Shaft drive thread (anyone else using?)
Shaft roller
Bikes: Brik Brut, Dynamic Tempo 8
Shaft drive isn't popular on bicycles because the differentials which change the axis of applied torque, are thermodynamically inefficient. With a shaft drive bike you're eating up 5-10% more power than a chain or belt drive.
Belt drive with IGH or Pinion gearbox are more efficient and just as clean/maintenance-free, though you do have to replace the belt once in awhile (they last upwards of 15,000 miles).
The future may hold more shaft drive bicycles in store, particularly as more people get into commuter/utility cycling as a choice, not as a necessity.
I also moved to shaft drive motorcycle after a cross country trip on a chain drive and tired of lubing it and the mess it made. Run a Moto Guzzi and it has been wonderful for the last 15 years. Change the oil once a year and keep on motoring. On the bicycle I don't like IGH, so chain it is. Not too messy, really, and wheel removal/installation is much easier with less hassle. I do see shafties for bikes if the cost comes way, way down, but the IGH will prevent that from happening even if they figure out how to do a low cost shaft drive.
Combine The % of IGH energy loss, and the added % from those 2 bevel gears , and live with it..
purists will find the exact numbers for you.
biggest issue I see is you cannot change the gear range up or down..
So, you just cope with the one it is , as is.
Bikes: Road, Commuter, Mountain, Tandem and a couple others
Quoted: 87 Post(s)
Liked 41 Times
I've never seen one, but I would not call you an "idiot" for loving shaft drive bikes. You've got two versions, I think that's cool!
As for why they haven't caught on - there's probably 20 reasons but my guess is the only reason that matters is money. Sram probably has $5 in a $50 chain, and it's disposable.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Sincere request --keep us updated on how the drives wear as you put on the miles. 2000 clicks is well within what I would expect to get from one chain.
I haven't even seen one of these, but my biggest concern would be the possible difficulty in finding replacement parts, so I'm curious to know how bullet proof they really are over the many miles I would likely put on them.
Thanks for posting about this. I'm glad you are enjoying the bikes, and want to get your impression of how they hold up.
Quoted: 27 Post(s)
Wow, didn't know about shaft bicycles that would be awesome but out of space in the garage.
I also have a 96 Guzzi California and a 06 kawasaki concours love em both.
Quoted: 1364 Post(s)
Liked 1,678 Times
Very cool. You'd think shaft drive bikes would be more popular due to the massive government-sponsored marketing campaign...
Tragically Ignorant
Liked 9,098 Times
Quoted: 643 Post(s)
Liked 1,526 Times
A chain drive isn't a big enough hassle for me on a bicycle to look at alternatives but it definitely was for motorcycles.
1968 BMW R60.. they look like this; not mine but you get a picture, this way.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Yeah, but tell us something we don't know. ...
I think the real reason why it hasn't gotten into mainstream is not efficiency, but cost and untested grounds. Shaft-drive is more expensive to build, needs much more design and thought (needs very high rigidity for high-torque application, needs very smart design to make it light and compact, from gear symmetry, bearing tolerance to an efficient modern "spiral" tooth pattern setup) to make it work properly and efficient compared to a chain or belt that have been tested and tried. Other reason is that it needs a good IGH to couple with, while shaft drive has been around since 1880s only lately (2010 and on) we've gotten those decent enough IGH gearboxes (the high-end ones: Nexus 8 Premium/Alfine 8/11, Rohloff, there are still many bad examples of bad IGHs). So in this sense I feel the future looks bright for shaft drives if it's done properly as the IGH gearboxes evolve.
Youre right: It's hard to make shaft drives light and compact. They are more costly (with two spiral-cut bevels, it's unlikely that they'll ever be relatively cheap). They do put a significant torque on the rear triangle that just isn't there with chain or belt drives. So a beefier rear triangle is needed. You mention 'modern "spiral" tooth pattern setup'. Spiral bevel gears have been around since at least the 1920s, and I think even back into the 1800s. The gear machines back then used clever geometrically appropriate hobs (gear cutters) to precisely "generate" the spiral gear tooth pattern precisely. What is modern about this?
It's true that enclosed shaft drives are enclosed and won't snag your trousers. As someone has said, shaft drive is an approach that surfaces every few years and never really catches on. With all of the disadvantages, and few advantages, why would people want these?
I read your points, and have to say they aren't compelling for me. But you commute, and you may weigh different aspects of cycling different than I do.
Keep pushing. Man's reach should exceed his grasp, or what's a heaven for? and all that.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
It's probably fair to say that the bike industry has explored shaft drive for a hundred years or more. I'd love to try one! I get that shaft drive could represent a fair trade off for certain use cases like urban commuting, for example. I also understand that shaft drive is an expensive bet for a brand to risk making. It's fun just knowing there are a couple brands still producing shaft drive bikes.
Tragically Ignorant
Liked 9,098 Times
The Ceramic Speed looks very interesting, but they certainly make grandiose claims without showing any proof they have a working bike with such efficiencies.
They claim to have been track testing, but I find it very suspicious that there's no video of this, and none of their mock-ups have shown an actually working shift mechanism.
As far as materials technology advances leading to greater efficiencies and easier maintenance, there's no reason in principle that won't apply to chain-drive as well--chains may look very different in 20 years.
Technologies seem to develop faster when there are competing lines of technologies, so I'm rooting for shaft drive to advance, but I remain skeptical that it will be anything other than a niche for quite a while. People with poor wrenching skills, like myself, will likely steer clear of it for a while because we wouldn't know how to deal with problems, and think it would likely be a very expensive prospect to find someone who does. .
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
I predict that the chain drive will advance with technology advances in the cogs and the chains themselves. If there were "worthy" advances in bicycle drive systems we would have adopted them by now.
Liked 341 Times
Spiral bevel gears were even more complex. Complex hobs (gear cutters) were used. Once set up, the gears could be mass-produced (think differential gears in cars, some of which were hypoid*!).
The pics you shared of the various shaft drives were great. Really enjoyed them, much appreciated.
When you get to a certain age, there's a tendency to thing "been there, done that" and to lose some enthusiasm for novel (or in this case, kind of novel) things. Sorry if my note was not as supportive of investigating alternate ways of thinking about bikes as perhaps it should have been. Good luck with your enthusiasm! Good riding, too.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I appreciate the OP's enthusiasm, and the bikes look really nice, but I really can't see shaft drives having any advantage over good chain drives in similarly-purposed bikes using IGH. The chain problems have (almost) all been solved for a long time with fully-enclosed chain cases, and the last one--changing tires/tubes--was recently solved by WorkCycles, with the "Escape Hatch" featured on some models. The whole left side dropout unbolts from the frame and wheel, leaving the right side with the chaincase and shift cable undisturbed while giving access to replace a tire or tube. Scroll down this page a little and you'll see it:
Bakfiets en Meer » Overview: WorkCycles Fr8 Transport Bikes
How easy is it to change the rear tire on one of yours? I can't tell from the pictures, but it seems to me you may have to loosen the shaft assembly at the front in order to get the wheel out of the frame. Or does it simply slide straight out? Even then, you still have to disconnect the shift cable.
Again, for the same kinds of bikes, I think the economic advantage still goes to chain, especially in manufacturing cost; anybody with a couple of punch-presses can make good chain, but the machinery for cutting and heat-treating those gear teeth has to be a lot more of a capital investment. And with a straight chainline, the chain (and chainring and cog) can be wider, spreading the stress over a wider area to reduce wear. Also, the straight-line chain doesn't incur wear from bending sideways or having its sideplates grinding against the sides of cogs and chainwheels and derailleur gates. Altogether, I'm really surprised anybody's making shaft-drive bikes at all.
If I'm not mistaken, CeramicSpeed has openly admitted that they have yet to solve the problem of how to shift gears with their design; this has been discussed elsewhere. I doubt it can be done at all without an electronically-controlled servo, and maybe a heavy one at that--powered by a largish battery.
I don't mean to shoot down the idea; I just don't think it's ever going to catch on in any big way.
