Did I make the right choice? (Tarmac/Supersix)
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 03-30-20, 12:13 AM
cyclic_eric
cyclic_eric's Avatar
Bikes: Specialized Tarmac, Gitane TdF, Mercier Kilo TT, Santa Cruz Heckler
Quoted: 20 Post(s)
Liked 9 Times in 6 Posts
Iím still agonizing over a decision I made last summer.
Last July, after test rides on 5 or 6 different bikes and a few hundred hours researching them online, I bought a lightly used 2017 Tarmac Expert Disc Ultegra. The top contender was a 2019 Cannondale Supersix Evo (also Ultegra), with the old school level top tube and rim brakes. Subjectively, on 30-minute test rides, the Supersix seemed to have more of a balanced and assured handling, whereas the Tarmac was quick, almost a teensy bit nervous.
Most of my riding involves climbing, and I liked the lightweight Supersix. But at the time, it seemed like a good idea to opt for the newer style frame of the Tarmac, with its disc brakes and lower price.
The Tarmac has been good to me for these past 9 months. But still I have doubts. Did I make the right call? Or should I trade in my Tarmac for the Supersix?
Thanks for your time & opinions.
Below is a picture of my Tarmac, and a pic of the Supersix found online.
cyclic_eric is offline
Old 03-30-20, 12:18 AM
bpcyclist
Quoted: 447 Post(s)
Liked 356 Times in 221 Posts
Love the look of that Tarmac--beautiful.
What is lacking in the Tarmac? What is it not doing for you? Are you hoping/looking for a more aggressive geometry for some reason?
bpcyclist is offline
Likes For bpcyclist:
Old 03-30-20, 12:31 AM
cyclic_eric
Quoted: 20 Post(s)
It's fairly heavy, at 18 lbs. My last bike was 16 lbs, and the Supersix has the benefit of those carbon hoops.
Another issue is that I just haven't gotten the fit sorted out. I've gone as far as I can on my own, next is to get a pro fitting done.
The Tarmac has quick-release hubs front and rear, and my local bike shop says only custom built carbon wheels will fit.
idk
So I guess the weight is one issue, fitting another, and then - please forgive me here - I need to convince myself that the Tarmac is cool.
Old 03-30-20, 07:25 AM
colnago62
Quoted: 482 Post(s)
Liked 146 Times in 93 Posts
What size is that frame? I have a 60cm Madone 9 and with pedals plus cages and a power meter it weighs in about that.
colnago62 is offline
Old 03-30-20, 07:37 AM
abshipp
abshipp's Avatar
Quoted: 1220 Post(s)
Liked 716 Times in 325 Posts
idk
A thing to consider, I know that most disc wheels are thru-axle nowadays, but it's also very common for hub manufacturers to design their hubs with interchangeable end caps, so that you can run them either with a thru-axle or with quick release skewers. For example, the wheelset on my MTB can be run at 15x100/12x142 or 9x100/10x135.
And FWIW, to answer your initial question, I would have gone with the Cannondale. I probably wouldn't hate owning the Tarmac, but the Cannondale is definitely a hotter bike.
abshipp is offline
Likes For abshipp:
Old 03-30-20, 07:44 AM
WhyFi
WhyFi's Avatar
Quoted: 12556 Post(s)
Liked 2,191 Times in 1,161 Posts
SCS spacing?
It's a nice bike. Going forward, I'd much rather have discs and a small weight penalty. If I had to choose between those two bike, I would have went with the Tarmac, too.
WhyFi is offline
Old 03-30-20, 07:50 AM
topflightpro
topflightpro's Avatar
Quoted: 1516 Post(s)
Liked 237 Times in 158 Posts
SCS spacing?
I agree that I would rather have discs at this point, since that is the way the market is going. (Not saying discs are needed, but it sets you up better for future compatability.) That said, if it is SCS spacing, I believe you can purchase a new RD hanger that eliminates the SCS so you can use different wheels, though it is increasingly difficult to find QR disc wheels.
In the end, OP, you're comparing an Accord to a Camry. They are both quality bikes that are very similar in many ways, and you really didn't make a bad choice.
topflightpro is offline
Likes For topflightpro:
Old 03-30-20, 08:02 AM
SSRI
Quoted: 103 Post(s)
Liked 9 Times in 7 Posts
As an 1 and only bike in your stable..Tarmac Disc.
But I am more partial to the Dale with the R7000....since I have an inventory of Rim brake Wheelset.
