Is mildewy cutting board safe?
Old 05-09-20, 10:13 PM
mtb_addict
Quoted: 3217 Post(s)
Liked 59 Times in 51 Posts
hi. bought it online. Theres mildewy stuff on both sides. it was damp when i recived it.
i tried soap, water, vinegar, and green pad to scrub it off...no luck.
is this safe to use? just ignore it and use it?
mtb_addict is offline
Old 05-09-20, 10:20 PM
mtb_addict
Old 05-09-20, 11:41 PM
canklecat
canklecat's Avatar
Quoted: 3558 Post(s)
Liked 1,054 Times in 709 Posts
If it's wood I'd toss it or use it in the garage or shop for other projects. Wood isn't good for kitchen food prep -- too hard to sanitize properly.
I use plastic cutting boards and thin liners and just replace 'em once in awhile as they wear. They're cheap and good from local dollar stores and discounters.
Otherwise, if you prefer to keep this cutting board, try bleach or Clorox bleach spray. Their foaming bleach spray is the bee's knees for kitchen and bathroom cleanup. It's the perfect mixture of bleach and surfactants, no need to worry about mixing incompatible chemicals and creating toxic gas. Bleach will kill just about any microbe. We used it in hemodialysis units because some patients had hepatitis and other bloodborne diseases. We'd swab for lab tests occasionally and the bleached unit came back negative. It works. But with the Clorox foaming spray you don't need to worry about the correct dilution.
canklecat is online now
Old 05-09-20, 11:50 PM
Russ Roth
Quoted: 299 Post(s)
Liked 202 Times in 153 Posts
This is completely inaccurate, while tests show that a new plastic cutting board is easier to sanitize once the board has been used a couple times it can be nearly impossible to thoroughly sanitize while the tannin in wood help the board to be sanitized and if it gets too scratched so that its hard to clean it can be sanded and fixed while plastic has to be thrown out.
To the OP, you won't get the staining out completely, canklecat is right about bleaching it, there will probably be a stain after that but it won't effect the ability of the board to work. Kind of looks like someone finished wood that wasn't fully dry which requires a large drying oven or can take over a year of he wood being properly stickered and stacked with appropriate air flow.
Russ Roth is offline
Likes For Russ Roth:
Old 05-10-20, 12:00 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4602 Post(s)
Liked 1,182 Times in 703 Posts
I would sand it and re-oil it. Plastic cutting boards are disposable items, a good wood cutting board can last a lifetime. Sure, they take more care than a sheet of plastic that can be thrown in the dishwasher, but sometimes that's the price of having a nice thing.
In my kitchen we have an island with a 3" thick butcherblock top. I refinish the top and re-oil it every few years.
The cutting board I made as a wedding gift for a buddy of mine a few years ago. Endgrain except for the walnut trim, 2" thick. I would take this over an injection molded chunk of plastic any day.
DrIsotope is offline
Likes For DrIsotope:
Old 05-10-20, 12:01 AM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2183 Post(s)
Liked 579 Times in 405 Posts
I read of an interesting discovery years ago by a researcher who was doing a project relating to kitchen bacteria. (Don't remember what he was researching.) Just for a reference, he set two cutting boards dirty from uncooked meat out overnight. One plastic, the other wood. The next morning the plastic was, as expected, teeming with bacteria. But the wood wasn't. It had some but far less. He repeated this several times and kept getting the same results. Commented to the effect that this might why primitive cultures don't all keel over from bacteria poisoning despite none of the modern hygiene.
I have mold in this house. Stays manageable with attention to keeping things dry. But it has gotten in to my favorite cutting board. I use it every day and seem to suffer no adverse effects. I know I could cure the mold issues and insurance would pay for it but it would be at the cost of my integrity. (Have an arsonist burn my house to the ground and rebuild.)
Ben
79pmooney is offline
Old 05-10-20, 12:57 AM
canklecat
canklecat's Avatar
I simplified things for the sake clarity. Butcher block safety depends on the type of wood and maintenance. If you're not sure of what kind of wood a cutting board is made from or how to clean it properly, it's probably not the right choice for your kitchen. I just find it easier to replace plastic cutting boards often.
Old 05-10-20, 01:31 AM
mtb_addict
is a block of wood and some coarse sand paper....doable?
or do i need to buy a electric sander?
Old 05-10-20, 04:40 AM
ahsposo
Turgid Member
ahsposo's Avatar
Quoted: 4314 Post(s)
Liked 1,012 Times in 620 Posts
Hit it with a butane torch.
ahsposo is offline
Old 05-10-20, 04:50 AM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 711 Post(s)
Liked 283 Times in 211 Posts
you can hand sand it but a motorized/pneumatic tool would be way easier. This gets my vote too, sand it and start fresh....
sdmc530 is offline
Old 05-10-20, 07:34 AM
FiftySix
I'm the anecdote.
FiftySix's Avatar
Bikes: '13 Norco CityGlide 8IGH, '12 Schwinn "Speedster" Willy SS
Quoted: 846 Post(s)
Liked 723 Times in 527 Posts
If the goal is to make it a usable cutting board and not a work of art, I vote for bleaching first. If not satisfied with the results, then sand it down.
Most working cutting boards don't look pretty for very long anyway.
FiftySix is offline
Old 05-10-20, 10:56 AM
Quoted: 11227 Post(s)
Liked 2,809 Times in 1,566 Posts
Iíd be worried about it shocking me or catching on fire and hurting one of my family members.
Likes For indyfabz:
Old 05-10-20, 11:22 AM
njkayaker
Quoted: 2102 Post(s)
Liked 152 Times in 106 Posts
It won't be any less or more safe than without it.
njkayaker is offline
Likes For njkayaker:
Old 05-10-20, 11:24 AM
ahsposo
Turgid Member
ahsposo's Avatar
Oh come on! Where is your sense of drama? That thing looks like it will kill just sitting on the counter...
ahsposo is offline
Likes For ahsposo:
Old 05-10-20, 11:28 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 11843 Post(s)
Liked 3,148 Times in 1,774 Posts
Those kinds of tools aren't safe. At all.
Seattle Forrest is offline
Likes For Seattle Forrest:
Old 05-10-20, 11:36 AM
Itís a wonder that you still know how to breathe.
Likes For indyfabz:
Old 05-10-20, 12:46 PM
Seattle Forrest
Is breathing safe?
Old 05-10-20, 12:49 PM
mrodgers
mrodgers's Avatar
Bikes: 2014 Giant Escape 1
Quoted: 267 Post(s)
Liked 17 Times in 12 Posts
It is ridiculous. No one needs an assault sander just to get rid of some mold in a cutting board. This is why we need sensible sander laws.
mrodgers is offline
Likes For mrodgers:
Old 05-10-20, 12:54 PM
ahsposo
Turgid Member
ahsposo's Avatar
When assault sanders are outlawed only outlaws will have assault sanders!
ahsposo is offline
Old 05-10-20, 12:55 PM
ahsposo
Turgid Member
ahsposo's Avatar
Is breathing safe?
I think it's pretty well proven that if you breath long enough eventually you die.
ahsposo is offline
Likes For ahsposo:
Old 05-10-20, 01:36 PM
skijor
on by
skijor's Avatar
Quoted: 671 Post(s)
Liked 168 Times in 102 Posts
Sanders don't kill people.
Oh wait...
skijor is offline
Likes For skijor:
Old 05-10-20, 01:55 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Seriously - don't get a belt sander! Get an orbital sander. Belt sanders are great tools - in the hands of someone who has skill with them., intends to remove real amounts of material and intends to follow up with other sanders. They do not have the inherent tendency to keep surfaces flat. Once you create the waves, its use as a good cutting board with long, straight knives is over unless you want to do real work making the board flat again. (More tools and/or elbow grease.)
Likes For 79pmooney:
Old 05-10-20, 01:59 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2769 Post(s)
Liked 678 Times in 473 Posts
How did I guess that this OP would figure out a cheap way to make a bad idea more dangerous?
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
But if you donít breathe long enough you die sooner.
Old 05-10-20, 03:02 PM
ahsposo
Turgid Member
ahsposo's Avatar
Just another example of "You're damned if you do and damned if you don't".
ahsposo is offline
