Options for 700c wheels on old french bike with narrow frame spacing
Hi there ,
I have an old perugeot , carbolite steel ,made for 27 x 1 1/4 inch wheels , it has 125 spacing at rear and something like 98 or so up front.
Id like to put a modern wheelset in there to run as a singlespeed but I'd like to avoid coldsetting the frame.
What are my options ? Could I play around with spacers , dishing and shorten axles and source QR levers to achieve this ?
Thanks ,
J
Thanks ,
J
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
98/125 to 100/126 is close enough to not need cold setting...it'll just fit... and probably 100/126 was the original spec anyway.
Sr Member on Sr bikes
But wait. If by "modern wheelset" you're referring to 700c...you might have a problem with rim brakes. A 700c wheel has a smaller circumference than a 27" wheel. If the frame was constructed for 27" wheels and you put a 700c on it...the brake arms may not be long enough to adjust the pads out far enough to reach the rims. Check that before you purchase the wheels. There are brake calipers available with longer arms specifically for this situation. But just pointing out that you may be setting yourself up for a purchase of new calipers with this rework.
Dan
Dan
Likes For _ForceD_:
Constant tinkerer
A carbolite Peugeot is not rare or collectible enough to be worried about something as trivial as re-spacing the frame and fork a couple millimeters. Or, as Scott said, just ease the new wheels in there. It'll work fine.
If you have a good mechanic do the work it's a nice opportunity to make sure the frame and fork are both straight, and have the dropouts aligned if necessary.
The pads only have to move down 4mm and there is almost always enough adjustment in them. But it's still a good idea to check.
Dan
Dan
Quoted: 5888 Post(s)
Liked 3,471 Times
You likely do not need special brakes assuming you have the original center pull brakes (likely weinmann but maybe Mafac if an older Peugeot). Either of those brakes have sufficient reach for a 700c conversion.
Likes For bikemig:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Different Scott here: there are quite a few 126mm-spaced freewheel rear wheels available, get one of those.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Check out Velomine. Plenty of good 126(rear) wheelsets, and great service.
Again it's almost certainly supposed to be 100/126, and regardless that'll fit effortlessly anyways. You might be able to space a 120mm single speed wheel to 126 with spacers assuming the axle is long enough, or order a longer axle with the same size and pitch. This is probably what I would do. Or on the cheap you could find an older 126mm freewheel wheel, which will have the slight disadvantage of being somewhat dished (as opposed to respacing a ss/fg hub).
There's also https://velo-orange.com/products/gra...fixed-hub-rear .
It's MY mountain
Liked 2,980 Times
Single speeds on a cassette hub would require some fitting issues for the 130mm OLD, would almost certainly be more expensive, and would look awkward too.
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
Hi there ,
Thanks ,
J
Thanks ,
J
That said, there are many ways to achieve your objective, as already stated in many responses above. But respacing a Carbolite frame is pretty easily accomplished.