SSRI is offline
Old 03-30-20, 08:40 AM
smashndash
Quoted: 544 Post(s)
Liked 142 Times in 102 Posts
The cannondale has a TA front and a QR rear. IMO thatís even worse than having QR front and rear because youíll never find such a wheelset (unless you go with interchangeable end caps).
Itís not that tough to get a custom wheel built. People do it all the time. It was the only way to get a wheel until the 80s or so.
I personally think you are reeeeally splitting hairs trying to find a difference between these two bikes. The frames are both stiff, light, racy and use QR discs. The rest is parts.
smashndash is offline
Likes For smashndash:
Old 03-30-20, 11:06 AM
cyclic_eric
Quoted: 20 Post(s)
My tarmac is a 54cm.
From what I understand, it is a SCS (short chainstay) at 40.5cm long. The hubs are DT Swiss 350. 135 mm rear dropout spacing. It sounds like I may be limited to Roval or Next wheels, idk.
So if it can be accomplished, carbon rims, and perhaps a carbon stem/handlebar set, will save a bunch of weight, and upgrade to a livelier feeling ride.
I guess I'll try to read up on wheels. What a p.i.t.a.
I should go for a ride.
Old 03-30-20, 11:28 AM
ls01
he said member
ls01's Avatar
Bikes: yes please
Quoted: 553 Post(s)
Liked 277 Times in 182 Posts
It wouldnt matter. You would be asking this the other way round of you bought the 6.
Tarmacs are great bikes. I have 4 of them.
I have a 16 with disk and sram axs 12 speed. Its heaver too 18 ish lbs.
but it is rock solid.
ebay. Carbon wheels from king bike. It's a woman but I cant recall her name. As far as getting wheels that will fit they can make anything you need. These are dt swiss hubs 60mm carbons with xdr freehub for axs12 speed for 500.00. Hard to beat
ls01 is offline
Likes For ls01:
Old 03-30-20, 11:42 AM
cyclic_eric
Quoted: 20 Post(s)
Thanks -
Great looking ride
Old 03-30-20, 09:11 PM
RedBullFiXX
RedBullFiXX's Avatar
Quoted: 70 Post(s)
Liked 38 Times in 30 Posts
Supersix is Super nice
QR axles are better for rim brakes
RedBullFiXX is offline
Old 03-30-20, 10:55 PM
bahula03
Quoted: 13 Post(s)
Liked 23 Times in 11 Posts
People seem to have covered the wheel aspect pretty well. Two small things to add,
-If a bike isn't fit properly, you're never going to be able to fully enjoy it no matter how nice it is. I know a few people around here strongly advocate for doing the fit yourself, I'm of the opinion that unless you have a ton of experience setting bikes up, spending the time and money on a professional fit is a necessity.
-Once you get into "nice" bikes, things become as much (if not more) about how you feel about the bike and how the bike makes you feel, as the actual function of the bike. There are a ton of great options at any given price point and bike type (including both bikes in question), and if you're more excited about the Cannondale to the point it's going to get you out riding more...go for it. I think you probably already know the answer to the logical value/benefit question for the lighter rim brake bike vs the functionality of the disc bike as-is, having come from a ~16lb rim brake bike and having ridden the Tarmac for nine months.
bahula03 is offline
Old 03-30-20, 11:16 PM
Camilo
Quoted: 308 Post(s)
Liked 89 Times in 56 Posts
There's no wrong choice with either of those fine bikes. However, I would have the bike that felt best to me, no doubt at all. That's what makes me happy when I ride. The group, the braking system (assuming excellent brakes), the "hotness", none of that matters a bit when you're riding. But the handling, comfort, overall feel.... that's what makes me happy, gets me on the bike and makes me ride more and faster.
IMHO, disk vs rim is not the most important factor by a long shot. Good rim brakes are.... good enough for pro riders, at least some of them, to this day. As far as future compatibility, I don't believe you'll ever want for quality rim brake wheels. At least until the time you'd want a new bike anyway.
For you the obvious choice is n+1 . Glad I could be of help. 8-)
Camilo is offline
Likes For Camilo:
Old 03-30-20, 11:20 PM
cyclic_eric
Quoted: 20 Post(s)
Well said bahula03. Once everyone is ok with getting within 6 ft of each other again I'll schedule a fitting. I hope that time comes soon.
I think I probably made the right call, logically speaking. The discs do feel safer, imo. But once stores open up again, I may go have another look at the Supersix, just to torture myself.
In fact, I'll probably go around to all my local bike shops, and just buy anything remotely useful.
