Bianchi Serial Number Identification
#1501
Quoted: 4722 Post(s)
Liked 3,036 Times
Good afternoon
After a long search I recently purchased this Bianchi pista/track frame. I am now looking to try to establish what model the frame is and what tubing it could be. The BB is Italian with 27mm or 27.2 mm seatpin diameter.
would also like to establish the date it was made. Any assistance is appreciated.
The serial number on the BB looks to be E . 007
Here are some pics.
Here are some pics.
#1502
Bikes: Colnago Mexico, Holdsworth, Zini, Alpina, Gemini, Colnago Master Pista, Colnago Master xLight, C40, Dream Lux, Vitus Dural 797, Vitus Carbone 3 KAS team replica, DHC, Viner, Vitesse, Alan, Bianchi, Cinelli, Paletti, Basso, Benotto, Dancelli, FW Evans
Quoted: 7 Post(s)
Liked 11 Times
Apology, I should have mentioned that I am in South Africa and the Bianchi would have been imported from Italy.
Thank you for your input T-Mar, it is always appreciated.
#1503
Bikes: One beautfiul bianchi (additional information pending)
Yes, I found your photographs and they support 1986. A 1971-1972 would not have water bottle bosses, an investment cast seat stay bridge for recessed brakes or short Campagnolo dropouts. All these features are very hard to change without great cost. The most modern feature are the Campagnolo non-Portacatena, short dropouts, which makes it no earlier than mid-1980s. The 'B' within a circle embossing on the seat stay caps carried through into the late 1980s.
Components also support the era with an aero style crankset (introduced early 1980s), post CPSC (1978+) Campagnolo components, 1978-1987 style Columbus decal and Modolo Speedy brakeset. It looks like the rear wheel, or at least the quick release skewer is a replacement.
The x.x segment of the serial number is the date code, with the numeral indicating the calendar year. Sometimes, we see some European models with two numerals. Regardless, since both are '6', it indicates 1986 manufacture, as frame features indicate it is not from the previous decade.
What is difficult to identify is the model, as specs and model names were often market specific and I have little knowledge of the German market models. However, the mixed Italian components are typical of Bianchi mid-range models of this era.
The serial number identification has certainly helped narrow down the process, now to learn about the European bicycle market of the 80's.
Any suggestions on how to get started on that?
#1504
Ageing Warrior
Recent Acquisition
Hello all, first post so apologies if a little dull. I recently acquired a frame that purports to be a Bianchi and the only other i.d. is that of the (rather hideous, in my opinion) Caurus paint job. Why the obvious needed its own decals is beyond me. The only stampings that I can find are '58' and 'F.301' , both on the bottom bracket.
Until about 30 years ago, I put in many thousands of miles here in the U.K. on a variety of decent machinery so I have been out of the loop for some time and worked in inches rather than cm (odd furrin language that it be).
Any info as to model, year and original equipment would be most appreciated. I would post pictures but the site will not allow me to and, when I tried to, it lost the text too. Rats!!
Cheers.
Cheers.
#1505
Ageing Warrior
Addendum
Having previously hunted all over for clues, I rather gave up on thinking that it might be something even half decent and thought that I would just make it into a usable parts-bin hack.
Further poking of the mass of quivering, gelatinous and often baffling information has thrown up, for a number of reasons, that it is most likely to be a Proto from around 1990 so. Odd that Bianchi would bung the same paint job to their decent machinery as well as their lower-end jobs but, being married to an Italian, I know that, as Tennyson informed: "Ours is not to reason why".
Time to hunt down s/h Campag Record parts & Delta brakes.
Anybody spare a tenner? Will dance for money, knot sausages or clean vacuum cleaners with tongue, no legal job refused.
#1506
Liked 3,036 Times
Link to photos; https://www.bikeforums.net/g/user/536358
#1507
Unknown Bianchi
Hello. I'm new to this forum and not really sure how it works, but I have an oldish Bianchi Eros I'd like to find more information about - i.e. how old is it and how much is it worth. It's been sitting unused in my dad's (dry) garage for decades - I guess since the 80s or 90s. It was bought in the US and has all its original parts - it has not been used very much - my guess is it has done less than 1000 miles in total and so it's nearly new condition, although i think it used to have its gear shifters on the down tube which have been moved to the handlebars at some point... Please can someone help? I can provide more details and pictures but i'm not sure what's relevant. Many thanks in advance...
