Best wheels for commuting?
Old 12-20-19, 02:20 AM
Database82
Bikes: Bianchi Volpe (Sold), Bianchi San Jose, Kona Hahanna (Sold)
Quoted: 5 Post(s)
Hey gang, I wondering what kind of wheels you prefer for commuting? Clinchers, Tubeless, Tubular? I was also wondering if a deep rim would be best for cobblestone and crappy roads? Any help would be great, thanks.
Database82 is offline
Old 12-20-19, 02:48 AM
tim24k
Bikes: To many to list. I like them all!
Quoted: 60 Post(s)
Liked 43 Times in 32 Posts
Clinchers! I like and ride 2.0 to 2.35 Schwalbe Big Apples for the bad paved roads just like what you are talking about.
tim24k is offline
Old 12-20-19, 03:00 AM
Dave Mayer
Dave Mayer's Avatar
Quoted: 1371 Post(s)
Liked 476 Times in 278 Posts
Trick question... obviously you want to be on 1,000 gram (front and rear wheels combined) low-profile carbon tubulars mated with $150, 200 gram tires. The lowest rotating mass of any possible wheel option, almost impervious to pinch flats, and the tires stay put safely stuck tight to the rim if you have a sudden deflation.
However, if you are carrying loads, or riding in the rain over sketchy roads, you'll obviously have to ride something heavier and stronger than the dream setup I just listed.
Life is full of compromises...
Dave Mayer is offline
Old 12-20-19, 05:50 AM
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Liked 1,238 Times in 686 Posts
Building a commuter around H+Son Archetype rims and hub brakes. Medium-height V-profile rims should be stiff and wide enough for some 37mm tyres.
JaccoW is offline
Old 12-20-19, 07:30 AM
mcours2006
mcours2006's Avatar
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times in 235 Posts
The best wheels are the ones that are already on the bike and have been for a while. Anything else is going to cost extra. Mine are heavy and robust. They need to be able to be withstand the rigours of my commute--rain, snow, ice, ruts, carrying heavy loads, etc. On the road bike that I ride to work occasionally, well, that's different.
mcours2006 is offline
Likes For mcours2006:
Old 12-20-19, 12:15 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
There's nothing esoteric about commuting. You just happen to be riding the bike to work instead of across finish lines or to camp sites. Any kind of wheel should work, and if it doesn't, get something else.
Just make sure that it's not too hard to fix flats on what you've got. 'Cuz you'll probably need to.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 12-20-19, 12:29 PM
Classtime
Classtime's Avatar
Quoted: 1952 Post(s)
Liked 2,013 Times in 1,112 Posts
I see you have a Volpe. When the roads are clear, your good to go with whatever you have. When the tires wear out, I recommend Gatorskins in 28s or 32s. The only reason for new wheels would be to put some snow tires on them and swap wheelsets for the bad days when only hardcore crazies on this sub-forum would ride to work.
Classtime is offline
Old 12-20-19, 12:31 PM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,292 Times in 744 Posts
Round ones.
phughes is offline
Likes For phughes:
Old 12-20-19, 01:09 PM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Triban RC520 Gravel Ltd, Btwin Ultra 520 AF GF, Triban Road 7, Benotto 850
Quoted: 402 Post(s)
Liked 215 Times in 137 Posts
Always clinchers. For commuting and everything else.
Tubeless is not worth the trouble IMHO. Not to mention tubulars...
Amt0571 is offline
Likes For Amt0571:
Old 12-20-19, 07:13 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
Wheels with a minimum of 32 spokes, I also have few wheels with 36 spokes. I like the simplicity of tire/tube combo...Tubeless and tubulars are just too much trouble and offer no real advantages over the traditional tube/tire combo.
wolfchild is offline
Likes For wolfchild:
Old 12-20-19, 11:27 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6220 Post(s)
Liked 4,221 Times in 2,367 Posts
I prefer regular tubed tires. I have 8 bikes and use 4 to 5 of them for regular commuting. The care and feeding of that many tubeless tires is just more than I want to deal with.
As for how the wheels are built, strong wheels don’t have to be heavy. In fact, heavy wheels aren’t necessarily stronger. I use very light rims on my off-road touring mountain bike wheels which get more abuse than commuting wheels do. I use either Mavic XM717 or Velocity Aeroheads for most of my builds. The key to a strong, durable wheel is the spokes. Rims add little to the strength of a wheel. My preferred spokes for all my wheels are triple butted (2.3/2.8/2.0mm spokes) from either Pillar or DT Swiss Alpine III. These wheels will carry 40 lbs of gear on rocky roads for hundreds of miles. My touring bike uses similarly built wheels and have provided great service over thousands of heavily loaded miles.
Stuart Black
cyccommute is offline
Old 12-21-19, 04:57 PM
Database82
Quoted: 5 Post(s)
Thanks everyone for the great advice, I asked because the idea is to potentially convert my bike to single speed for commuting and city riding and just wanted to see what the best possible options may be.
Old 12-21-19, 09:56 PM
Koyote
Quoted: 6972 Post(s)
Liked 10,970 Times in 4,692 Posts
Commuting is fundamentally a utilitarian endeavor, and hence simpler is better...Hence the recommendation of standard tubed clinchers.
