Inverse relationship between Power and Speed?
Quoted: 28 Post(s)
Liked 33 Times
For you Garmin Connect users out there, am I right to assume that those of you that ride, on average, at higher speeds also produce more power than the average user in your age group when looking at “Insights”?
I struggle to produce power that resembles anything of other Strava users but I also don’t think I ride relatively slowly. I often have faster segment performances than others but at a much lower average power.
Pulling up Insights in Garmin Connect shows that I produce significantly below average power for my age group, but inversely, my average speed is higher than 71% of other users.
I’m just trying to square why my power output is so low. Initially, I though I might have a faulty left side crank PM but I’ve tried both a Stages Gen 3 and a 4iiii Precision 3+ versions and they’re relatively producing the same numbers.
Likes For RChung:
Quoted: 6196 Post(s)
Liked 4,811 Times
Also that power output graph compared to age group probably is not adjusted to watts per kg. So if you are a really light person, you won't need to be putting out the watts to get the speed you are getting compared to the average garmin user that might be a much higher weight average and therefore have to put out more power to move them along.
Quoted: 4416 Post(s)
Liked 4,871 Times
Just to add to all of the above factors, your riding terrain will also greatly affect speed. Are you roads smooth and relatively flat?
Likes For PeteHski:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
I don't think that data is from identical populations. In the first case, you're getting a histogram of all Garmn bike-ride recorders (and likely mostly watch users). In the second case, you're getting a histogram of only those who can record power, surely a vastly smaller population.
Likes For blacknbluebikes:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Garmin Connect says my average speed is 78th percentile, but max average power is only 50th percentile.
Speed is a useless measure, as it's dependent on terrain, wind, road surface, aerodynamics, etc.
But what is "max average power"? According to Garmin, it's the highest power recorded over a 20-minute or 60-minute segment. And it records as zero power any time you may have been stopped during that segment. I wouldn't trust that number for much of anything.
Training Peaks tell me that my 20-minute power (watts/kg) is 73rd percentile, my 60-minute power is 84th percentile, and my 90-minute power is 86th percentile. That seems about right (20-minute power probably is low because I'm not doing any 20-minute FTP efforts).
Training Peaks also says that my watts are about the 40th percentile. Which explains why the big guys can destroy me on a flat course.
Quoted: 28 Post(s)
Liked 33 Times
Appreciate the discussion, All!
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
I pretty much only ride roads/routes which average about 50'/mi. in total gain. So like 60 miles, 3000'. That has a big influence on average speed. Weight to power is a big deal too, as you realize. Anymore, I mostly ride outside on a tandem with my wife. We're geezers, I have a heart condition and neither of us put out a whole lot of watts. However, our tandem confers a significant aero advantage over a single. So last Sunday we did about 30 miles and 1500'. On the flat we were hitting 16-17 mph but our overall average was only 12.4. That's rather an extreme example but it shows what the issues are. IOW never compare your average speed with another's unless you were both riding the same route on the same day.
Back in the day, in my late 50s, early 60s, my fastest average with my single on a typical 60 mile hilly route was 18. Of course there's always That Guy. Our group had a strong rider who'd come out with us and drop any of us on a hill pulling his Golden Retriever in a trailer. Really. He rode with us because we'd ride in any weather every single sucking Sunday and the dog made it good exercise for him. He was a lot of fun to ride with. Went on to be the fastest American on RAAM a few years ago.
Yeah, no data here, just perspective. I do have a PM and record everything though. Not that it makes any difference.
Results matter
Results matter
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 219 Post(s)
Liked 851 Times
This. I have the inverse of the OP...according to Garmin Insights, I have a "max avg power" in the 94th percentile. However, my speed is only in the 51st. I live/ride in the mountains, it's a rare occurrence that I do a ride that falls below the golden ratio of 100'/mile.
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,482 Times
I have a Garmin 830 and do not get Insights from my Garmin app.
Speed versus power. I am a data junkie that records most every metric and I have done detailed aero testing at the indoor velodrome using a third party service.
Since this is a training subform and many want to increase performance - speed matters...a lot. Power is ones currency to buy speed and of course there is a cost. The cost is a function of ones weight, frontal area, tires, wheels, bike, helmet and position. Much like in finance, if one has enough money, one can buy whatever one wants and even overpay for it.
In the world of cycling performance, power, our currency to buy speed seems to always be in snort supply. The cyclist that can generate the most speed at the right moment wins. And I seem to top out at speed for different events whether I am sprinting, climbing or doing a time trial. Of course terrain, wind and road surface affects speed but it does for all players.
At our structured track sessions, we divide into two groups - fast and less fast. It is all about lap times - speed. To ride with the fast group, one has to be able to do 18 second laps or 31mph for solo efforts and recover. Sometimes, we have a motor that runs at 19 seconds per lap and the group must take laps on the motor. I see all kinds riders in different positions, equipment and body morphology. If ones cost of speed is too high, it is very tough to continuously make enough power to buy that kind of speed.
In the less fast group, the problem is the same. If the cost of speed is too high, one quickly runs out of energy and power generating capability.
Having said all that, I get why some will focus on FTP and power as a measure of capability and fitness. It is a solid metric for general fitness and a predictor of performance. But when training and racing with some of the best cyclists in world, power is not enough.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Speaking of Garmins, I think Garmins have pretty much accepted showing power metrics; what they still don't do very well is show drag metrics. I think that'd be a good next step.
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 570 Post(s)
Liked 773 Times
I don’t have that function on my app for some reason…
But from Strava segment data and riding with others, I put out more power than others at similar speeds.
Im slower than the bike calculator website predicts, I’m slower than my zwift speeds… 180w on zwift gets me 20-21 MPH, I get about 19 on dead flat roads.
I recently did a dead flat Strava segment at 285w, decent 8-10 MPH tailwind and only managed around 24 MPH. About 3 mph slow…
On top of body aerodynamics, wheels and tires can affect this data. Upgrading to CF deep wheels and GP5000’s gave me over 1 mph extra over the crap stock stuff that came with my bike.
Liked 4,871 Times
I wonder if anyone can match their Zwift speeds on the flat? Those Zwift roads are super quick! My Zwift climbing speeds are realistic, but not on the flat. My flat cruising speed on Zwift is around 36-38 kph and more like 33 kph outdoors. My local roads are pretty rough though in fairness.
Quoted: 28 Post(s)
Liked 33 Times
With an additional 125 watts at my disposal, I’d likely be averaging 26-27 mph with a similar tailwind…I suspect.
Quoted: 570 Post(s)
Liked 773 Times
The canal path is a fast surface. I'm about as aero as a brick... working on that this winter.
I like the "cost of speed" analogies made by Hermes.
Quoted: 570 Post(s)
Liked 773 Times
19:15, 20.3 MPH @ 209w
13:28, 19.8 @ 203w
Bike calculator example of the same conditions with a 5 mph tailwind = 24.19 MPH.
KOM for the segment is 27.1 MPH at 213w. Probably a wicked tailwind and a TT bike - but I've hammered the segment at 250+ with a tailwind and come nowhere close to that speed.
Some people are simply more efficient than others.
Likes For RChung:
Version 7.0
Bikes: Too Many
Liked 2,482 Times
jughead The low hanging / less expensive fruit to lower the cost of speed are clothes, helmet, head position (free) and tires/tubes. In the aero testing sessions, if one has their head up in the air, one is dead on arrival with respect to drag. Even if one puts a million dollar helmet on ones head, if the head is up and in the air versus turtled or down, it is hard to get a low cost of speed. And it takes a lot of practice and constant reminder to keep ones head down. The best way to know if the head is down is how one sees ahead. If one is looking up and through ones eyebrows, then the head is probably in a good position. And of course, never sacrifice looking ahead for road hazards.
On the indoor track, I generate 20 mph at 160 watts and that is not in the aerobars. Outdoors on a flat TT course on the road bike it is more like 175 to 180 that is probably right around VT 1 for me (on a good day).
Likes For Hermes:
climber has-been
Liked 3,567 Times
No idea if that tracks for anyone else.
Likes For RChung:
Quoted: 570 Post(s)
Liked 773 Times
On today's ride, there was one pancake flat and straight section, so I tried to keep my power right at 200 watts (3.33 w/kg). My speed over that segment was just under 22 mph. I'm a 181 cm skinny guy on a non-aero bike, no aero anything, hands on hoods with forearms parallel to ground.
I'm +/- 2 MPH slower at the same power levels.
A 20mph rolling average ride for me = 230-240w.
I just purchased a bike with more aggressive geometry and am working on my position - shall see how much of a difference I notice over time.
Quoted: 28 Post(s)
Liked 33 Times
The MyWindsock app is supposed to give you some calculated coefficient of drag (CdA); however, you have to pay for the premium version of the app. It sounds like you might be able to make aero improvements to your setup and see those calculated in the app’s estimate. I wouldn’t have high hopes for its accuracy.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Likes For RChung:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Raw power wise, it may skew high on a large population due to the large population skewing well...........larger, in the waist.
Otherwise, speed is fun, but meh. Lots of variables. I ride a lot of gravel lately so the avg speed is well down from road riding. Even my road riding, lots of short 8% hills in/around town to get out to the flatter riding. And in town several stops and very slow turns or stops at the bottom of hills you wish you could keep your momentum thru.
Ever want to feel "small". Do some running and lookup you percentiles in Garmin. You think your 7:00/mile 5k workout is swift..........then you realize......dang slow!
