How necessary are disk brakes for gravel?
Quoted: 10 Post(s)
Just wondering. I have a caddx 105 with avid shorty's and everytime I consider getting a new cross/gravel bike, I talk myself out of it due to how much I like my caddx. I don't race and I don't ride in wet conditions very often. What am I missing by not having discs. Oh and I don't have a problem running 35mm tires.
I'd say you're missing nothing with your riding conditions.
Only reason I'm running them is due to not being able to find a frame with enough tyre clearance for my specs.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Just a little puddle or stream can get your rims wet, which will inevitably attract dirt, which will cause a horrible grinding sound when you brake. That's what I dislike most about rim brakes.
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
They’re not necessary at all.
There are many reasons discs are nicer, but necessity isn’t one of them.
I opted against discs on my Kinesis build for reasons of weight, cost, groupset (no Campagnolo discs at the time), and wheel compatibility with my other rim brake roadies. Had I not wanted the wheel swap-ability, or if it was my main bike, I’d have gone discs.
I wouldn’t replace a beloved bike just to get discs, particularly if I couldn’t even tell if they would improve my cycling life.
Personally, I am a Canti fan and when I built up my Cross/ Gravel bike - which came with the option for Disc - I stayed with the Cantis for the reasons mentioned above. Much easier to maintain and I did not feel like getting new wheels. I raced cross and ride my bike on the road and never felt like I didn't have enough stopping power. If I was racing or doing more technical trails - like on a mt bike - discs have a huge advantage - but for normal riding, gravel grinding or even cross racing - I think regular old canti's work great.
Quoted: 5224 Post(s)
Liked 3,585 Times
who stops, really?
Quoted: 18883 Post(s)
Liked 10,646 Times
I wouldn't. But you know your area better than any of us do.
Liked 3,585 Times
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
I like having 100/130mm spacing on my gravel bike. Its a road bike and used road bike spacing.
If you rode in wet weather a lot, or thru water a lot, or were scared of gravel descents- then sure disc brakes could be helpful and confidence inspiring. Though I am on the larger side of things, I probably dont ride fast enough to feel out of control on gravel.
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
I would say the one thing you are missing is the ability to go into corners or downhill faster - disk brakes allow for braking later because you can stop/slow down faster when needed. Its confidence to go faster! Ironically.
Use or a marketing feature? they are pushed now, as is N+X more 'speeds'...
you can ride on a gravel road with just about any bike, the Tour D France was raced over un paved roads for decades.
Jet Jockey
Not at all.
Discs have 3 advantages.
1) Better braking with carbon rims. But this is a self-created problem, isn't it?
2) An edge in extreme winter, and really, really wet and sloppy conditions. But it's not like rim brakes won't stop you, just that discs don't really lose anything.
3) The ability to change wheel sizes. Say you want to run 650b one week with big rubber, and 700c the next with a more traditional 32mm? No problem.
Good night...and good luck
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Not at all.
I only wish for disks when riding in really really deep snow and slush.
Realistically, wet rims are a non issue for good rims/pads. But it takes a little more finesse to clear ice off of a rim. Then again, last night my hubs were full of ice too, so disks might not have helped.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
The other time discs (especially hydraulic discs) can be nice is if you have an extended steep descent where you need to keep your speed in check. I did a gravel ride last year using a bike with dual-pivot calipers where my forearms were starting to cramp on a descent like that.
The downside, since you are used to cantilever brakes, is that you may find yourself surprised by the experience of gently squeezing the brake lever and having the bike actually slow down.
My Bikes
My Bikes
Bikes: CENTURION / LOOK / Bianchi
Quoted: 214 Post(s)
Liked 10 Times
This times a million. My dream bike is a Trail Donkey and a few extra sets of rims with different sizes/rubber.. One bike for almost everything would be amazing.
Not at all.
Liked 10,646 Times
This is mostly true. A lot of times on gravel you're going to be limited by the available traction, but even then discs can help you scrub more speed on the bare spots between the piles of loose gravel. Anyone who cites physics and disputes this has clearly not used Avid Shortys or really good disc brakes.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Yes there's the qualifier "good there...Cheapo disk brakes are about as underwhelming as cheapo rim-calipers.
