Balancing a bike to put toddler in seat
I stopped riding when my daughter was born three years ago, but I was thinking that this summer would be a good time to get back into it and have her tag along. I was going to buy a seat for her when I realized that my bike has no kickstand. How do I balance the bike enough to safely put a 30 lb. toddler in the seat? I know there are some products that you can use in place of a kickstand - does anyone have any recommendations?
You do not want to depend on the kick stand when loading or unloading or having a child in the seat.
What I did was to face the rear of the bike, lean it against your body, and then lift the kid into the seat. Then make sure you ALWAYS have at least one hand on the bike, and avoid kicking Jr. when putting your leg over the seat to get on yourself.
It's easy with a little practice.
Quoted: 18378 Post(s)
Liked 4,512 Times
There are discussions about using devices or straps to keep the front wheel from turning, and perhaps also keep it from spinning. That would keep the bike more stable.
I've found that I can hold the seat and kick over the bars just as easily as swinging my leg around the back.
Quoted: 15 Post(s)
It's expensive, but the Ursus Jumbo kickstand is the bomb. I never hesitated to depend on that kickstand to hold the bike up while loading my kiddo and then unengaged the kickstand and hop on (I had a mixte frame bike, easy to mount).
Bikes: 2010 Trek 7100
Quoted: 697 Post(s)
I never put a kid seat on my bikes, and both my girls are now well into trail-a-bike size or beyond, but I think if I was going to do it, I'd look for a beater step-through frame and make a utility bike of it with at least a front basket, maybe a front low-ride pannier rack. (After all, if you're taking a kid out for more than a few minutes, you'd better be carrying snacks and such, at the very least.)
Quoted: 659 Post(s)
Liked 7 Times
Never used a kickstand or any special device to balance the bike. Just propped it up against my body and lifted our daughter into her seat. I then swung my leg over the front of the bike to get on. I agree with the comment above about adding low-rider panniers. These were not only essential for carrying child supplies (snacks, diapers, toys, extra clothes, etc.), but also improved the handling of the bike by putting more weight on the front wheel.
Quoted: 507 Post(s)
Liked 237 Times
1. Prop bike against body or even better, squeeze the top tube with your thighs but facing backwards
2. Pick up kid, put in seat. You're still holding the kid & anchoring the bike at this point
3. Fasten the kid while holding the bike by the saddle when needed
4. Now, one hand on the bike, one on the front brake do the moves needed to face forward
Having a lower top tube helps, but I can do this with my MTB no problem
Quoted: 507 Post(s)
Liked 237 Times
Problems with wobble are more pronounced on winding paths; at the same time uphill climbing becomes more challenging due to the weight distribution being so biased towards the rear wheel.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
I've used bike seats when the lad and the lass were smaller, and a trail-a-bike when the lass was bigger (the lad went straight to riding himself).
Loading up is not an issue. You lean your bike against something solid as you normally would. Loading the wriggling monster is just like handling a toddler in any situation - you soon learn what works for you and your child. It is easier if you've got someone to support the bike but without that, you soon work out what works for you.
I would NOT use a kick stand, they are just implements for dumping your bike on the ground.
After the first couple of trips, you'll remember this thread and wonder why you asked.
To be honest, once the child is loaded and ready to go, the biggest hassle is swinging your leg over the saddle without kicking them in the face.
Bikes: 2014 Cannondale Synapse Hi-MOD 2 SRAM Red, 2013 Cannondale Quick 4, 1995 Cannondale F500
I also use the Ursus Jumbo kickstand and have had no issues.
Straightbangin
General Cycling Discussion
15
03-05-17 06:53 PM
PlusVeggie27
Recreational & Family
9
07-20-12 09:04 AM
