29 plus Wheelset for 350 LBS? (Surly Krampus)
I things I’m going to pull the trigger on a Krampus complete. I’d like to get a good strong versatile wheelset to swap in.
thoughts?
thoughts?
Maybe look at ebike rated wheels. They're usually rated for more weight due to their more robust build to cope with the elec motor torque
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Have your shop hand tension the stock rear wheel and ride it.
Likes For c_m_shooter:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Prowheelbuilder.com can build that.
Pick your price point on 40 hole hubs: https://www.prowheelbuilder.com/hubs...y/40-hole.html
+1 on trying the stock rim with a conversation from a good wheelbuilder.
Here's my story:
In 2008, we were getting started riding; I was 285# and the rear rim of my Giant Cypress DX started popping spokes not long after buying at a large/fancy bike shop where I felt like I wasn't the target audience. There was a smaller shop a mile or so from work, so after reading here on BF.net C&A folder, went there and expected to have a conversation about building up a tandem wheel.
An older gentleman, graying beard and a well worn apron said: "We can do that if you want, of course, but let me try to rebuild this for you and see if you come back." He replaced all spokes with a more robust profile (with a brand that now eludes me), used my stock rim and hub, and made sure everything was properly tensioned and trued. I got a few tips about how to mount and dismount safely (both feet on the ground, straddle the bike, do NOT push off and then swing a leg over while rolling). While the bike has been mothballed the last many years, I never had to go back.
(However, I /did/ buy my NEXT bike there as they'd earned my business).
Here's my story:
Likes For Zoxe:
https://www.velocityusa.com/
Quoted: 1097 Post(s)
Liked 1,036 Times
Doubt you will need to go 40h, 36 should be sufficient but go with a butted spoke that is 13g at the elbow. Something like the cliffhanger as mentioned above will help a lot though for true plus size tires you might need to look at the blunt 35. Just pair it to a good hub. Personally if I'm building wheels as an upgrade I will start with an XT hub for MTB/Cross/Gravel; shimano doesn't make "wow" factor hubs but the XT or XTR are top quality and reliable. They are built to a better standard and worth the extra money though at XTR pricing I'd start looking at White Industry perhaps.
Velocity Cliffhanger rims (36 hole front, 40 hole rear) and Sapim Strong spokes.
Two wrongs don't make a right but three lefts do! Unknown
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,111 Times
I wonder if you might be better off with a bike made for loaded touring like an ECR.
DT Swiss's "Hybrid" line of wheels is, in spite of its name, for e-bikes. They have strengthened versions of the hubs with thicker shells and steel freehubs as well as stronger spokes. The 1700 wheelset has 350 hub,s 28-spoke wheels and 30mm rims that are a little skinny for plus tires (2.8 or 3 in), but would be fine with 2.4-2.6 tires. The more premium 1501 version has triple butted spokes and 240 hubs. I've been following this stuff because E-MTB stuff has found favor for MTB tandem use; MTBTandems makes plus wheels based on the 36 spoke high flange version of the 350 hybrid hub.
On the other hand availability of anything this year might be difficult.
Genesis 49:16-17
Genesis 49:16-17
Like some guys said, try your wheels...you may never have an issue, give it a good couple rides, run her up to a trusted shop with a wheel guy and let him check spokes....I'd try this before dumping a grand on a set of wheels
Likes For Chad991:
Quoted: 770 Post(s)
Liked 1,765 Times
When I started riding, I was 375 and was riding on a Trek 7300 hybrid that had the stock wheels which were 32 spoke box rims. Nothing to write home about. I rode them as I lost my first 50 lbs. I had an issue with a few spokes, but the shop hooked me up and re-spoked with better spokes and did not have an issues with the wheels after that. I eventually decided to lighten up the bike a little and got a set of Velocity Deep V's which were fantastic. I agree with others, have the shop check the wheels and ride them first. You might be surprised.
Thx guys. I’m just going to ride the stock stuff and cross my fingers till it calls for my attention
Likes For TourDeHood:
