Tow a bike with another bike?
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
I've heard of people having clever methods for towing a dead bike with another bike. I'm picking up a used bike tommorow, and am temporarily car-free. I don't currently own a trailer (though I'm in the process of building one), but I do have a bike with a standard rear rack, and a bunch of bungees.
Any advice for transporting the dead bike about 5 miles, using only another bike?
Thanks!
Peace,
Sam
Thanks!
Peace,
Sam
Sophomoric Member
Ghost riding is when you just hold the dead bike with one hand on the bars and steer and brake your good bike with the other hand. Usually you go slow on the sidewalk or a side street. I don't think I'd want to do it for 5 miles. Can you take it by bus? Walk it?
Likes For Roody:
Go Fast.. Go Fixed!
Bikes: Marinoni Squadra Fixed Conversion, Eatern Woods Research "Original Woods" MTB, Eastern Woods Research -Modified Trials (20" wheels), and a home made Chopper.
I know a local shop owner put a bike rack on his BOB trailer to bring dead bikes in to his shop for customers that were carless. Since your trailer isn't ready, I wonder if mounting a velo vice type bike fork mount on a rear rack would allow the rest of the bike to track behind you as a trailer. Then you just have to bungee the front wheel on the frame of the trailed bike.
Bikes: .
I think you may be able to come up with a way to attach the front wheel of the dead bike to your rack, maybe to one side, bring lotsa bungees, and then can keep both hands on the bars of your live bike and ride. The combination will probably handle like a pig but will be better than trying to steer with one hand and lead the dead bike with the other.
Bikes: 2004 Martin Novato w/ 2004 Burley Nomad
I would take the wheels off, you can put them on your handle bars, brake down the handle bars, brakes, peatles, seat and seat post and put them in a backpack and then put frame on the rack with the bungees. If you nothing else you can make more then one trip.
Good Luck,
Geek
Good Luck,
Geek
winter is comming
Bikes: Mikado kensington 2003, "commuterized" 8yr old Mongoose hilltopper SX, Baycrest Hurricane 10 speed
I asked the same question around a while ago, and there doesn't seem to be anything that is made specificaly for that. Here's the link : https://www.bikeforums.net/archive/in...p/t-69048.html
contrarian
Bikes: 80's ross road bike/commuter, 80's team miyata, 90's haro mtb xtracycle conversion, koga mitaya world traveler
The xtracycle kit has a setup specifically for this (the tray bien) but even with just an xtracycle this is a cinch. I've done both though it is pricey, I think it's worth it by far.
https://www.xtracycle.com/html/home.php
https://www.xtracycle.com/html/shoppr...products_id=71
Higher ground for the apocalypse!
winter is comming
oh wow!!!! This is definatly making me want to buy an xtracycle...
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
Maybe you can take the bus/walk/run to the bike? Or does dead bike mean unridable? If its unridable, is it untowable?
Al
Al
Spoked to Death
xtra cycles are definately cool, but out of my price range, and they won't help me on today's project. I'll probably attempt to build my own xtracycle-like creation one of these days. I rode on the back of someone's at Tour de Fat recently, and it was really nice.
I think, after combining some ideas I've been reading here, that I've got a solution. I've taken a bare front hub and very securely tied it to my rear rack, nestled up close to the seat. I'll take the front wheel off the dead bike, and attach its fork to the hub on my rack, so the rest of the bike trails behind, rolling on its rear wheel (which does roll). The front wheel I'll bungee to the dead bike's frame.
If it works, I'll post a picture for other people edification. If it doesn't work, I'll figure something else out, or lock it up somewhere on the way back, and then walk back and pick it up by hand. However, its over 90 degrees out right now, so I've got an incentive to spend as little time outside as possible.
Wish me luck.
Peace,
sam
Wish me luck.
Peace,
sam
Spoked to Death
Well, to report back, my method was a failure. I had tied a hub to the rack, then devised to attach the fork of the towed bike to that hub, and tow it home. Unfortunately, despite my best efforts, I couldn't get the system rigid enough, and the bike would flop to the side as I would begin to turn. It was just too big of a lever arm for me to keep stable.
I think the idea would still work, but it would have to be a very beefy system connected directly to the frame of the towing bike, and it would have to be very rigid. Mounting the fork of the towed bike as low as possible will also help.
