Chain Jam
Chain Jam
No, not a new spread for toast. Shifting onto the biggest cog, while on the small chain ring caused a jam, the other day. Since I was going up hill at a really low rate of speed, The bike immediately stopped and I fell over. The second time, I was ready and did not fall over. The chain looked like it was riding up on the upper jockey wheel on the derailleur.
Chain rings are 46-36-24, rear cog is 30. Suntour cogs and derailleurs on a Bruce Gordon.
Any ideas?
Any ideas?
Quoted: 3452 Post(s)
Liked 1,452 Times
Could the derailleur or hanger be bent? Does alignment look good?
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I had that happen to me on my MTB after swapping out the BB for a sealed unit and having to modify (shim) the front DR to reach the outer ring. It came loose just enough to move (pivot) and throw off the alignment with the chain. After having the chain jam in the rear, I looked it over and sure enough the FDR was guiding the chain at an off angle to the rear cassette and binding the chain back there. I realigned the FDR and all is good with the world again. If I hadn't recently shimmed out the FDR for the reach, I never would have suspected it. Just another thought. Good luck,
Suspect the hanger is OK, no other shifts feel bad. Maybe the FDR has an issue, I'll look.
Thanks, to you both
Thanks, to you both
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times
I doubt that posting this, that the bottom of this problem will be solved. As a bicycle store owner for over 12 years and a mechanic for many more, I believe that if you are not able to figure out why the chain is jamming I can not imagine how someone on this forum will know (especially without even seeing it). I would though, recommend that you take it to your LBS and give them some hands on with the bike. (something that will never happen on this forum). hope you figure it out. Good Luck.
Likes For Brian25:
how old be thy chain?
check that the links are all rotating smoothly. rust inside the bushings might be causing one link to bind.
won't notice on the big chain ring, but going around the pulleys, one link will stick and not rotate freely.
https://tse2-mm.cn.bing.net/th/id/OI...4?pid=Api&rs=1
Likes For saddlesores:
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times
Alignment issue (bent RD or otherwise)
Idler pulley/cog issue - bearings (if it has them, roller, ceramic?) goofed up? Bushing issue (if bushing instead of bearings)?
Debris stuck in the RD causing an issue with the above 2?
If you are having trouble seeing the chain alignment shifting put the bike on a stand and hand crank it slowly and watch the motion of the RD and chain alignment. Check the RD spring tension also. Too lose and the chain could be allowed to bounce too much.
Check the link count on the chain and see if it is identical to what you were using before. Chain length will affect the RD as it is also taking up the slack of the chain. Different length chains will give you different angles to the pulleys/cogs in the RD and could affect the shifting somehow.
Good luck.
Good luck.
Liked 1,452 Times
Or, hang it from a rafter in a garage from a rope.
If the chain is that new, maybe it is a couple links too short and you only found out about that now.
Quoted: 2236 Post(s)
Liked 1,314 Times
Where did the chain jam?
If it was between the large sprocket and the frame it could be the rear derailer limiter screw needs to be adjusted inward.
No, the rock group was what I landed on, on the dirt road.
Chain length looks ok, not stretched out or all doubled up on either the small ring/big cog, or middle ring/ big cog.
Jam was between RD and largest cog on the cluster.
I put the bike on the rack in the garage and tried various shifting combinations and they all seemed to work fine
Quoted: 405 Post(s)
Liked 115 Times
LOL. Cluster. What a cluster fluck.
Its a "cassette".
In any event, good test on the cranking. When you say it jammed between the RD and the largest cog on the cassette - you mean on the wheel side of the cog? Or the next smallest cog on the cassette? And when you un-jammed it - was the chain on the idler pulley/cog nearest the cassette? Or was it off of that idler as part of the jam?
Someone already pointed out the adjustable stop-screws on the RD mechanism. If the RD throws the chain too far "in" (towards the wheel/tire) it is possible the chain could ride up and over the teeth. That doesn't sound right to me, though, if everything was adjusted before and the only difference was the new chain.
I suspect there is something that is bent, or otherwise misaligned. I had that happen to me with my folding bike. I swapped the tires F/R earlier this season to balance the thread wear (will need to do that again soon - the small tires wear faster) and I managed to put some odd pressure on the RD maneuvering the wheel on and off. I had to reset the RD adjustment etc to get it dialed back in. Not much of a problem, but it was avoidable work if I was more careful with the taking out/installing of the wheel...
Its a "cassette".
Liked 1,452 Times
Quoted: 1188 Post(s)
Liked 1,154 Times
Yep, back in the day that's what we called them. And the chamois in your shorts was made from a deer...
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Any ideas?
Any ideas?
Stuart Black
Stuart Black
Static testing did not reveal any jamming, but the weather for tomorrow looks to be nice so I'll try to recreate the problem; on a nice level parking lot.
Wish me luck
Wish me luck
