s)
Liked 421 Times in 235 Posts
you'll be just fine and i doubt you'll really notice much difference between the two. rocking a '28 up front and a '25 in back on
a mid-80's steel bike that doesn't have clearance for the '28 in back. thought it did. take it on the road and light dirt and it does just fine.
i do like to switch it up occasionally and swap the wheels with '23's from the other bike. the mid-80's bike feels like a new, racier bike at that point.
ooga-booga is offline
Old 07-20-19, 08:24 AM
WhyFi
WhyFi's Avatar
Quoted: 12546 Post(s)
Liked 2,178 Times in 1,151 Posts
Yeah, unless we were talking about gravel/dirt, I'd put the larger on the rear so that I can run a little lower pressure (vs the smaller tire) without increasing the chances of a pinch flat. For gravel/dirt, some prefer the larger tire up front for handling on loose surfaces, iirc.
WhyFi is offline
Old 07-20-19, 08:25 AM
WhyFi
WhyFi's Avatar
Oh wait - I forgot a classic BF answer:
Put the smaller tire up front so that you're always riding on a slight downhill, bruh!
WhyFi is offline
Likes For WhyFi:
Old 07-20-19, 09:42 AM
RGMN
Quoted: 142 Post(s)
Liked 59 Times in 46 Posts
I run a 23mm on the front of my Ritchey Road Logic 2.0 simply because I can't fit a larger tire. A 25mm rubs the underside of the Campag Skeleton brake. A 25mm or 28mm fits in the rear no problem. I've had no issues with it setup this way.
RGMN is offline
Old 07-20-19, 08:17 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 914 Post(s)
Liked 254 Times in 189 Posts
Here's a tip from @FBinNY from the mechanics forum: epoxy a couple of short lengths of spoke in each dropout, then you can run a 25.
Kimmo is offline
Old 07-20-19, 08:24 PM
BengalCat
Bikes: 50/34, 11-40, 11 Speed
Quoted: 135 Post(s)
Liked 68 Times in 49 Posts
My personal experience, (YMMV) IMO was black and white is to go wider on the front on mismatched sizes. It produced better handling and a more comfortable ride.
BengalCat is offline
Old 07-20-19, 09:02 PM
Point
Quoted: 25 Post(s)
According to Sheldon Brown, the newer tire should always be in the front. You want the tire with less chance of failure there.
Point is offline
Likes For Point:
Old 07-20-19, 09:08 PM
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 3153 Post(s)
Liked 148 Times in 108 Posts
The front tire is more important for grip. the rear tends to hit things you may dodge with the front. So for that - bigger on rear is better.
But...if you don't wack things, the smaller profile on the power wheel is more responsive.
You can do either. Pros and cons to both.
Doge is offline
Old 07-20-19, 09:33 PM
RGMN
Quoted: 142 Post(s)
Yeah, I've seen that hack. It's really entertaining when (not if) one side falls out. Bring wrenches to remove the brake.
RGMN is offline
Old 07-21-19, 12:09 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 914 Post(s)
when (not if)
By that logic, anything bonded should eventually asplode.
Gotta glue to clean surfaces. I'd build up the epoxy to surround the bits of spoke, to form a new arch for the dropout.
IMO the biggest issue with it is what it'd do to the geometry by raising the front 4mm instead of 2.
Kimmo is offline
Old 07-27-19, 05:02 PM
RGMN
Quoted: 142 Post(s)
No, my logic is that most mechanics are not well versed in properly bonding metals with adhesives. They won't get an adequate surface prep (likely needs to be etched,) the joint will fail and the spokes will fall out somewhere down the road, usually at the most inconvenient time. Like my buddy who had the spoke fall out while fixing a flat on Mt Evans, just after 11 switchbacks. Shifted the tire enough that it hit the fork. He said he walked a LONG way carrying the front of his bike before someone offered him a ride.
Frame manufacturers typically know how to prep the joints properly. Cleaning only part of the surface preparation.
RGMN is offline
Old 07-28-19, 01:22 AM
Jax Rhapsody
Rhapsodic Laviathan
Jax Rhapsody's Avatar
Bikes: Rideable; 83 Schwinn High Sierra. Two cruiser, bmx bike, one other mtb, three road frames, one citybike.
Quoted: 97 Post(s)
Liked 12 Times in 9 Posts
If anything; pure aestetics alone dictate skinnier tire up front.
Sportbike
Hotrod
Dragster
Sand Rail
Chopper
Wouldn't look right any other way.
Jax Rhapsody is offline
Old 07-28-19, 09:16 AM
SCTinkering
SCTinkering's Avatar
Bikes: 2003 Airborne Valykire w Ultegra 6800, 2018 Trek FX-5S with GRX/Xt 1x drive train
Quoted: 18 Post(s)
Liked 9 Times in 8 Posts
Yep, that's how I do it on my MTB. Oh the bygone days of the Panaracer Smoke 2.0 on the rear and Dart 2.3 on the front. The Dart just looked wrong. Handled awesome, but the optics were...strange.
SCTinkering is offline
Old 07-28-19, 10:42 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
My "SoCal fire road" setup is Panaracer Gravelking SKs, 700x43 in the front and 700x38 in the back. Partly because the chainstays won't clear a 43, but also because for whatever reason the 43 has two more rows of knobs than the 38. When it gets loose, I'm very thankful for those two extra rows.