I ended up ghost riding the thing home. After a few miles, I got pretty good at it. My greatest achievement was when I was cruising down the road at about 15mph with this bike to my left side, and using my right hand to control my right brake (which is my front). I saw a big dead fox in the shoulder, and I didn't have enough shoulder space to move to the left, and the curb was on the right. So my bike went right, and the ghost bike went left, and I rode both bikes, with about 40% of my weight on the ghost bike, straddled out over the fox, and skimmed over it, each bike rolling about an inch away from it on each side, with me precariously dangled overhead. Scary, but fun. If I ever hold a race, a 'ghost race' will be part of it.
Thanks for the advice, folks. When I get this trailer together, I'll work out some provision for easy bike hauling. I may even investigate modifying a more heavy duty rack for true towing abilities.
peace,
sam
PS: My prize is below. '77 Raleigh Grand Prix Mixte, in great shape.
peace,
sam
Sophomoric Member
Sounds like a fun ghost ride! Your story reminded me of the old westerns, when the hero would ride his horse alongside a stagecoach, then stand on his horse's back and straddle over to the stagecoach. Then usually he sould take the reins from the coach driver, who had been shot, and stop the coach just before it went over a cliff.
Well, your ride over the dead fox was a littlebit like that, wasn't it?
Big Member
Bikes: Old School Centurion IronMan Expert, Homemade FrankenFixie
I had tried to bring a bike home once ghost riding. It sucked. So after a mile I just tied off the front wheel to the down tube and strapped the bike to my back. I just made sure the crank/pedal tward my butt was at 6 o'clock.
it's only been 6 years since anyone replied, but if by chance someone stumbles over this like I did:
Here is a possible solution: https://www.biking.com/buy-bike-accessories/tow-bar.html
It's called a tail-gator. I've been wanting something like this for a while. Connect my son's bicycle to mine, ride mine - towing his to his school. "pick" him up, and the two of us ride back home.
In the right lane
Having another gadget hanging around just to move DOA bikes seems like overkill. You'd probably only use it once every two or three years.
When I have a dead bike, I usually ride somewhere to get a part. On another bike.
If I can't do that, the bus has racks.
Accidentally locked 2 bikes together without a key one time. I had to throw one over the handlebars and ride the other.
Full story here:
https://www.alternativecommutepueblo....dx-part-2.html
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
I think that to tow a bike properly, the front axle has to be at approximately the right height. If you try attaching the fork to a rear rack, then this places the headset at a steep angle which will shift the balance of the following bike in an unstable manner when trying to turn.
Mark
Mark
This is, of course, generally only applicable to people with long tails, but we regularly haul bikes to and from the shop with our Kona Ute. Can't carry two kids while hauling, but we can still carry our daughter. We just make sure these runs take place while the older kiddo is at school or both parents are home.
I tried this w/my vintage MTB with Surly nice rack: just strapping the front wheel to the rear rack. I used bungee cord and some simple straps to keep the hub snug against the rack, you have to be careful to only strap the front wheel so it can pivot on bumps.
Riding is a bit weird, but it works pretty well overall.
https://www.instagram.com/p/BNpTUNYh...-by=explora_me
Quoted: 1074 Post(s)
Liked 295 Times
I don't transport bikes with bikes often enough to merit the effort of being particularly clever about it.
If ghost riding isn't an option, due to distance or condition of the bike, I'll remove the wheels and strap one to each side of the rear rack.
Then the frame - preferably with one pedal removed - goes onto the outside of a (climber-inspired) backpack with plenty of attachment points, more or less vertically.
If the bike has a threadless headset, I may pull the fork and bars too, and stick them in the backpack to make it less top heavy.
For rideable bikes, my preferred method is to travel to the bike on inline skates, stick the skates in a backpack and ride home.
That last instagram shot was super cool, wish we had details!
This old thread was actually one of the ones that inspired me a few years ago to solve this. I finally wrote up my solution -- I made a DIY version where the second bike does not need any disassembly and won't fall over. I hope this helps you guys!
Blarg it won't let me post a link, sheesh or even a photo, but you can google "mschausprojects tow" to get all the details and parts list. Wish I could show more clearly here but I don't have many posts. Maybe someone else can post the link
Likes For chimike:
