Good vintage centerpulls?
Quoted: 76 Post(s)
Liked 19 Times
Is there any reason to choose one model of Weinmann or Dia Compe or any other version of centerpull brakes or are they all about the same stopping wise?
Reason I'm asking is the local co-op has a big box of takeoffs and I was wondering if I should dig through it looking for some treasure.
Quoted: 741 Post(s)
Liked 818 Times
I have three types on different bikes, Weinmann, Universal 61 and Mafac Racers. I can't tell the difference in them. The Weinmanns stop the best, but probably because they have newish Koolstop pads. The Mavics have old hard Koolstop pads, and the Universals have few years old Shimano pads. In my opinion the pads make a bigger difference than the brand of caliper. I find the Mafacs a pain to adjust and set up, but they are the ones I'm least familiar with.
Quoted: 76 Post(s)
Liked 19 Times
My Finest has Weinmanns (now I'm second guessing myself) anyhow it doesn't stop very well. I just put some new Dia Compe pads on it, but the weather here has been horrible and I haven't got to ride it yet.
Quoted: 741 Post(s)
Liked 818 Times
I started using the Koolstop dual compound, (black/salmon color) pads since we had a lot of rain, too (for sunny California). I did a 50 mile rain ride on my newer Roubaix, and really liked how they worked wet, so I put a set on my Super Course, for Eroica, and no rain. I still like how well they stop.
Quoted: 823 Post(s)
Liked 1,395 Times
The MAFACs we all derided in 1975 are now Gallic cool; the Weinmanns we took for granted remain excellent stoppers make better with lines housing and good pads; I always heard Universals were a bit brittle, but bending ANY aluminum alloy brake arm for toe-in is probably a bad idea.
Dia Compe was a copy of the Weinmann, but I have a memory of someone writing that they were not as good - do they have the center bit that keeps the arms aligned and working symmetrically?
They all worked well with good pads and cables and housings....
Quoted: 76 Post(s)
Liked 19 Times
Here it's usually dry, but the wind gusts can shove you around a bunch. I just saw Kool Stop made pads pads for Weinmann, next time I order some parts I'll try and remember to grab some.
One word for you: MAFAC. They're the only vintage CP that's worth the trouble in my experience. Set 'em up with modern cables and pads and you're good to go (or stop!)
Quoted: 741 Post(s)
Liked 818 Times
I've been riding Universal 61s on my Legnano for 55 years, since new. Never had any issues with them, except now I use modern Shimano pads with the concave washer to adjust angle of pad to rim. I have the same type holders on my Weinmanns too. The Funky Mafacs have the cantilever type mounting stud, as stock.
Quoted: 76 Post(s)
Liked 19 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Best I ever had were Mafac Racers (with kool-stops) on a '79ish pkn10.
Those inspired some serious bombing down Seattle's hills.
Likes For SurferRosa:
Quoted: 5888 Post(s)
Liked 3,471 Times
Dia compes are a good choice for the OP's Fuji Finest as that it likely what it came stock with. I'd get a set of kool stop continentals and just ride the heck out of them:
https://www.jensonusa.com/Koolstop-C...caAmPXEALw_wcB
I like mafacs but they would not look right on a Fuji. It's your bike though.
Quoted: 76 Post(s)
Liked 19 Times
Next time I'm at the co-op I'll dig through the bin and see if I can find a set or two. It'll be worth the few bucks it costs me to get a set of Mafac or Universal if they have any.
Quoted: 76 Post(s)
Liked 19 Times
I went and looked and it does have Dia Compes on it. I do have a set of Schwinn Approved Weinmanns sitting around though.
Liked 3,471 Times
The weinmann or mafacs are not much of a trade up from the dia compe. I'd just focus on making sure they are well adjusted and then go with a quality brake shoe like the kool stop and good quality brake cables and housing. It will give you plenty of stopping power.
Likes For bikemig:
Quoted: 741 Post(s)
Liked 818 Times
I prefer to use the modern, slender, but slightly longer pad holder and pads. These have a washer that allows the pad to angle a little from parallel to the rim. Stops better, and reduces squeal with a little toe in.
These are Shimano pads and holders.
Similar Koolstop holders and dual compound pads.
These are Koolstop black pads on original type Mafac mounting studs, came with the bike, no idea how old they are. Sanding them a little helped squeal and improved stopping. These work great with Campy aero levers.
Likes For Slightspeed:
Quoted: 767 Post(s)
Liked 1,898 Times
I know they have their fans, but I don't like Weinmann or Dia-Compe centerpulls at all. The arms are way too flexy for me. If you search you'll find that some riders add a booster, or solid link, between the two pivots to try and stiffen them up.
The only centerpulls I like are Mafacs. They are, by far, better than the others (for me). Serious stoppers.
I'm sure some forumites have old Dia Compes that could be checked...
Hmm, I've always found that MAFAC CP brakes had much more flexible caliper arms. I've tested this on the brakes I own. Pretty obvious difference.
I really like both the Weinmann and MAFAC design. They are just different: Ford vs GM. I've come to prefer Weinmann/Dia/Gran-Compe CP brakes myself. I used to like MAFAC better. I'd still give MAFAC the edge WRT stopping power, but I prefer the modulation of Gran Compe.
Stopping power is mostly a matter of the pads anyway.
Likes For Salamandrine:
Quoted: 790 Post(s)
Liked 1,769 Times
I have found both Mafac and Dia-compe work great with modern pads nicely setup. Dia-compes are easier to setup and work on and they work nicely with basic relatively cheap MTB style pads that allow for toe in adjustment. The Mafacs have the advantage of being nearly fully adjustable so the can be setup to work nicely with pretty much all brake levers I have even setup them up with modern brifters and got great results, but because you have to fairly accuretly adjust a half dozen things they can be difficult to setup without a real good understanding of brake mechanics and practice.
One big tip to make life a lot easier when running center pulls is to get some nice cable hangers with barrel adjusters and quick release mech's which makes setup and wheel removal alot easier.
Quoted: 767 Post(s)
Liked 1,898 Times
Really I really like both the Weinmann and MAFAC design. They are just different: Ford vs GM. I've come to prefer Weinmann/Dia/Gran-Compe CP brakes myself. I used to like MAFAC better. I'd still give MAFAC the edge WRT stopping power, but I prefer the modulation of Gran Compe.
Quoted: 76 Post(s)
Liked 19 Times
My Finest has modern brake levers with a quick release plus the flip up quick release on the stem hanger and you are right they will open wide if I use both at the same time.
Quoted: 1372 Post(s)
Liked 1,752 Times
I have tried several different center pull brakes, including Weinmann, Universal, Shimano, DiaComp and Mafac. Mafac wins in my book. Not only do they stop well, but they are more user friendly to set up since the pads can be pivoted to allow for proper toe-in...
Quoted: 4806 Post(s)
Liked 3,932 Times
My Mafac joke for years was: $50 nearly NOS Mafac Racers are out there. You just have to remove and dispose of the attached Peugeot UO-8.
Very good brakes. Probably the only brake that had both the reach and stopping ability to stop the thousands of steel rimmed UO-8s in the rain. (Yes, stopping was a slow process but they did stop.)
Ben
Ben
