Arch Pain, HotSpots, & Numb Toes - Help Please
Morning All,
I've been through the trials here, trying to resolve this problem. I have a pair of diadora cycling shoes with the spd style recessed cleat. They are fairly flat on the inside. With medium-weight socks, they are just a hair loose on my foot, but they fit fine.
When using them I experience serious arch pain in my left foot and left foot only.
So I bought some specialized brand inserts. Now, the arch pain is gone but I've got serious numb toes and hot spots. With the inserts, the shoe is a little tight on my foot, which I can imagine is causing the numbness.
I've fiddled with cleat position and think my cleats are in the right spot...ala the spindle is just under the ball of my foot.
My next question...now what?
+1. My cycling shoes are a full size bigger than my regular shoes. The specialized insert will give you arch support but also has a metatarsal button which spreads your toes out slightly to help prevent hotspots at the ball of your foot & toes. You need bigger shoes to accommodate that feature & typical foot swelling during a long ride.
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
They might just be too flexy. I have the exact same issues with my MTB shoes but not with my stiffer road shoes. I have the same SPD cleats as you.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Do you have high arches? Often the lack of flexibility coupled with high arches and a rigid foot causes those problems
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
custom shoes. I was having arch problems, and custom molded Rocket7's solved it. Unfortunately they're out of business, but there still is D2
https://www.d2shoe.com/
Admittedly pricey, but the points where you interface the bike are good places to spend money if you have it to spend.
You could get lost and die.
You could hit a tree and die.
Liked 5 Times
Do you need to walk much in your cycling shoes?
If not, switching to SPD-SL or similar pedals along with a large shoe would probably help, too. The SPD-SL road pedals have a much larger surface to push on.
