FS - Cranks, Rings, BB, Stems and Bars
Quoted: 502 Post(s)
Liked 466 Times
Prices do not include shipping. I will be happy to combine any of the below, including assembling cranks and rings until I run out of my few sets of chain ring bolts and spacers. PM with any requests and we’ll figure out a better assembly price and shipping price. I will update this post as items sell.
Teaser photos are shown below. Click on any photos to go to the website (Dfrost) where more detailed photos are available, including parts FS I have not yet listed below.
Triple Crank Sets
Sugino AT, 170mm -110/74mm BCD. Some marks on inside of DS arm, minor scuffs on outside. Beautiful, cold-forged low "Q" crank, requires at least 127mm BB with DS spacer. Will include spacers if requested. VG condition. $40
Shimano 6206, 170mm - 110/74mm BCD. NDS arm came from 6207 - same profile, but marked "600". You'll never notice unless you're looking at both arms simultaneously. Uses 122.5mm BB (see below). VG condition. $30
Topline, 170mm - 110/74mm BCD. Lovely, light weight (100g less than Sugino AT or Shimano 6206 above) polished crank. Uses 119mm BB (see Phil BB listed below). Requires pedals with external wrench flats (typical), since the pedal holes are blind. VG condition. $50
Crank sets with Chain Rings
Campagnolo Veloce Triple, 170mm - 135/74mm BCD. Includes 28-42-52 Campagnolo rings with shift assist pins, Campy dust caps. DS crank and rings look nearly new with minimal scuffs; NDS crank has minor scuffs. Looks like it takes a 111mm or 115.5mm BB, but check my research. Exc condition. $80
SR Double, 165mm – No part number. 135mm BCD, Includes 42-52t rings. Don’t know the required BB length. Good condition. $20
Chain Rings
74mm BCD
26T - Aluminum (no brand name), very little wear. Exc condition. $10
26T TA – Stainless steel, minimal visible wear. Exc condition. $15
110mm BCD
36T Sugino - Removed from new Sugino XD, with shift assist pins and ramps. See also 50T ring below. New condition. $20
38T SR – 2 available, identical. Plenty of life left on these. Good condition. $10 each.
39T TA Zephyr - Harder aluminum than most rings. Polished outer face. Has shift-assist pins and ramps. Marked "9/10 speed", but I use these rings on my 8-speed bikes with no problem. VG condition. $25
39T - No brand name, worn, but some life left. Good condition. $5
48T Sugino – 3 available, very similar. Some wear, but I don’t use my big ring much, so mostly shift marks on inner surfaces. One has smaller holes compared to others. Ritchey-marked has pin to prevent chain drops onto crank arm. Good condition. $10 each
50T Sugino - Removed from new Sugino XD, with shift assist pins and ramps. See also 36T ring above. New condition. $20
110/74mm BCD BioPace Set – 28-38-48 rings, silver. VG condition. $30
Square Taper Bottom Brackets
Shimano 68x122.5mm UN55 - Only used for length determination. Excellent with Shimano 600 cranks above. New condition. $15
Shimano 68x110mm UN55 - Very little use before swapping to a shorter BB. Excellent condition. $15
Phil 119mm – 2 available, identical. Symmetric, but adjusts for asymmetric. Includes English thread installation rings. I can work a loan for the installation tools if required. VG condition. $70 each.
Stems
Cinelli XA, 130mm - Minimal use. 26.4 clamp, 75mm height. See Cinelli 65-42 bars below. Exc condition. $50
Nitto Pearl 9 - 26.0 clamp, measures about 95mm long, 85mm height. VG condition. $50
Nitto “Specialized” 8 - Made by Nitto, identical to Pearl in finish and quality, 26.0 clamp, measures about 85mm long, 85mm height. VG condition. $40
SR “Custom”, 60mm - 25.4mm clamp. Measures about 65mm long, 85mm height, wedge style. Good condition. $15
SR Soul, 110mm – Forged, measures about 115mm long, 90mm height, wedge style. Good condition. $20
Bars
Cinelli Criterium 65-42 - 42mm CTC at drops. Minimal use. Fits Cinelli stem above. Pretty big radius behind drops. Excellent condition. $30
Triple Crank Sets
Chain Rings
74mm BCD
110mm BCD
Stems
Bars
Triple Crank Sets
Chain Rings
74mm BCD
110mm BCD
Stems
Bars
Triple Crank Sets
Chain Rings
74mm BCD
110mm BCD
Stems
Bars
Triple Crank Sets
Chain Rings
74mm BCD
110mm BCD
Stems
Bars
Triple Crank Sets
Chain Rings
74mm BCD
110mm BCD
Stems
Bars
Quoted: 502 Post(s)
Liked 466 Times
Sorry for the double text in the original post. "Post Preview" and "Edit Post" aren't showing anything to edit. I will fix it when the system lets me. OK, now its duplicating the text again when I try to edit! Jeesh!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Nice swag X 2!
Quoted: 5888 Post(s)
Liked 3,471 Times
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,405 Times
I'll take the Shimano 6206/600 cranks. PM incoming
Quoted: 502 Post(s)
Liked 466 Times
Can't edit my original post. (What's going on, Moderators? Its only a problem with my original post. Because of the photo BBCode?) So I'll have to use thread replies to provide updates.
SOLD are:
Topline cranks (wish I had more to offer!)
BB - Shimano 122.5mm UN55
Chain Rings - 36T, 50T, one 48T
SOLD are:
Bikes: 1987 Schwinn Circuit, 1986 Schwinn Passage, 1987 Shogun Katana, 2018 Giant Anyroad Advanced, 2013 Karate Monkey
Quoted: 125 Post(s)
Liked 269 Times
PM sent.
SOLD are:
SOLD are:
Dfrost
Classic and Vintage Sales
17
09-29-16 01:28 PM
YoKev
9
05-22-16 03:13 PM
cooperryder
0
08-03-15 10:39 AM