My only other recommendation is to just ride the wheels you have on the bike, as someone else recommended. My commuter has very cheap, nasty wheels - and they roll just fine and stay in true. I won't replace 'em until they start falling apart.
Koyote is online now
Likes For Koyote:
Old 12-22-19, 09:50 AM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times in 1,617 Posts
I have a fixed gear commuter with two sets of wheels. It's nice to have a backup pair for a quick swap in case you break a spoke or something.
Both clinchers with tubes, both aluminum, one is box section one is aero, one is a little wider, one will not take tires over 28mm. I keep 32mm on the wide ones but they don't fit under the fenders as well so I use them in the summer and the narrower ones in the Winter.
DiabloScott is offline
Old 12-22-19, 10:20 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
Maybe it's just familiarity, but it seems to me that clinchers are the most straightforward when dealing with problems. And with puncture resistant tires, they are virtually maintenance free until they wear out. Resistance to pinch flats doesn't seem like a big enough attraction for tubeless, when riding at fairly high pressure on pavement. Of course that's a YMMV thing.
Gresp15C is offline
Old 12-25-19, 12:31 PM
hokie cycler
hokie cycler's Avatar
Bikes: 2018 Giant Stance 1, 2011 Trek Madone 3.1, 2004 LeMond Nevada City, 1980 Peugeot Course single speed, 1978 Peugeot AO-8
Quoted: 5 Post(s)
Tubeless equals fewer flats and is therefore less trouble. I've been commuting on tubeless since the summer with no issues.
hokie cycler is offline
Old 12-25-19, 12:54 PM
Clyde1820
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times in 429 Posts
Had a set of wheels built-up for commuting on somewhat-rougher urban pavements. Velocity Dyad, DT Swiss spokes/nipples, Continental Tour Ride 47-622 tires, on Shimano Deore XT 36H hubs. Very capable for handling the occasional pothole, lots of seams and upheaved sections, and with the tires it's plenty able to deal with light mud, gravel, sand, and other off-pavement junk. Not the lightest setup around, but quality and durable. Tires I selected exceeded Velocity's recommendation for tire sizes, though they have worked fine. Quite impressed, overall.
If I were to do it again with the same width of tires as the goal, I'd likely select the Velocity Cliffhanger rim over the Dyad.
Clyde1820 is offline
Old 01-12-20, 02:03 AM
lazi_me
Last year, all the punchers are from commuting and not weekend rides. I go with clincher, might get a bit more punchers but a lot easier to fix. Few commuters I know also switch from tubeless to clincher since they got puncher too often due to broken glasses.
lazi_me is offline
Old 01-12-20, 03:31 AM
KraneXL
Quoted: 3405 Post(s)
Liked 240 Times in 185 Posts
Clincher for everything except racing. Otherwise its more trouble than its worth.
KraneXL is offline
Likes For KraneXL:
Old 01-15-20, 07:37 AM
irfani28
irfani28's Avatar
I planned to use road bike to work, which bar do you prefer? flat bar or drop bar?
irfani28 is offline
Old 01-17-20, 11:16 AM
davei1980
Very Slow Rider
davei1980's Avatar
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times in 101 Posts
Wider the better to allow more air volume in the tire, this will straighten your sidewalls and let you run fewer PSI in your tires which is beneficial to commuting.
I have run inner tube clinchers, tubulars and tubeless.
I am 100 percent tubeless now which is great because flats self-seal. Cyccocommute is correct in his analysis (per the norm) but I only have one bike to tend to, not 1/2 dozen like him
GOOD LUCK AND HAVE FUN
davei1980 is offline
Old 01-17-20, 12:20 PM
Amt0571
Quoted: 402 Post(s)
I use clinchers for everything, including commuting. I think tubeless is not worth it. Maybe flats are more common with clinchers, but I can fix them in less than 10 minutes without making a mess.
About the rims, all of them work if they can carry the weight you need.
Amt0571 is offline
Old 01-17-20, 02:10 PM
davei1980
Very Slow Rider
davei1980's Avatar
Quoted: 500 Post(s)
That's a matter of deep controversy and personal opinion.
I have commuted for some time on both.
I prefer flat bars but drop bars have their advantages.
The main drawback to flatbars is the limited number of hand positions. This is a bigger problem the longer your commute is, if it's short, then maybe not a problem at all. I overcame this problem by mounting MTB bar ends on the inside of the grips to give me a secondary semi-aero position for headwinds or just a change of pace.
My current bike has the Jones H Loop Bar - it's a flat bar by nature but has more hand positions than drops. It's very unorthodox but I highly recommend.
Likes For davei1980:
Old 01-17-20, 02:13 PM
davei1980
Very Slow Rider
davei1980's Avatar
Quoted: 500 Post(s)
Cliffhanger is supposed to be an awesome rim, let me know if you every get a set built up.
I am currently running 3" tires on 50mm rims, no such thing as TOO wide lol!
Old 01-17-20, 06:05 PM
257 roberts
Bikes: 2008 Trek Police bike 2019 Jamis Coda Sport 2021 Surly Bridgeclub
Quoted: 76 Post(s)
Liked 924 Times in 304 Posts
I have the Jones bars also and highly recommend them
257 roberts is offline
Likes For 257 roberts:
