Lights, Reflectors...Action!
Old 11-16-18, 11:18 AM
BobbyG
BobbyG's Avatar
Quoted: 1364 Post(s)
Liked 1,678 Times in 827 Posts
My bike lighting this fall...
BobbyG is offline
Old 11-16-18, 12:13 PM
no motor?
Unlisted member
no motor?'s Avatar
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times in 297 Posts
I've been wanting to see what I look like when I ride at night, I wish I would have done this before it snowed.
no motor? is offline
Old 11-16-18, 01:11 PM
BobbyG
BobbyG's Avatar
When I looked at the video I noticed I had no reflector on the back wheel. I bought a new wheel two months ago, and forgot about it. As it is a disc brake bike, I will put reflective tape on part of the rim...yellow and black caution tape, like my rear fender. And not all around, just a portion. I think the "leaping gazelle" movement of a single reflector catches the eye better.
BobbyG is offline
Old 11-16-18, 02:59 PM
no motor?
Unlisted member
no motor?'s Avatar
I used to put LIghtweights on every spoke until I bought my last wheel. I went every other pair there to make it more visible. I'm not sure if it worked or not, but it seems like it should.
Old 11-16-18, 03:21 PM
rollagain
Lopsided biped
rollagain's Avatar
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times in 97 Posts
https://www.youtube.com/watch?v=YNfJhkbzW-E
Someone's going to report you as a UFO.
I just bought a Planet Bike Grateful Red tail light for my Street Strider, which I'm still in the process of accessorizing. I got that light because (a) it runs on AAA batteries, (b) it has a mounting bracket that's made to bolt onto a flat surface such as the bar on my luggage rack and (c) because I didn't entirely choke on the price and didn't feel like sorting through the dozens of choices available on Amazon.
I like this tail light quite a bit. Instead of multiple discrete LEDs it has that elongated strip variety that's showing up more and more now. Turns out they can do a lot of cool stuff with that, like having the middle and end sections flash separately. It's VERY bright, and the lens spreads the light in a wide sidewise beam. It also has large sections of the traditional honeycomb reflector above and below the LED. I'm not too fond of the strobe, though; it's just a little too intense and jittery, but would be good if you're riding in heavy fog, rain, or snow, or if you find yourself craving a psychedelic experience.
rollagain is offline
Old 11-16-18, 03:28 PM
BobbyG
BobbyG's Avatar
Unidentified Fredding Object[/QUOTE]
I keep my bikes in an unelectrified shed, so the bike lights get batteries, so that I don't have to carry them in to recharge. The headlight is removable and comes in to recharge.
BobbyG is offline
Old 11-16-18, 04:03 PM
PaulRivers
Quoted: 539 Post(s)
Liked 44 Times in 38 Posts
That's very interesting. I've been looking for a usb-rechargeable version of the B&M Flatline Plus light, and that looks close. For "steady" mode I really think a "solid line" is better for standing out as a bike vs the "single red led" you usually get. As a driver I notice bikes a lot easier in a sea of tail lights.
I see it comes in both aaa battery and usb-rechargeable versions. I used to use aaa's....but several times I'd get home and find my rear light had died. Sometimes the battery ran out of juice. Sometimes the battery wiggled out of the holder when I hit a bump or something. So I only use usb-rechargeable rear lights now...battery can't jiggle loose, and I store my bike next to my charger and just leave it plugged in when not riding it. The usb version is $27, replacement aaa batteries are about $10, I figured the added reliability is worth the extra cost of just replacing the whole light when the battery wears out. Plus maybe they'll have a better light out by then.
Planet Bike lights "blinking" mode are a bit nutty i.m.o.. I wish they had a steady flash instead.
PaulRivers is offline
Old 11-16-18, 04:05 PM
jefnvk
jefnvk's Avatar
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times in 51 Posts
That's my winter setup! Not as snazzy as yours, but I get to ride around in snow where no car can go over 20 or so anyhow!
I like your wheel lights, I may have to look into those. People kinda disliek them, but it is the one thing that instantly screams BIKE to any motorist.
jefnvk is offline
Old 11-16-18, 04:09 PM
PaulRivers
Quoted: 539 Post(s)
I couldn't find it in a quick search, I vaguely remember seeing some sort of either reflective or led tube kind of light where it outlined a skeleton shape so you looked like a person from behind. I thought that was interesting.
It's pretty interesting to see such a...uh...visible getup. I always wonder if being obnoxiously blinking and bright is better for safety or worse.
I definitely like the lights on the ankles that you can see from behind and provide movement. I wonder if the camera just makes the front wheel light stand out more? It uh...seems a bit loud for my taste. I'd probably be going for more of a ribbon light that makes a circle around the front wheel so it's not as crazy myself. I like wheel lights but it seems uncessarily distracting (though that could be just the video making it look different than it would in person).
Old 11-16-18, 06:15 PM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1107 Post(s)
Liked 64 Times in 47 Posts
I vote better. A driver has about 1/2 a second to see you.
TrojanHorse is offline
Old 11-16-18, 08:23 PM
ggoytia1
Quoted: 27 Post(s)
Are tge sneakers light up? Similar to kids shows? If yes thats awesome i need a pair.
ggoytia1 is offline
Old 11-16-18, 08:34 PM
rollagain
Lopsided biped
rollagain's Avatar
Quoted: 316 Post(s)
Originally Posted by PaulRivers
snip
snip
I anticipate batteries dying, so I use rechargeables and carry a spare set in my tool kit, same as I do for my headlights. If I have to change a set during a ride, I just swap them with a fresh set from the charger when I get home.
I've never had a battery come loose in any light.
The 'Courtesy' mode is pretty sedate; the end segments light steadily and the middle pulses gently on and off, about two seconds on, two off. I'd like it better if the pulse was twice that fast, but I'm okay with it.
Old 11-16-18, 10:49 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,584 Times in 2,344 Posts
Haha awesome & really like the text overlay!
rumrunn6 is offline
Old 11-17-18, 01:14 AM
Davednconfused
Well, if they look up from their phone - they'll certainly see you!
Davednconfused is offline
Old 11-17-18, 04:45 AM
Troul
Troul's Avatar
Liked 2,979 Times in 1,920 Posts
that is a factual statement.
-Oh Hey!
Troul is offline
Old 11-17-18, 04:48 AM
Troul
Troul's Avatar
imo where i ride, i find it worse. A target board for everyone else [criminals, thugs, drivers, hobo's]
-Oh Hey!
Troul is offline
Old 11-17-18, 08:24 AM
BobbyG
BobbyG's Avatar
Yes.
This is them:
https://www.amazon.com/gp/product/B01LAZL0CA/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
BobbyG is offline
Old 11-17-18, 09:30 PM
ggoytia1
Quoted: 27 Post(s)
BobbyG.
Thank you for the link.
Just noticed my spelling...geez.😬
ggoytia1 is offline
Old 11-17-18, 11:33 PM
BobbyG
BobbyG's Avatar
I always assume auto-corrupt of some sort.
BobbyG is offline
Old 11-18-18, 04:07 AM
KraneXL
Quoted: 3405 Post(s)
Liked 240 Times in 185 Posts
KraneXL is offline
chas58
Commuting
25
12-08-17 03:34 PM
providencebikes
Bicycle Mechanics
6
04-18-16 07:53 PM
Juggler2
15
09-08-12 08:22 AM
sknhgy
General Cycling Discussion
14
12-24-11 06:36 PM
ProBro Doug
22
02-02-10 08:10 AM
