Bike pump and tyre pressure.
Old 05-28-20, 06:20 AM
Dany6
Quoted: 11 Post(s)
I was wondering is there an air pump for bike with 7.5/8 bar capacity?
Because i visited 4 stores and they only had with capacity up to 7 bar.And is it possible to at those extra 0.5 bar with a 7 bar pump?to make it 7.5 pressure on my rear tyre.
And would i have any problems if i'd set it at 7.5 bar on a 25mm tyre with 13mm wheel,and i weight 82kg/1.92cm tall.
Dany6 is offline
Old 05-28-20, 06:27 AM
WhyFi
WhyFi's Avatar
Quoted: 12489 Post(s)
Liked 2,135 Times in 1,129 Posts
Are you talking about a floor pump for home use or are you talking about a mini-pump for use in the event of a flat during a ride?
Most floor pumps that you'd find at a bike shop will reach 8 bar without a problem, then the question becomes whether or not you actually need to go that high (you probably don't want to).
Many mini-pumps are advertised as going that high, but the reality is that you'll reach, "oh **** this - good enough," well before you reach the theoretical max of the pump.
WhyFi is offline
Likes For WhyFi:
Old 05-28-20, 06:35 AM
rumrunn6
rumrunn6's Avatar
Quoted: 3719 Post(s)
Liked 837 Times in 583 Posts
yeah, roadside, I prefer co2 to get to my desired max pressure
rumrunn6 is offline
Old 05-28-20, 07:01 AM
Dany6
Quoted: 11 Post(s)
Floor pump,i forgot to say that.
Probably i won't need 8 or above but if i'm planning to buy one that's a bit more expensive with better quality i guess then it's better to buy the one with 8bar or even 10,you know...just in case.
Dany6 is offline
Old 05-28-20, 07:45 AM
znomit
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Scott Sub 35
Quoted: 267 Post(s)
Liked 187 Times in 95 Posts
Most floor pumps got to 9-11 bar (130-160psi). I like to pump up to 130psi to seat new tyres but dial if back to 90 or less for riding pressure.
znomit is offline
Old 05-28-20, 10:47 AM
blacknbluebikes
blacknbluebikes's Avatar
Bikes: two blacks, a blue and a white.
Quoted: 66 Post(s)
Liked 52 Times in 26 Posts
At 72kg, I never ride more than 6 bar.
blacknbluebikes is offline
Old 05-28-20, 11:30 AM
eduskator
eduskator's Avatar
Bikes: TCR Advanced Pro 0 Disc
Quoted: 319 Post(s)
Liked 146 Times in 114 Posts
What kind of store have you visited...? The majority of floor pump can go up to 140-160PSI (10-11bar?)
eduskator is offline
Old 05-28-20, 11:35 AM
Dany6
Quoted: 11 Post(s)
Hardware stores,there's no any bike shop/store in area where i live.
Dany6 is offline
Old 05-28-20, 11:51 AM
GlennR
I'm Lost
GlennR's Avatar
Quoted: 1569 Post(s)
Liked 583 Times in 301 Posts
Amazon
GlennR is offline
