TT on road bike
Old 12-06-11, 09:03 AM
rotti
TT on road bike
I'm interested in racing a few TT's next year, but I don't want to put down the money on a TT bike without racing a few first. Do most TT's have a road bike division? Also, I'm curious as to how many can break an hour on a road bike. I'm thinking of making this my goal, but not sure how realistic that would be. Right now, I could probably do 20mph for a flat to rolling TT on a road bike.
rotti is offline
Old 12-06-11, 09:12 AM
rkwaki
soon to be gsteinc...
rkwaki's Avatar
Ok I'll bite. By break an hour on a road bike what exactly do you mean? A 40km tt? If so, yes I can.
Is there a seperate division? Sometimes yes it is called a Merckx TT - no aero equipment allowed.
My recommendation would be to give it a try, you can put on a simple pair of aero bars (clip ons) and go.
Don't overthink and complicate it, just race, you'll figure it out as you gain experience.
rkwaki is offline
Old 12-06-11, 09:31 AM
botto
botto's Avatar
Quoted: 15 Post(s)
Liked 27 Times in 12 Posts
c'mon man. everybody knows experience is overrated. if you want to make it to the cat4s, you need a climbing bike, a crit bike, a TT bike, a power meter, zipp303s, zipp202s, and a 70-eleventy!
botto is offline
Old 12-06-11, 09:36 AM
rkwaki
rkwaki's Avatar
Shhhhhhhhhhhhhhhhhhh - you're going to spoil my secrets. I only need 9 more points - just ordered my new TT bike with Di2 and all the carbon bits I need to get me there...
Don't forget the time in the wind tunnel, coach, dietician, massage therapist, hooker, therapist, etc.
Ahhhhhhhhhhh 9 more points....
rkwaki is offline
Old 12-06-11, 10:21 AM
echappist
fuggitivo solitario
Quoted: 243 Post(s)
Liked 13 Times in 9 Posts
i thought you also needed a coach, a disc, normatec space legs (for recovery), and a computrainer. that should do it, right?
echappist is offline
Old 12-06-11, 10:29 AM
SalsaPodio
SalsaPodio's Avatar
Bikes: 2012 Parlee Z5
A lot
SalsaPodio is offline
Old 12-06-11, 10:36 AM
rotti
Originally Posted by SalsaPodio
A lot
So it's really not that bike of a deal??? I'm not asking to call out people, hopefully thats not the way it's taken. I'm just wondering if it's a practicle goal without a tt bike
rotti is offline
Old 12-06-11, 10:48 AM
echappist
fuggitivo solitario
Quoted: 243 Post(s)
ok, i'll bite. On a really flat course (net elevation gain/distance ~0.2%) with no aero equipment (maybe just a skin suit), a 70kg rider with reasonable CdA (0.32) requires 325W. That's 4.64 w/kg. If you are aero like Nate or RacerEx, you can get it down to 308W, but that's still 4.40w/kg. Of course, the slight downhills on the course might reduce the wattage required a bit, but not much.
https://www.analyticcycling.com/ForcesPower_Page.html. A really aero road rider can have a CdA of ~0.30
Many on this forum has 4.0w/kg for an hour as a goal. Those with 4.40w/kg are all Cat3 or well on their way to earning their cat3 by points. You get up to 4.64, you are into Cat2 territory.
Old 12-06-11, 11:03 AM
waterrockets
Making a kilometer blurry
waterrockets's Avatar
Bikes: rkwaki's porn collection
Quoted: 37 Post(s)
Liked 91 Times in 38 Posts
The bike doesn't make a huge amount of difference, but the position does. A TT bike will allow you to get into a position that generates significantly less drag. The bike and components will further impact this.
waterrockets is offline
Old 12-06-11, 11:08 AM
echappist
fuggitivo solitario
Quoted: 243 Post(s)
that makes the rider significantly more aero. You can probably go down from 0.32 to the high 0.2x with clip-on bars alone.
