Can a pedal be un-removable? Schwinn Letour 3
Old 04-15-20, 04:39 PM
Arthur Peabody
Quoted: 124 Post(s)
Liked 20 Times in 14 Posts
I tried to help a neighbor who had broken a pedal on his Schwinn Letour 3 (it appears to be a very cheap bicycle). It was broken where the axle enters the pedal. I put my biggest wrench, a 12-incher, on it. Neither of us could make it budge. It's an alloy crank. The pedal looks to be screwed into the crank arm. I've been replacing my own pedals for 50 years, so I know how to do it.
Arthur Peabody is offline
Old 04-15-20, 04:48 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Quoted: 935 Post(s)
Liked 376 Times in 272 Posts
And you're certain you didn't have the LH crank and were tightening it?
Heat it a little with a torch to break it free.
Unca_Sam is offline
Old 04-15-20, 04:57 PM
Trevtassie
Quoted: 503 Post(s)
Liked 301 Times in 154 Posts
Even better, heat it with a heat gun and spray some Loctite Freeze and Release spray on the back side where the other end is. As it cools the release lube will get sucked into the thread.
Trevtassie is online now
Old 04-15-20, 05:05 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1057 Post(s)
Liked 429 Times in 318 Posts
Before you do the heat/cold treatments, spray some Kano Kroil or PB Blaster on liberally, tap the end of the pedal axle with a hammer to get it started soaking in, and wait overnight or longer for it to do its magic.
And make certain that you are turning the right direction, left pedal is left-handed threaded.
dsbrantjr is online now
Old 04-15-20, 05:52 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 991 Post(s)
Liked 210 Times in 165 Posts
The idea is to "ring" it, not smash it. I use the box end of an old 7/16-5/8" wrench and use quick, light taps. Wrench size varies with part size.
The vibration helps the oil to migrate to where it needs to go. Apparently, the "ringing" assists the capillary action of the oil.
Bill Kapaun is offline
Old 04-15-20, 06:56 PM
Arthur Peabody
Quoted: 124 Post(s)
I know how to deal with stuck threads. I know how pedals are threaded. I noticed another neighbor had left the frame of a junked bike out for the trash. I removed its pedals easily. My question stands unanswered.
Old 04-15-20, 07:00 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 174 Post(s)
Liked 84 Times in 64 Posts
If push comes to shove there's always the drill. Use a dull bit and it'll heat it up at the same time. I have quite a few dull bits if you need one...
Bigbus is offline
Old 04-15-20, 07:04 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 68 Post(s)
Liked 38 Times in 26 Posts
If you don't mention it, we gotta ask if you know the left pedal is lefty-tighty.
You say you know how to deal with stuck threads. You say you know how to do it. Some people have good suggestions and you've tossed them aside. What else have you tried besides your biggest wrench?
To answer your question, yes, it's possible for a pedal to be unremovable.
Rogerogeroge is offline
Old 04-15-20, 07:28 PM
Trakhak
Quoted: 509 Post(s)
Liked 157 Times in 109 Posts
In 15 years of working in bike stores, I only ever encountered one pedal that almost beat me. Ended up extending a 12-inch adjustable wrench with a Park frame straightener tool. It's surprising what a difference four feet of persuasion can make.
That tool happened to be handy, but you can probably extemporize something providing similar leverage. My rule: whatever you need to solve some seemingly impossible mechanical problem is within ten paces of where you're standing.
In fact, come to think of it, just a week ago I was fooling around at home, trying to back a Campagnolo Ultra-Torque bottom bracket cup out of a frame. That cup was as immovable as the pedal had been. So I took the bike off my Aldi repair stand, pulled off the top part of the stand, and stuck that pipe over the handle of a 1/2" drive ratchet wrench. I thought the ratchet would give first, but the cup finally started turning. Success.
Trakhak is online now
Old 04-15-20, 08:04 PM
aggiegrads
Quoted: 164 Post(s)
Liked 66 Times in 49 Posts
You didnít actually ask a question in your OP. To answer the thread title: There is no doubt that the pedal can be removed. The crank or pedal may not be salvageable, but the pedal CAN be removed.
aggiegrads is offline
Old 04-15-20, 08:05 PM
Arthur Peabody
Quoted: 124 Post(s)
This won't work if the pedal is bonded (welded?) into the crank arm.
I've been changing pedals for 50 years, both left and right. As I mentioned in my second message, I removed both pedals of another bike a few minutes later.
It's the owner's call. He had to go. I don't want to promise him that I'll succeed when I can't. We're not friends, just neighbors. He's 45 years younger, so we may not read each other well.
In the sense that it was made that way, rather than corroded on?
These are bikes people bring into shops. This fellow is riding around with 1 pedal, seems to think that's okay. I think he'll ride on 1 pedal, or junk it, before he takes it to a shop. It's a throwaway bike. Some cranks are made so you can't remove the chain rings. Some hubs are made so you can't remove the cogs.
Old 04-15-20, 08:13 PM
aggiegrads
Quoted: 164 Post(s)
Ah, I understand your question now. No - all pedals are removable. I am certain that no pedal was ever permanently fixed on the crank arm by design. Especially one with wrench flats.
Likes For aggiegrads:
Old 04-15-20, 08:15 PM
Rogerogeroge
Quoted: 68 Post(s)
It wasn't made that way. Most likely a galvanic reaction between the steel pedal spindle and the alloy crank arm. Or possibly corrosion, but I doubt the oxidation of the spindle would prevent removing it with brute force. Galvanizing can be the equivalent of welding, i.e., a four foot cheater bar isn't going to remove it without snapping it off.
Le Mechanic
Le Mechanic's Avatar
Bikes: Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 83 Post(s)
Liked 44 Times in 36 Posts
If they were installed, they can be removed. I made a video a few years ago with some tips and tricks that might be helpful for stuck pedal removal.
Le Mechanic is offline
Old 04-15-20, 09:23 PM
davidad
Quoted: 426 Post(s)
Liked 57 Times in 52 Posts
I had a tough one a year ago and iced the pedal axle for ten minutes and it came off fairly easily. This was after using a 4 pound hammer and a heat gun that couldn't get it off.
davidad is offline
Old 04-15-20, 09:36 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 566 Post(s)
Liked 143 Times in 109 Posts
I had a Schwinn Le Tour III years ago. Decent enough bike for its time.
As with all Schwinn bicycles from that decade the pedals were removable. I assembled hundreds of Schwinn bikes when I worked in the local shop and every single one required installation of the pedals.
Schwinn bikes back then had the occasional quirky part but the pedals were absolutely standard.
Jeff Wills
Jeff Wills is offline
Old 04-15-20, 09:42 PM
noobinsf
noobinsf's Avatar
Quoted: 568 Post(s)
Liked 254 Times in 185 Posts
Picture?
noobinsf is offline
Old 04-15-20, 09:51 PM
CliffordK
CliffordK's Avatar
Quoted: 11351 Post(s)
Liked 872 Times in 686 Posts
I wouldn't put it beyond someone welding a pedal spindle into a steel crank arm. But, that is less likely with a steel spindle and aluminum crank arm.
If the pedal is broken and non-repairable, I'd go by the theory of nothing you can do can make it worse.
Perhaps put the crank arm in a vise and use a cheater, or even a really large pipe wrench.
CliffordK is offline