#1508
Bianchi Serial Number Help
Hello all: assistance with Bianchi identification. Most interested in year and tubing such as Columbus SLX.
Numbers appearing on bottom bracket: 7F 5782-- is otherwise typical non-descript celeste Bianchi. There is no tubing type sticker (restored)
#1509
Bianchi Eros ID serial number
#1510
Liked 3,036 Times
The serial number is indicative of a 1987, Italian manufactured frame. I see that you are located in the USA. so it likely an American market model and therefore no lower than midrange. However, that still leaves a wide range range of models and about four possible tubesets. Photos would help to determine the info which you seek.
#1511
Liked 3,036 Times
The serial number format is consistent with Hodaka of Taiwan, a known Bianchi source during the very late 1980s and into the 1990s. It indicates very late 1995 manufacture, so it should be a 1996 model, which was equipped with Campagnolo Mirage and available in dark blue or red
Value is highly dependent on condition, so we'd need to see photographs. There is a separate C&V forum for appraisals.
#1512
Thanks very much for this. I can confirm that it's equipped with Campagnolo Mirage, but it's celeste green - not dark blue or red? And unfortunately as a newbie to the forum I am not allowed to post photos?
#1513
Liked 3,036 Times
The colour difference is almost certainly market related. After you mentioned it, I checked for your location, which it turns out is in the UK. Most forum members are from the USA and the colours I stated were for the USA market. Unfortunately, I don't 1996 UK Bianchi literature but colour differences between markets are very common.
Your location will also complicate an appraisal, as market selling prices can vary significantly from country to country. I'm not sure how many members would be comfortable offering an appraisal for a bicycle in the UK. Personally, I wouldn't be comfortable suggesting a selling price.
#1514
Again, thanks for all the info - that's great. The bike is actually from the US originally - my dad brought it back to the UK with him - though this doesn't tally with your explanation about colour?
#1515
Liked 3,036 Times
I went back and double checked my USA reference material. The Eros was offered in forest green and red in 1995 and dark blue and red in 1996. The frame was definitely celeste in the pictures, so I went back to them, to see if I could pick up any other clues. First, I noticed that the cassette was 9 speed. Mirage with nine speed wasn't introduced until the 199 model year. Next, the Mirage components were black and that didn't occur until the 2004 model year. Finally, the tubeset, is Reynolds 631, which isn't mentioned in the specs until 2005. The specs change to 10 speed for 2007, so we're left with 2005 and 2006, both of which had a celeste option. Both years are spec'd almost identically, with the major difference being MAVIC rims in 2005 and Alex rims in 2006.
So it appears the initial assessment was off by one decade, which is easy to do with serial numbers and why photographs are so important. An overall photograph of the bicycle would have made this readily apparent via other features, such as a threadless stem and headset. Also, the reference to it originally having down tube shift levers, was a situation more likely to be 1990s than 2000s. According to the specs, both the 2005 and 2006 had Ergopower brifters as OEM.
Finally, the earlier reference to Hodaka manufacture may be erroneous. While they were a known Bianchi source in the late 1980s and early to mid-1990s, I can't verify that they were still used in the mid-2000s. The similarity of S/N format could be coincidence. However, if the country of origin decal is Taiwan, then they would still be the leading candidate.
#1516
Thanks so much for all this info and your time. I'm very impressed! Pretty sure it's the 2006 model with the Alex rims - apologies for unintentionally leading you down any garden paths. And yes, it has a sticker that says it was made in Taiwan. I've tried adding a picture of the full bike to my gallery for completeness/posterity. Many thanks again!
#1518
Liked 3,036 Times
The Rekord 920 was a European model. The 1987 versions that I've seen have used Formula One tubing and Campagnolo Victory groups. The subject bicycle has Formula Two tubing which is one grade lower. I don't know the European model but Formula Two tubing and New 600EX components were used on the 1987, USA market, Bianchi Limited.
#1520
Liked 3,036 Times
#1521
Bikes: Cervelo R3. Campagnolo Chorus. Fulcrum Racing Zero.
Hello BikeForums Family,
I need help identifying a frame. I’ve spent the past few days trying to do so but my findings cancel each other out. Any help any of you can provide is much appreciated.
Purchase:
The bike was bought in Melbourne (Australia) in late 1997. From memory I was told it was of Italian origin, which is supported by the Made in Italy sticker encircling the bottom of the seat tube. I recall there was a groupset change, but it was between two Veloce groupsets - the 1997 8-Speed version and the new 1998 9-Speed alternative - and not between different Campagnolo tier offerings. So at this point I don’t know if I purchased a bike or spec’d a frame and groupset. And, unfortunately, I don’t have the purchase invoice.
Tubing:
Dedacciai. Zero Tre. Tubi Alleggeriti A. Sezione Variabile. 25 Cr Mo4. Micro Alloyed. Engineered for Bianchi.
Headset, Stem & Bars:
Miche Headset. 3TTT Chromix stem branded for Bianchi. 3TTT Podium bars.
Best Guess:
Using the Bicycle Blue Book website, my first guess is either a 1997 Bianchi Eros (2) or Campione d’Italia. The groupsets don’t line up, as both come with Mirage, but the headset, stem and bars match perfectly. Online photos, however, show both bikes with their names along the top tube. My bike has no model designation. Instead it features ‘Bianchi’ on both sides near the headset, and a signature on the drive side near the seat post.
Serial Number:
My bike has serial 59E2010C which suggests build year of 1992, but the seat tube features two Dedacciai stickers with the company's current logo and, as Deda wasn’t founded/rebranded until 1993, the frame therefore had to be built thereafter.
Additional Information:
I’ve squinted at the 1990s Bianchi catalogs over at 2Velo’s website but I’m guessing their Japanese origin has little relevance to bikes and frames produced in Italy and shipped to Australia. So I offer the following additional information:
Purchase:
Tubing:
Best Guess:
Serial Number:
- There’s no Bianchi logo or branding on top of the bottom bracket and brake mounts.
- Brakes are Campagnolo Veloce [1998] dual pivots.
- Cabling is internal along the top tube to the rear brake.
- Fork is painted celeste green, but appears to be chromed underneath thanks to a few scratches. It has Bianchi branding facing forwards on both sides and sticker on side saying “Cr Mo Fork. Bianchi Reparto Corse.”
- Chromed rear triangle. Note drop outs also chromed, not painted celeste green.
- Sticker on seat tube denotes “Made in Italy.”
#1522
Liked 3,036 Times
Purchase:
Tubing:
Best Guess:
Serial Number:
Purchase:
Tubing:
Best Guess:
Serial Number:
Bianchi model names and specs can vary from country. I'm familiar primarily with North American models and it's similar to our Bianchi Veloce of the era.
Link to photo album; https://www.bikeforums.net/g/user/73780
#1524
Hello!
Could I get some help identifying my Bianchi? I purchased it a few years ago from the second owner. I originally believed it was a Nuovo Racing but, upon further research I've become less convinced.
The serial number (under a white, plastic cable guide) is A374004
There are no other numbers stamped anywhere on the frame.
The size is 62cm but it's not shown anywhere
Distinguishing features are:
Campagnolo Victory components (all except rear hub and known-to-be-replaced seat post)
Italmanubri Bar and stem? (no marking on visible part of stem) shaped like ITM
Mavic Module 3 rims (silver)
Made in Italy decal on downtube below bike shop sticker (from Cupertino, California)
Original (likely) navy blue cable housing (ribbed, vintage style)
Original (likely) blue handlebar ribbon - Benotto style
Black suede saddle with Bianchi logotype on sides
Frame is solid Celeste green. No chrome. Navy blue Bianchi decals with the mid-eighties style "wedge" mark
The frame has pantographed "B" (in a circle) on seat stays and the fork has some minimal pantography in navy blue - nothing more
Is that enough?
My research makes me think it's a 1984 bike... with the navy blue cable housing and the blue bar tape. And the Campy Victory components appeared in 1984. The 1984 Bianchi catalog scans I've seen, don't show Victory components. Perhaps mine is a mid-year revision spec?
Thanks in advance!
Chris
Is that enough?
Thanks in advance!
Chris
#1525
Hello!
Is that enough?
Thanks in advance!
Chris
Is that enough?
Thanks in advance!
Chris
Chris