Old 12-06-11, 11:15 AM
waterrockets
Quoted: 37 Post(s)
Here's an old test done by some magazine. I believe this test was at a velodrome:
Originally Posted by ripped off
They put Uwe Peschel on a normal bike:
Needed Watts for Speed = 45 km/h :
Stevens San Remo bike with normal handlebar 465 Watts needed to go 45 km/h
Same bike Hands down the drops: 406 watts needed
Same bikeEaston Aeroforce bar: 369 Watts
Same bike Triathlon position (5.5 cm lower bar, saddle forwards): 360 Watts
Same bike Triathlon position (5.5 cm lower bar, saddle forwards) and
carbon Tri spoke wheels front and rear: 345 Watt
Cervelo + Tri spoke front 328 Watts
Cervelo + Tri spoke front + disk rear wheel : 320
Cervelo + Tri spoke front + disk rear wheel +Giro helmet: 317
Cervelo + Tri spoke front + disk rear wheel +Giro helmet + speed suit: 307
Cervelo + Tri spoke front + disk rear wheel +Giro helmet + speed suit +
saddle 3 cm further back: 293 Watts
From 465 to 293 watts... That's a lotta savings.
Old 12-06-11, 11:17 AM
rkwaki
rkwaki's Avatar
I realize that was not your intention and wasn't taken that way. My opinion (which means very little) don't sweat the small stuff, just get out and ride/race, you will learn as you go. What works for you may be very different than what works for others.
Case in point, many disagree with my training methods, but it works for me. What you like for equipment may go against the grain but if it works for you that is all that matters.
Technology does not win you races, sure once you are at a certain level it will help but when you are starting out I believe it can be a distraction - put it this way - when you develop a big motor it doesn't matter what you ride.
rkwaki is offline
Old 12-06-11, 11:19 AM
rkwaki
rkwaki's Avatar
Moral of this? For $100 and a little tinkering you can save yourself 100 watts.
rkwaki is offline
Old 12-06-11, 11:38 AM
SalsaPodio
SalsaPodio's Avatar
https://connect.garmin.com/activity/108352902
That's from a 40k TT I did with a road bike. IAB, a skinsuit, and an aero helmet I borrowed. Take away the aero helmet and skinsuit and I bet it would still be under an hour.
I'm definitely not good at TTs either. My FTP was around 4.6 W/kg at the time.
Old 12-06-11, 11:46 AM
Nate552
Nate552's Avatar
Bikes: Orbea Orca Trek 5500 Trek Equinox
For me, going from a Specialized Transition to a Litespeed C1 with clip on's would cost me about 30 watts, or to do a sub hour 40K, I'd go from having to put out 3.47 w/kg to 3.98 w/kg.
Nate552 is offline
Old 12-06-11, 11:51 AM
echappist
fuggitivo solitario
Quoted: 243 Post(s)
what's the CdA on that? 0.27 ish?
Old 12-06-11, 12:01 PM
Nate552
Nate552's Avatar
I don't have the data that has the CdA, it's at home. I just have my notes that has raw drag numbers.
Nate552 is offline
Old 12-06-11, 12:50 PM
rkwaki
rkwaki's Avatar
Nate you don't happen to be from TN do you?
rkwaki is offline
Old 12-06-11, 01:34 PM
kensuf
My idea of fun
kensuf's Avatar
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times in 36 Posts
Oh jesus, you need to stop posting for a bit.
To the OP, in my first 40k I broke 56 minutes (55:48) on a road bike with clip-on's, a cheap disc cover, and 404 front wheel at 309w. I think I also had a skin-suit and helmet. I'm not a small guy. It can be done cheaply.
kensuf is offline
Old 12-06-11, 02:11 PM
ridethecliche
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times in 160 Posts
I think echap is having an affair with numbers...
ridethecliche is offline
Old 12-06-11, 02:15 PM
Nate552
Nate552's Avatar
Nope, TX.
Nate552 is offline
Old 12-06-11, 02:16 PM
echappist
fuggitivo solitario
Quoted: 243 Post(s)
shhh, don't tell my chemicals about it
rkwaki
rkwaki's Avatar
Originally Posted by Nate552
Nope, TX.
Cool...
You reminded me of someone in that pic.
rkwaki is offline
Old 12-06-11, 03:19 PM
kensuf
My idea of fun
kensuf's Avatar
Quoted: 41 Post(s)
Yup. I mean I can get nerdy and worked up about numbers, aerodynamics, etc, but he takes it to a whole new level.
kensuf is offline
Old 12-06-11, 05:30 PM
rotti
Did you just clip on the bars and go or did you have to adjust the saddle height and position?
rotti is offline
