Bought 11 speed chain. Too loose?
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 05-27-20, 09:40 PM
InvertedMP
InvertedMP's Avatar
Bikes: Cervelo R3, Specalized Allez Elite, 2019 Scott Metrix 10
Quoted: 67 Post(s)
Liked 106 Times in 39 Posts
My road bike is 11 speed (sram eTap) and the sram 11 speed chain I bought seems significantly looser. Itís a quick link chain. I would have expected it to be sized. Iím guessing I need to take some links out?
InvertedMP is offline
Old 05-27-20, 09:51 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4586 Post(s)
Liked 1,174 Times in 700 Posts
Yeah, unless you have a goldilocks combination of rings and cogs, you're going to need to shorten the chain. My 1X bike uses a full 114-link chain, which is nice.
DrIsotope is offline
Old 05-27-20, 09:56 PM
Russ Roth
Quoted: 299 Post(s)
Liked 202 Times in 153 Posts
If by loose you mean too long then yes, you're supposed to size it to the bike. Two ways to do it, my preferred is to go small ring, small cog and have it so the rear der has the slightest amount of tension being put on it while still keeping the chain from rubbing against the der body. The other is to go big/big and have the der stretched as far as it can safely go. If your gearing is within manufacturer's spec either will result in a chain that can run all the gears without slack or damage to the rear der.
Russ Roth is offline
Old 05-27-20, 10:05 PM
InvertedMP
InvertedMP's Avatar
Quoted: 67 Post(s)
Iím not sure why I thought it would be sized 🤣🤣 thanks guys
Old 05-28-20, 05:38 AM
rubiksoval
Bikes: Felt AR
Quoted: 1897 Post(s)
Liked 377 Times in 184 Posts
Just take off the old chain, hold the new one up to it, then take out the appropriate links.
No need to remeasure a new chain on your bike.
rubiksoval is offline
Likes For rubiksoval:
Old 05-28-20, 06:18 AM
WhyFi
WhyFi's Avatar
Quoted: 12489 Post(s)
Liked 2,136 Times in 1,129 Posts
If you can't reference your old chain, use the big/big + 2 sizing method seen here (the 'easy' way, starting at 2:15) -
WhyFi is offline
Likes For WhyFi:
Old 05-28-20, 06:22 AM
shelbyfv
shelbyfv's Avatar
Quoted: 1576 Post(s)
Liked 787 Times in 478 Posts
May as well size it correctly per post #6 , at least the first time. You'll gain another bike mechanic skill.
shelbyfv is online now
Old 05-28-20, 07:23 AM
InvertedMP
InvertedMP's Avatar
Quoted: 67 Post(s)
Ok so avoid the RD pulleys, go big and big, wrap the chain and add two links basically...
Likes For InvertedMP:
Old 05-28-20, 09:02 AM
DaveSSS
Bikes: TWO Colnago C-RS w/Chorus 12
Quoted: 408 Post(s)
Liked 144 Times in 112 Posts
That gives you the shortest possible chain. I prefer to use the little/little method that gives the length that will work with the largest sprocket that the RD can handle. The chain is routed through the RD and around the small ring and smallest or next to smallest sprocket. When the ends of the chain are joined, the RD cage should swing forward slightly and the chain should not hang loose. If you have the largest possible sprocket on your bike, then both methods will produce the same result.
DaveSSS is offline
Old 05-28-20, 09:14 AM
topflightpro
topflightpro's Avatar
Quoted: 1508 Post(s)
Liked 234 Times in 156 Posts
IME, either method results in the same length chain. But I do find the Big-Big option easier to do.
topflightpro is offline
Old 05-28-20, 09:18 AM
Iride01
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 1320 Post(s)
Liked 311 Times in 240 Posts
Shimano gives very specific information in their DM's for sizing chains. 1x, 2x and 3x can be different procedures depending on the group. I'd think SRAM has similar info published too.
Typically and for many years, wrapping the largest front and back without going through the rear DR and then adding 2 links has been the standard.
New chains do come longer than needed because they don't know what you are putting them on.
Iride01 is offline
Likes For Iride01:
Old 05-28-20, 09:31 AM
yarbrough462
Pizzaiolo Americano
Bikes: 2021 Trek Domane, Bianchi Intenso, Trek Top Fuel, Trek Procaliber 9.6, Orbea Occam AM
Quoted: 189 Post(s)
Liked 29 Times in 12 Posts
Correct. Always best to read the DMs. The two link method will result in too short a chain on the new Shimano 12 speed MTB groups. Made that mistake the expensive way...
yarbrough462 is offline
Likes For yarbrough462:
Old 05-28-20, 11:07 AM
DaveSSS
Quoted: 408 Post(s)
The results will only be same if the largest possible sprocket is on the bike. Every 4 teeth smaller suggests a 1 inch shorter chain, using the big/big.
DaveSSS is offline
