Can some Garmin Edge users help me out?
Old 05-25-20, 03:59 PM
Koyote
Quoted: 827 Post(s)
Liked 621 Times in 332 Posts
Finally got my Edge 530 set up the way I want it, and it automatically connects to the Garmin Connect app when I turn it on for a ride - which is great, as text msgs and phone call notifications come through on the computer screen. But I am noticing that my iPhone battery drains about 10% per hour, mostly from the Connect app running in the background. I turned off location services for the app, but left background app refresh turned on, and same result.
Do others see this phone battery drain, or am I doing something wrong? Seems like this would make long rides (during which I might use my phone for photos and such) a bit dicey. And before someone asks, I am NOT using Garmin Live Track.
Any input appreciated!
Koyote is offline
Old 05-25-20, 04:20 PM
Steve B.
Quoted: 1593 Post(s)
Liked 304 Times in 215 Posts
Check that the backlight isnít set to always on. Donít stay on the map screen, that takes more processing and battery.
The connect app (Garmin Connect Mobile, or GCM) isnít on the device, itís on the phone only. The device will use low powered BlueTooth to maintain a connection to GCM for notifications. Thus having LiveTrack on wonít matter if BLE is running as itís always checking the phone for data.
The 30 series - 530/830/1030 all are rated at 20 hrs. My 2 year old 1030 gets 4-5% battery used per hr. currently. Navigation takes more battery.
Steve B. is offline
Old 05-25-20, 04:37 PM
Iride01
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 1329 Post(s)
Liked 320 Times in 247 Posts
Just to be clear.... it's the phone that is having the big battery drain when connected?
If you are using the Garmin app on your phone, that will be the culprit likely. Call Garmin support and see what they say. They likely have already dealt with other's on this if it is the Garmin app on the iPhone.
Do iPhones have an app or utility that lets you know how much battery the other apps and things on your phone are using?
Iride01 is online now
Old 05-25-20, 04:47 PM
Koyote
Quoted: 827 Post(s)
Thatís correct Ė the battery drain is on the phone, as I wrote in my original post.
I have looked at my batteryís usage stats, and the drain is coming from the Connect app. I suppose I can call Garmin support - itíll be the fourth bloody time since I got this computer two weeks ago. What an absolutely awful user interface experience.
Koyote is offline
Old 05-25-20, 05:13 PM
Iride01
Iride01's Avatar
Well if Garmin doesn't have anything to help, then try disabling certain features in the phone app and maybe you can narrow it down. Hopefully it is something you really don't care about.
Have you had the 530 for a while and have a lot of rides on it? If you just started using the app, then maybe it's sending all those stored ride to the Garmin Connect website. So maybe it's just a temporary thing. Does the phone app also have the ability to update maps and stuff on your device? That too might be battery drain.
Old 05-25-20, 07:18 PM
Steve B.
Thank you, missed that.
Steve B. is offline
Old 05-25-20, 07:25 PM
Steve B.
@OP, sorry I missed you stating the iPhone problem.
I have an iPhone 8 on the most recent OS, haven’t noticed any unusual battery issues but haven’t been paying attention either. My practice is to verify that Connect is running before I power up my 1030, so that LiveTrack will (hopefully) work, which is about 80% of the time. I get notifications as well and I know the weather widget gets updates thru BT and the phone, so that’s generally running as well. My phone is set to allow automatic updates of apps, so likely my version of Connect is current.
I’ll pay attention tomorrow, I’m doing a 2 to 2-1/2 hr ride.
Steve B. is offline
Old 05-25-20, 07:35 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 711 Post(s)
Liked 283 Times in 211 Posts
I never had this issue at the rate your having. It did bring down the battery more but not 10% an hour.....something is defiantly not correct. I had a 500, then a 520, not a 1030. Only the 520 and my new 1030 were live connected to my phone. I will say however my newer iPhone does better than my old 6 year old version...…
Check with garmin, either call or do the live chat. They have good CS if you DONT do the email exchange…..
sdmc530 is offline
Old 05-25-20, 08:38 PM
Koyote
Quoted: 827 Post(s)
I have an iPhone 8 on the most recent OS, havenít noticed any unusual battery issues but havenít been paying attention either. My practice is to verify that Connect is running before I power up my 1030, so that LiveTrack will (hopefully) work, which is about 80% of the time. I get notifications as well and I know the weather widget gets updates thru BT and the phone, so thatís generally running as well. My phone is set to allow automatic updates of apps, so likely my version of Connect is current.
Iíll pay attention tomorrow, Iím doing a 2 to 2-1/2 hr ride.
Steve, thanks, I'd love to hear how much your phone battery drops during the ride. Thanks!
Koyote is offline
Old 05-25-20, 11:51 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 11851 Post(s)
Liked 3,155 Times in 1,777 Posts
Have you had Bluetooth on before this or did you turn it on to work with the Garmin?
I'm using Android so I don't know how relevant my experience is to you, but my battery doesn't drain like that. It's mostly the screen that drains mine, or being out of range (of a cell tower).
Have you tried stopping the Connect app? I'm guessing it won't be able to forward texts that way, but I've never used iOS.
You should be able to ride for several hours, take as many pictures as you want, use the maps on the phone, etc. You can carry a battery pack for your phone and even charge it in a jersey pocket while you ride, but you shouldn't have to.
Seattle Forrest is offline
Old 05-26-20, 06:16 PM
Steve B.
I was at 100% this morning, am at 97% right now, did a 2-1/2 hr. ride, navigating the entire way, Live Track working.
Steve B. is offline
Likes For Steve B.:
Old 05-26-20, 06:35 PM
blazin
Blazer of saddles, trails
Quoted: 106 Post(s)
Liked 22 Times in 16 Posts
I have my iPhone 11 connected to my Garmin fenix 6 all day. This evening, the phone reports Connect accounting for 1% of battery activity. I canít think of a reason why an Edge would result In different usage. Perhaps try restarting the phone and/or deleting and reinstalling Connect.
blazin is offline
Old 05-26-20, 07:08 PM
Koyote
Quoted: 827 Post(s)
Steve, that's a good data point. Thanks!
Before this morning's ride, I spoke with a Garmin CS person, who had no idea what is going on and wanted to "open a ticket." I declined. After all of the hassles with this thing so far, either this issue gets sorted out without escalation, or it gets returned for a Wahoo.
Then I went for a ride, and tried turning off the Connect App's cellular data, and after two hours my phone battery was down 8%...So, that's an improvement, but still not as good as your result. I did lose accurate (updated) weather data on the home screen, but I can live with that. Still not sure if I am okay with this app draining my battery at all, though.
Koyote is offline
Old 05-26-20, 09:56 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 2347 Post(s)
Liked 414 Times in 304 Posts
My system for Garmin use is to load a RidewithGPS route and leave my phone alone. The Garmin battery lasts a long time and I don't have to fool with anything, just ride my bike and follow the turn directions. If I want radar and I have cell service, I can stop and look.If I don't need directions, that's even easier.
Results matter
Carbonfiberboy is offline
Old 05-27-20, 12:39 PM
Steve B.
I follow the assorted bike websites as well as the Garmin 1030 forum and the 2 Garmin FB pages and can say I've never heard this complaint (all that means is you've discovered a new way for a Garmin to not function correctly). I've used 3 different Garmin's as well as a Bolt, had no obvious issues. I would look at user experiences on the Garmin forums for the 530 as well as the responses on DC Rainmakers site for the 530. IMO the 530 is as good a unit as a Wahoo and I prefer the color screens, so would hesitate to dump the Garmin for a Wahooo, especially as you;ve invested time getting it configured. That time spent has to get done allover again with a Wahoo.
I would suspect an issue with the GCM app itself, not the device, thus would literally dump the app and re-install. Don';t do an update, just get rid of it. Then re-do your BlueTooth configuration. It kind of sounds like an over-active data connection between the device and phone, thus the GCM is using a lot of processing and draining the battery.
Here's the Garmin process for re-doing the BT:On the phone and in the GCM app, from the My Day page, select the More tab.
Select Garmin Devices in Garmin Connect Mobile
Select the Edge 1030.
Select the 3 dots on the top right and remove the device.
Remove from Bluetooth settings in your phone settings.
Remove Phone pairing from Edge
  1. Go to the Edge 1030 Menu.
  2. Select Settings.
  3. Select Connected Features.
  4. Select Phone.
  5. Select Pair Smartphone.
  6. Select Forget this Phone.
Turn off the phone Bluetooth.
Turn off your device.
Select the More tab, on the lower right.
Select Settings.
Sign out of Garmin Connect Mobile.
Double tap the Home button on your iPhone (the round button the front) and swipe off all the applications.
Restart the phone:
Once your phone boots up
My addiction - Uninstall and reinstall the mobile app.
Turn on Bluetooth and make sure that location services are on.
Go to Connect app and sign in.
Select, Browse All Compatible Devices.
Select Edge
Select Edge 1030
Put the Edge 1030 into pairing mode.
  1. Turn on device.
  2. Go to the Edge 1030 Menu.
  3. Select Settings.
  4. Select Connected Features.
  5. Select Phone.
  6. Select Pair Smartphone.
  7. Select Continue.
In Garmin Connect Mobile, follow directions to pair
Steve B. is offline
Old 05-28-20, 01:47 PM
Koyote
Quoted: 827 Post(s)
Steve B. , thanks for that advice. I did actually do that a couple days ago - disconnected all of the BT links, deleted and re-installed the app, paired up everything again via BT. Still have the same issues. I even went into my phones settings and shut down everything related to Connect that could cause battery drain: turned off location services, turned off background app refresh, cellular data. And yet, while I am riding, there is still battery drain from the Connect app running in the background - which should not be possible given that I turned off background app refresh.
I'm at a loss here. Very frustrated.
Koyote is offline
Old 05-28-20, 01:56 PM
Steve B.
I'd turn on Cellular Data. The app maybe wants to find the mother ship so it can do LiveTrack, Notifications, etc.... Maybe it's constantly searching for that connection, kind of like a cell phone will do when there's no cell service, the battery drains as the device is constantly transmitting to get a connection. Just a thought.
Steve B. is offline
Old 05-28-20, 03:27 PM
Koyote
Quoted: 827 Post(s)
Steve, that hadnít occurred to me, so I will try it. I really appreciate your help!
Will let you know what happens.
Koyote is offline
Old 05-28-20, 06:34 PM
Seattle Forrest
Clarification: eye roll is for the rep. What you did is basic enough they can't not have tested it, I'm sure the results are internally documented in the suppot group, and the guy takes calls like yours all day every day. But he's never heard of it before.
Old 05-28-20, 06:45 PM
Koyote
Quoted: 827 Post(s)
Yes, and a quick search at a Garmin users' forum confirmed that is is a fairly common problem.
Sad to say it, but I have ordered a Wahoo Roam. We'll see how that works out. They are both from REI, so one will ultimately get returned.
Koyote is offline
Likes For Koyote:
