Good bike to get for wife?
Bikes: Trek, Schwinn, Huffy
Quoted: 101 Post(s)
I have been enjoying going on bike rides with my wife, but um trying find right bike for her is an issue. I have a used steel Schwinn mountain bike I have her ride and sometimes I have her ride my hybrid Trek Bike. She unfortunately has problems with both bikes. Her problem with the hybrid is it kind of built more like a road bike. I Personally love the bike, got up to 20 mph on it for 3 miles and can ride it at 15mph+ for over 20mph, but she doesn't like how much she has to lean over on the bike. It hurts her back. She has an easier time with it though because it is lighter than the mountain bike, aluminum frame very light easier to handle.
The mountain bike is heavier for her, she falls off of it because of the weight of the bike. Sometimes when she stops or gets off bike she can't hold the bike like she can the lighter hybrid trek bike I have and falls. However She likes the Mountain Bike better than the Trek Hybrid because it has a more upright riding style. Her back is straight riding the bike, it doesn't have the racing style the hybrid Trek has where you have to lean over. So she says the Schwinn mountain bike feels a lot more comfortable on her back. The problem with the Schwinn mountain bike is the weight of the bike.
She is just getting into bike riding and I noticed has a hard time with controlling her balance on the bike. She looses her balance easier on the heavier Schwinn Mountain bike, doesn't have much strength to hold the 45+ lb bike up and has fallen 4 times off that bike. She has not fallen once off of the much lighter Trek Hybrid Aluminum bike I have, but she says the bent over position of the bike really hurts her back a lot. She doesn't have a lot strength, especially when it comes to balancing strength which is required riding a heavier mountain bike.
I been wondering about maybe getting her a Cruiser for her, but a lot of them are heavy 45+ lb bikes and they have coaster breaks which I am worried she would have a hard time getting use to. She is use to the regular hand brakes.
Any advice? I enjoy bike rides with her but I hate to see her keep falling off my Mountain bike or suffering back pain from the Trek Hybrid I got?
Im thinking a lightweight Cruiser might be best? Any advice type bike to get for her?
Quoted: 1062 Post(s)
Liked 665 Times
Let her figure it out?
Could be that the hybrid is just the wrong size for her. Also, some hybrids have adjustable stems that allow you to change the riding position to your comfort. And bike makers have been working on bikes with comfortable geometry that are still reasonably lightweight. Simply browsing through a few bike shops might give her an idea of what might be possible.
Edit: A relative of mine has one of these, and is quite happy with it:
https://www.purecycles.com/products/pure-city-bike
It's 32 pounds, which isn't super lightweight, but has a nice upright riding position. I've seen the bike, and it seems to be of decent quality.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 332 Post(s)
Liked 205 Times
Go to a shop or three, listen to their advice, and let her make the decision.
Your marriage will be happier for it.
Quoted: 101 Post(s)
It looks like a nice bike. something like that but lighter in weight. I think a woman's bike would better for her. She has a hard time for some reason lifting her leg over the men's bar at the top and falls, even though we are close to same height. For whatever reason she has a harder time lifting her leg over that top bar than I do. So maybe a women bike with the very slanted bar which makes it easier to lift her leg over the metal bar to get off the bike would be easier for her. Maybe it is just the way a woman is built I don't know. She has a harder time with her wider hips lifting her leg over that high bar at the top, lol. She also is light only 100lbs so a 45 lb bike is a lot weight for her.
Bikes: 2017 Trek DS 3 / 2016 Felt Z85
Quoted: 7 Post(s)
The cruiser type bike's you mentioned may be her best option.....Felt has 7 speed Bixby Womens 7-SP - Felt Bicycles for modest cost along with a wide variety of others to choose from.....could be a good starter bike for her. With the step through type bike the weight may be less of an issue.....
For people lacking the strength to hold a bike up when it leans over the key is to keep it upright. I'm guessing that neither bike is a step-thru so she has to lean it over to get on or off?
A Workcycles Gr8 would likely be a good option for her. These are quite popular with a wide variety of people but particularly for smaller women. Easy to get on and off and easy to manage. They're fun and efficient to ride. She'd likely find that she can ride farther and in more comfort on a Gr8 than either of the bikes that she's been riding.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I'm usually not the first person to recommend going to get a bike fit, but this seems like a problem that could be corrected with a bike fit. (If you're on a strict budget or more DIY, a bike fit calculator such as this one can be a good starting point.)
I've had heavy steel MTBs, and they are definitely not speed demons. The hybrid (or even a road type bike, such as a touring, gravel, or "adventure" bike) seems better for the type of riding you're describing, but pain is a good indicator that the hybrid does not fit your wife correctly. It's possible that the frame is the wrong size (even if you're the same height), and even if the frame is the right size, a number of other adjustments could improve comfort.
Maybe an upright bike is the right option, maybe it's not. Either way, a properly fitting bike will be easier to control, will not cause unnecessary pain, and will be much more fun to ride!
Perhaps the same model you have in in a women's model and a size that fits her. If you have a Trek FX, they make a stagger frame that might work (https://www.trekbikes.com/us/en_US/b...olorCode=black ). You might also add a stem extender to give her a more upright stance.
Hope this helps,
Penny
Hope this helps,
Penny
2011 Trek Madone 5.2 WSD
2009 Trek 2.1 WSD
2009 Trek 2.1 WSD
Advocatus Diaboli
Quoted: 4717 Post(s)
Liked 1,526 Times
Not sure it's a "cruiser" or a "city" bike style you'd probably be looking for. I think City would make more sense, eg. something along these lines.
https://www.liv-cycling.com/us/flourish-2-2018
We just bought my wife a Raleigh Venture a few months ago and she loves it.
She likes that it has a step thru frame so it's easier for her when she stops.
https://www.raleighusa.com/venture-step-thru-3480
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Crank Forward Bike
that allows her to stop with both feet on the ground while seated. Have several bike shops help her to find a comfortable solution. You stay out of it, only insofar as you can encourage, take her around, and listen. Don't offer your own opinions, as you're likely to mess it up. Let her decide.
Helpless Bike Fiend
Sean Kelly would answer: get a new wife
<this is a JOKE, so try not to be so literal>
Never give a gun to ducks No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
All of this. It is not your bike, it is hers, the only thing you should be offering is support (and if buying used, maybe opinions on monetary value and condition). Trying to guide her decision will result in a bike you want, not a bike she wants, and probably wind you back up in the same position. Just showing up with a bike you think she will like is even ten times worse than that, and really guaranteed to get you nowhere.
Quoted: 75 Post(s)
Have her test ride an Electra Townie. I personally don't much like them, but I can see how someone who is having trouble with other styles of bikes might like a Townie.
Bikes: Serotta CRL, Litespeed Blue Ridge, Bacchetta Ti Aero, Cannondale delta V, 67 Schwinn Sting Ray stick shift.
Quoted: 26 Post(s)
Liked 7 Times
Bike for wife? Good trade!
Quoted: 101 Post(s)
Yeah I am thinking maybe a Cruiser from Schwinn. My mother bought a very nice Cruiser used from a Schwinn Bike shop. I might look into that. Have my wife test ride it. Or I might see if can raise stem on the Hybrid I got so she isn't leaning over bike when she rides and it doesn't hurt her back.
Bikes: 2017 Felt VR 40, 2017 Felt Versa Speed and 2017 Cannondale Adventure 2
Quoted: 20 Post(s)
Purchased a Cannondale Adventure Women's 2 for my wife in June '17. Replaced a Nishiki from Dick's Sporting goods. Took to her to local bike shop that carries Cannondale, Felt and BMC and had her try a couple. The Cannondale worked for her as she went through the process of being fit. She is not a long distance rider 10 - 12 miles is a big ride for her, but she enjoys it. I have a Cannondale Adventure 2 as well and use it when I ride with her and ride my Felt VR40 for long distances.
Check out several shops and models before purchase...
Bikes: Old Raleigh Super Course Marin Pine Mountain Surly LHT
Quoted: 28 Post(s)
As others have said, go to a bike shop and let her look at, test ride, and decide on her ride.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 595 Times
And whatever you do, DO NOT get her a 45 lb bicycle!!!!!
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Sunshine
Quoted: 10902 Post(s)
Liked 7,393 Times
Go into a few shops. 1 that carries Giant among other brands, 1 that carries Trek among other brands, and 1 that carries something else major(Specialized, Jamis, etc).
Then let HER pick out what feels good to then test ride.
The way this sentence from your first post reads...well i hope its just poorly worded. Dont have her do anything. Instead, work with her to find what she likes.
"I have a used steel Schwinn mountain bike I have her ride and sometimes I have her ride my hybrid Trek Bike."
Also- raising the stem on the hybrid could work, but perhaps a properly fitting bike to fit her comfort and riding style would be best.
