New VP Vice pedals wreck threads on new Rene Herse crank
Old 05-18-20, 09:51 AM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 81 Post(s)
Liked 35 Times in 29 Posts
Has anyone else ever had this happen? Brand new pedals, brand new crank. The pedals were pretty difficult to install and by the end there were chips of aluminum getting pushed out the other side.
Yes, I thoroughly greased the threads. No, they're not cross-threaded. Both pedals did the same thing. I don't remember this happening years ago when I installed Shimano pedals on a new Rene Herse crank. I even tried softening the rough edges of the pedal threads with a Dremel cut-off wheel, but that didn't seem to help.
I think I'm going to order some crank taps and try making a pedal thread "die" out of an old steel crank arm to prevent something like this from happening again. I just hope I didn't ruin the crank... I needed the bike and didn't have another good option at the time. Now I'm afraid to remove the pedals.
FastJake is offline
Old 05-18-20, 10:23 AM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 17861 Post(s)
Liked 1,530 Times in 1,131 Posts
...I'm not familiar with those pedals, and I've never had the disposable cash to buy a Rene Herse crank set. But given your description, I too, would leave the pedals alone in place if the pedal axles are at straight right angles to the crank arms. But to put your mind at more ease, if there is some mysterious damage that has occurred because of this incident, your cranks are not ruined. There's a simple solution using special boring and rethreading tool, that you use to install a threaded insert (on each side, R + L), and that fixes them right back up. The tool and six sets of inserts is far cheaper than the original price of your crank. Some local shops have them, but not all of them.
If you have an issue later on, and you can't either buy the tool and threadserts or can't find one locally, let me know. But the whole back and forth shipping will cost way more than just finding someone local to do it.
3alarmer is offline
Old 05-18-20, 10:59 AM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 343 Post(s)
Liked 113 Times in 92 Posts
Guessing between the two--I'd bet the problem was predominantly the pedal threads. My guess is it's fine. If you ever messed up the threads on a super expensive crank like that, the upside is that a Herse crank is solid aluminum so you could use a helicoil kit on it if you somehow really damaged the threads.
cpach is offline
Old 05-18-20, 11:00 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1061 Post(s)
Liked 433 Times in 319 Posts
Might the pedals have had the old 14 mm x 1.25 mm French threads? Did you swap the pedals left for right?
dsbrantjr is offline
Old 05-18-20, 12:27 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2769 Post(s)
Liked 678 Times in 473 Posts
Spiky MTB pedals with French threads?
I suspect that this is some combination of a small crank ID or large pedal OD in order to prevent a loose fit. I have a virgin set of RH cranks downstairs -- I could try measuring the bore.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 05-18-20, 12:30 PM
bikemig
bikemig's Avatar
Quoted: 4445 Post(s)
Liked 739 Times in 536 Posts
That would be my guess. I'll bet there's no damage and pedals will now thread in easily to the crank.
bikemig is offline
Old 05-18-20, 12:41 PM
ThermionicScott
7-speed cultist
Okay, I forgot that my digital calipers have a dead battery. So I tried threading on one of my known-good Shimano A600 pedals -- from the back side of the crank, just in case. It presented no unusual resistance, but I saw some very fine aluminum shavings, too. I think RH is erring on the side of giving us the maximum amount of beef to start with since the crank threads are bound to wear, but those VP pedals might still have sharp or excessively-tall threads for the same reason.
RUSA #7498
Old 05-18-20, 12:42 PM
dsbrantjr
dsbrantjr's Avatar
I misspoke, I meant to say French-threaded cranks.
Old 05-18-20, 12:46 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 81 Post(s)
Good question. No, these are the new-production version. Definitely standard 9/16".
FastJake is offline
