Campy Ergo 8 speed Shifter Compatibility question
Old 10-03-17, 02:53 PM
kcblair
Old Legs
kcblair's Avatar
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times in 22 Posts
Hello all, Now that I have upgraded My Ciocc, with a 7 speed Micro Shifter, I'm looking into the possibility of upgrading my Concorde.
Here's what I have now, on the Concorde: Campy Athena RD, FD, Syncro II DT shifters, with a Shimano HG 7 speed cassette. Yes, that's the way I had it built, so I could have larger cogs, as I grew older, and the system works great.
I know, Campy did not make a 7 speed "brifter". Specs show the Campy Ergo has a cable pull of 3.5mm. vs 2.9mm for Shimano. Cog spacing seems to be the same 5.0mm .
I want to keep the Campy theme (Group). Has anyone adapted a Campy Ergo 8 speed shifter to a 7 speed cassette ?
I understand, one gear will be locked out on the shifter. Any suggestions and ideas are very welcome and thank you.
I do find used 8 speed Ergo shifters on Ebay, approx. $60. So I would take the risk. KB
kcblair is offline
Old 10-03-17, 03:08 PM
Force
Quoted: 81 Post(s)
Liked 155 Times in 66 Posts
I have used Campy 8 speed ergos with 7 speed freewheels, but with an 8 speed Campy RD. Works great.
Force is offline
Old 10-03-17, 03:11 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times in 1,439 Posts
St. Sheldon confirms your observation that Campy 8-speed had 5.0mm spacing, so I think that should work just fine. I've been experimenting with various off-spec combinations over the past year and my observation matches the theory -- namely that as long as you get the spacing and the derailleur movement properly matched, no matter how you do that, things work pretty well.
There is a slight caveat that $60 ergo shifters on eBay may need to be rebuilt. The good news is that they can be rebuilt to work like new. I think it's worth the risk.
My Bikes
Andy_K is online now
Old 10-03-17, 03:50 PM
kcblair
Old Legs
kcblair's Avatar
Quoted: 302 Post(s)
Thank you Andy. What about cable pull ? Campy 3.5 vs. Shimao 2.9 ? Now, where do I get info on parts and procedure, for a rebuild ? KB
kcblair is offline
Old 10-03-17, 05:13 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
For use with 8-speed Campy shifters, you'll want either an 8-speed Campy rear derailleur or an "old" 9-speed. The 9-speed thing can get a bit confusing because they changed the cable pull in the middle of the 9-speed era. I believe any Campy 9-speed rear derailleur made before 2001 will work for you, while any 10-speed rear derailleur won't. The way that you can distinguish between the old cable pull and the new cable pull is by looking for where the B-screw is. If the B-screw is next to the derailleur mounting bolt (similar to where Shimano puts it) it's going to use the old cable pull. If the B-screw is next to the upper jockey wheel, it's going to use the new cable pull. Looking for that will save you having to figure out what was 8-speed and what was 9-speed, I think.
My Bikes
Old 10-03-17, 05:33 PM
kcblair
Old Legs
kcblair's Avatar
Quoted: 302 Post(s)
Thanks Andy, I got that, Ill search for a 8 speed first. Again, thanks for your help. KB.
kcblair is offline
Old 10-04-17, 12:46 AM
Dfrost
Dfrost's Avatar
Quoted: 502 Post(s)
Liked 466 Times in 256 Posts
I use the Ergo rebuild instructions in Leonard Zinn’s “Zinn and the Art of Road Bike Maintenance”. I got in trouble trying to use actual Campagnolo instructions. Most likely parts will be the G-Springs that are widely available and inexpensive. Hopefully you don’t need a spring carrier (I haven’t needed one yet inseveral rebuilds.) Look for other threads on Ergo parts to understand which springs you need.
Dfrost is offline
Old 10-04-17, 06:29 AM
kcblair
Old Legs
kcblair's Avatar
Quoted: 302 Post(s)
Thanks dfrost, I've got that book in my library. Never thought of looking there. KB.
kcblair is offline
jcoll003
Classic & Vintage
14
09-03-15 04:44 AM
Todd Richards
Road Cycling
10
07-10-15 05:12 PM
Fred Smedley
Bicycle Mechanics
2
02-11-14 05:25 PM
SteveCrowley
Classic & Vintage
5
05-20-10 10:36 AM
