Seat doesn't stay in position
Old 02-04-19, 04:58 PM
fullergarrett
"Broke College Student"
fullergarrett's Avatar
Bikes: 2016 Giant Sedona, 1987 Free Spirit Pinnacle
Quoted: 87 Post(s)
Liked 6 Times in 6 Posts
Recently I've been having a problem with my seat not staying in position. I've been changing my seat height to nearly the highest position (the lowest position is uncomfortable) but after a minute or two of riding the seat slides right back down to the lowest position. Any ideas on how to make it stay?
My bike has a quick-release mechanism on the seat post that clamps it in tight or loosens up to change the positioning.
Any advice would be greatly appreciated.
fullergarrett is offline
Old 02-04-19, 05:20 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6945 Post(s)
Liked 255 Times in 210 Posts
Sight unseen? Its 20 questions again ,,
#1 Replace the QR with a bolt on one steel bolt steel nut..
On my folding bike I have a need to have the QR, so I added a 2nd one directly gripping the post, itself , so now I have 2.
I am 210# .... OP rider weight is a factor ?
fietsbob is offline
Old 02-04-19, 06:21 PM
fullergarrett
Quoted: 87 Post(s)
I'm ~320 pounds, so maybe that's the culprit. Should the QR be replaced with a traditional bolt-style?
Old 02-04-19, 06:27 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
tighten it more you may have a hard time opening the QR lever ..
Not uncommon to get out the adjustable wrench to get them open, after that... for extra leverage ..
a + will be someone else will have a real challenge trying to steal your seatpost and saddle..
Should? , It Can .. be replaced , But .. you have to measure the frame, tube outside diameter to know which one fits..
Perhaps the Dealer you bought the bike from can help? If You don't need the post lowered.. mid ride ... a bolt type can be bade pretty tight..
fietsbob is offline
Old 02-04-19, 08:14 PM
02Giant
Home School Valedictorian
02Giant's Avatar
Bikes: 13 Orbea Orca 02 Giant Cypress 88 Mongoose ATB 79 frame-built to 80 spec. Schwinn Traveller
Quoted: 897 Post(s)
Liked 77 Times in 55 Posts
Is there an adjuster that you can give a quarter of a turn, to snug it up tighter?
I had one quite similar, it had an adjuster on the opposite end of the cam lock.
I ain't broke and I ain't hungry but I'm close enough to care
tp
02Giant is online now
Old 02-04-19, 08:24 PM
Sci-Fi
Sci-Fi's Avatar
Quoted: 16 Post(s)
One of my bikes did that. I put a screw type hose clamp on there and it held the seat post height adjustment going on 10+ years.
Sci-Fi is offline
Old 02-04-19, 08:47 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1252 Post(s)
Liked 82 Times in 70 Posts
Yes, it should. I have a couple of these in my parts box and they look like a super short hub quick release skewer with a tension adjusting nut opposite the "flag" end. You can tighten the nut to make the flag harder to close and increase the clamping pressure.
HillRider is offline
Old 02-04-19, 08:50 PM
fullergarrett
Quoted: 87 Post(s)
I think I found an adjustment knob (pic below) that I believe is for the quick release (hiding on the other side), although it seemed fairly tight and wouldn't budge in either direction by hand. Should I take a wrench and tighten it slightly more?
The owner's manual for this bike says:
The action of the cam squeezes the seat collar around the seat post to hold the seat post securely in place. The amount of clamping force is controlled by the tension adjusting nut. Turning the tension adjusting nut clockwise while keeping the cam lever from rotating increases clamping force; turning it counterclockwise while keeping the cam lever from rotating reduces clamping force. Less than half a turn of the tension adjusting nut can make the difference between safe and unsafe clamping force.
If all else fails, I'll take fietsbob's advice and contact the dealer I purchased the bike from. It's a relatively new bike... I purchased it this fall and it has only been on a few rides.
Old 02-04-19, 08:57 PM
02Giant
02Giant's Avatar
Quoted: 897 Post(s)
That new of a purchase, definitely take it back for assistance if it doesn't want to cooperate.
tp
Old 02-04-19, 08:59 PM
HillRider
To adjust the tension you first open the cam lever by pulling it away from the clamp. That releases all tension on the seat colllar. Then turn the adjusting nut a fraction of a turn tighter and try to close the lever. It should take a fair bit of hand pressure to close. Repeat this procedure until the lever is hard enough to close. The general rule is that the lever should leave an imprint on your palm when it closes firmly enough. Please note the lever is NOT a wing nut, it is tensioned by the adjusting nut and clamps by pivoting it closed, not by rotating it.
Old 02-04-19, 09:03 PM
fullergarrett
Quoted: 87 Post(s)
That was extremely helpful. I finally was able to tighten the tension nut much tighter than it was after opening the clamp. Thanks.
Next time I ride I'll see if it maintains its position. If not, I'll try tightening it slightly more.
Old 02-04-19, 09:15 PM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 382 Post(s)
I have used an industrial 2 piece shaft collar on the seat post to prevent if falling into the frame, and the seat post clamp just has to prevent the saddle from coming out of the frame.
Like this one: https://www.amazon.com/Climax-2C-100.../dp/B001VXU0UK
nfmisso is offline
Old 02-05-19, 07:31 AM
Kapusta
Cyclochondriac
Quoted: 1117 Post(s)
Liked 189 Times in 134 Posts
It sounds to me like you’ve found the solution.
Kapusta is offline
Old 02-05-19, 08:50 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 588 Post(s)
Liked 52 Times in 40 Posts
For aluminum frames and posts, I have found knurling to be an effective cure. In the absence of a knurling tool, you could mark the post at the desired height, remove it from the frame and make several divots around the circumference with a center punch in the area where the clamp presses on it.
Dan Burkhart is offline
Old 02-05-19, 10:00 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1232 Post(s)
Liked 81 Times in 59 Posts
Is there any space at all between the knob and the body of that QR lever? Looks pretty close from the photo. If the knob is touching (and since you can't make it turn it might be) I'd remove it and stick a washer under it so that you can tighten it just a little bit more. I doubt it will require very much.
Retro Grouch is offline
Old 02-05-19, 11:53 AM
Kapusta
Cyclochondriac
Hey, Folks.....
The OP simply did not know how to adjust the QR collar. Now he does.
He does not need an industrial two-piece shaft collar.
He does not need to take a center punch to his seat post to create divots.
He does not need whatever products are pictured in fietsbob's haiku.
Kapusta is offline
Old 02-05-19, 12:47 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 798 Post(s)
Liked 123 Times in 104 Posts
Like an axle quick release, you should adjust the tension such that the lever makes a mark on your palm when you push it home. And lubricating the cam mechanism will give better clamping with less lever force.
dsbrantjr is offline
Old 02-05-19, 04:10 PM
fullergarrett
Quoted: 87 Post(s)
Yep. Found it - shouldn't budge, and if it does, I know how to tighten the tension.
Hey, Folks.....
Thanks everyone for your help. I've found and fixed the problem.
Old 02-05-19, 06:45 PM
Retro Grouch
Hey, Folks.....
Well, you're right of course but I think you ought to cut the people who are trying to help a little bit of slack. OP asked his question clear up at post #1 . Potential helpers read his question and attempt to craft an answer it without necessarily reading all of the intermediate posts. That's all it is.
Old 02-05-19, 07:42 PM
Kapusta
Cyclochondriac
Fair enough. Your right. I was unnecessarily snarky.
Kapusta is offline
Old 02-06-19, 04:53 PM
Duo
Bikes: classic & vintage road bikes, some newer stuff, tandems, and a few mtb's
Quoted: 79 Post(s)
actually the suggestions were Great for my personal situation.
i have a tandem that has seat post slipping issues; really like the collar and knurling ideas. those collars also can solve many problems in addition to bicycles.
when it comes to problems, many times it is better to have a bunch of solutions, rather than just one that may not work at all.
Duo is offline
Old 02-06-19, 05:30 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
As you say in another post you have a lot of short trips on a school campus.. know they are high bike theft places ??, and so for that reason ,
in addition to not slipping think about your seat and post bring stolen... perhaps a Really tight QR lever that cannot be opened with someones hands will be adequate
But Perhaps Not..
have to bring & carry pretty robust locks too
fietsbob is offline
nickjahn
Bicycle Mechanics
5
10-14-18 10:18 PM
techman
Bicycle Mechanics
8
04-22-14 02:59 PM
Globalconflict
General Cycling Discussion
6
07-16-11 11:17 PM
MDI
Bicycle Mechanics
8
05-31-11 12:52 PM
JusticeZero
Bicycle Mechanics
9
07-25-10 10:04 AM
