180mm rotor- do I need a spacer for my brake caliper?
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
I’ll be building my Slalsa Fargo as soon as the frame arrives. Bought TRP Spyke brakes (flat bar bike) and will be mounting to the Firestarter fork. To properly space out the brake from the typical 160mm rotor spacing to 180mm, will I need some sort of spacer? Does TRP make standard parts for this?
thanks.
thanks.
Likes For tyrion:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
"Industry Standard". That's the kind with the flat metal part at the bottom of the fork that the adapter bolts to. Then the calipers bolt to the adapter. All I.S. mounts need an adapter of one size or the other.
Likes For tyrion:
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I.S. is post mount, but it's the post mount type that needs the dogbone shaped adaptor, as opposed to the post mount that has conical washers that sit upon posts with long bolts to hold it all together.
You'd want to buy an I.S. adaptor for 180mm. As noted above, very standard part. Front & rear require different adaptors...180 front=160 rear or some such thing. Maybe I have it backwards.
Likes For base2:
Non omnino gravis
You want a post mount to post mount +20 adapter, like this one from Shimano. There are others from other brands, any +20mm most mount adapter will do.
What IS mount adapter you need for the rear depends on the OEM size of the rear rotor. The mount will look like this, but you can't always trust the description. If the bike "natively" takes a 140mm rear rotor, you would need a 180mm adapter (essentially a +20) to mount a 160mm rotor.
Likes For DrIsotope:
Quoted: 198 Post(s)
Liked 332 Times
Thanks everyone, this all makes sense and confirms what I had expected. Just wanted some confirmation before I purchased components.
A free beer to everyone who responded
