Alternative to rags for cleaning, lubing chain
Old 08-25-19, 07:04 PM
vuduthmb
Quoted: 7 Post(s)
I like to pull the Townie and my Giant Cypress out once in a while and wipe the chains and apply a chain lubricant. I usually use household rags for this job, and then I throw them away because they're so dirty. Is there an alternative to rags for this job? Paper towels or baby wipes or something.
Any input is appreciated. Thank you.
vuduthmb is offline
Old 08-25-19, 07:50 PM
Bmach
Quoted: 280 Post(s)
Liked 26 Times in 21 Posts
How about just wash them? That’s what I do.
Bmach is offline
Old 08-25-19, 08:02 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 777 Post(s)
Liked 80 Times in 61 Posts
Cats. They clean themselves.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 08-25-19, 08:14 PM
andrewclaus
Bikes: 2016 Fuji Tread
Quoted: 254 Post(s)
Liked 37 Times in 32 Posts
If the chain is off the bike I'll hit it with a wire brush. Otherwise I throw away the rags (with all due care to oily rags--avoid spontaneous combustion).
I get many of my rags on the roadside, especially in boating areas on summer weekends. So I don't feel so bad about eventually throwing them away, since they were once litter I picked up.
Since I share a washing machine with people I love, I don't put greasy rags in the laundry (any more).
andrewclaus is online now
Old 08-25-19, 08:25 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 120 Post(s)
Liked 33 Times in 24 Posts
I have a Rubbermaid just for worn out fabrix that I keep handy for dirty jobs. It might contain old bed sheets, towels, cotton shirts and Tees, anything that will absorb goes into it instead of the garbage. But yeah, I like to wash it first and then just use the rag for drying before waxing. Hey Bill, do cats really make a good chain? Do you use the whole cat or just the catgut? A self cleaning chain would be really cool.
Bigbus is offline
Old 08-25-19, 09:00 PM
delbiker1
delbiker1's Avatar
Bikes: 2003 Lemond Poprad, 1991 Ochsner steel frame, 2002 Airborne Zeppelin titanium, Schwinn DBX SS aluminum, Orbea MD 40 carbon fiber
Quoted: 294 Post(s)
Liked 114 Times in 80 Posts
I cannot remember where I saw it, but there is a sponge that is made and shaped just for cleaning chains. It has a ridge running down the center of the sponge that is supposed to assist in cleaning the inside of the links. It is also supposed to be easy to clean and last for a number of cleanings. I was kind of skeptical but there were a couple of good reviews. Anybody out there that knows of and where to get it?
delbiker1 is offline
Old 08-25-19, 09:06 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Quoted: 368 Post(s)
Liked 108 Times in 87 Posts
Unca_Sam is online now
Old 08-25-19, 09:11 PM
Unca_Sam
The dropped
Unca_Sam's Avatar
Quoted: 368 Post(s)
Simple Green is a miracle surfactant
Full strength simple green cleaner will remove roofing sealant. You should be able to dump some on the rag you use and hand wash the worst of off it, then wash with other rags.
Don't put the simple green in your washer in any significant amount though, unless you like bubbles.
Old 08-25-19, 10:33 PM
MrK.
MrK.'s Avatar
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 1973 World Voyageur, 2006 Soma Groove, 2000 Trek 820, 1995 Fuji Discovery drop bar conversion, 1991 Haro Impulse Comp, 1985 Shogun Prairie Breaker I, 1987 KHS Montana Pro, 1941 Schwinn DX "Klunker"
Quoted: 48 Post(s)
Liked 13 Times in 7 Posts
I have an old plastic popcorn jar with a wide mouth that I keep about 1/2 full of mineral spirits. I drop the chain in and let it soak, give it a few shakes, soak, shake ... over a day or so. Pull the chain out and let it drip dry over paper towels then reinstall and lube.
MrK. is offline
Old 08-26-19, 03:33 AM
berner
Quoted: 373 Post(s)
Liked 92 Times in 72 Posts
Here in the US, Ace Hardware stores have rolls of heavy duty paper towel that are perfect for wiping off chains. I suspect Auto Zone or other auto supply stores have them also.
berner is offline
Likes For berner:
Old 08-26-19, 03:49 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 73 Post(s)
Liked 13 Times in 13 Posts
A well as many others, Home Depot, Harbor Freight
https://www.homedepot.com/p/Scott-Sh...5143/202519693
https://www.harborfreight.com/dispos..._q=shop+towels
https://www.pepboys.com/sellars-tool...510?quantity=1
JoeTBM (The Bike Man)
I'm a black & white type of guy, the only gray in my life is the hair on my head.
JoeTBM is offline
Likes For JoeTBM:
Old 08-26-19, 06:13 AM
mrt2you
Bikes: trek 720 multitrack hybred, 92 trek 2300, 2010 specialized roubaix, 2014 specialized roubaix
Quoted: 14 Post(s)
Liked 13 Times in 11 Posts
maybe try some mechanic hand cleaning wipes, they will have something to cut grease and grime in the wipe. after you are done throw away.
possibly something like this....https://www.menards.com/main/health-...2823301788.htm
mrt2you is offline
Old 08-26-19, 09:42 AM
vuduthmb
Quoted: 7 Post(s)
yeah, this is the answer I was looking for. Perfect. Thank you.
vuduthmb is offline
Old 08-26-19, 10:27 AM
CarloM
Bikes: 2019 TCR Advanced SL1 Disc; 2018 Cervelo S3 SRAM eTap HRD; 2020 Giant Revolt Advanced
Quoted: 194 Post(s)
Liked 105 Times in 86 Posts
Curious about the Gojo. I may try that next.
Currently I wipe down my chain after every ride using the Scott shop towels and degreaser. I spray the degreaser mix (simple green) lightly directly onto the towel and just wipe the outside of the chain. I make sure I don't put enough degreaser to soak into the chain pivots/rivets so that it doesn't dissolve the chain lube inside the pivots. Just a light enough spray to cut through the grime on the outside of the chain. Then I do a second pass with just the shop towel, to remove any trace of the degreaser from the outside of the chain, and discard the towel.
About every 100 miles or so I reapply the Finish Line wet lube. The chain/transmission noise will tell me when I need to. It's very quiet right after cleaning and application, but then after maybe 5 or so rides of between 10-25 miles, if after doing the quick wipe down it is still markedly noisier, then I'll do a reapplication of the lube.
After maybe 500 miles I'll do a deep clean of the chain using the Park Tool chain cleaner tool and full strength chain degreaser, followed by a pass with soapy water, then multiple passes with regular water and allow to air dry before applying the lube again, one drop on each pivot. Since I ride just about every day, this ends up being maybe once every 4-5 weeks. More frequently if I've done riding in very dusty/sandy areas like trails or beach-side paths.
CarloM is offline
Old 08-26-19, 01:47 PM
DaveSSS
Bikes: Look KG461 w/Chorus 12, Colnago C-RS w/Chorus 12
Quoted: 164 Post(s)
Liked 25 Times in 21 Posts
Scott shop towels work great. I buy a bundle of 12 rolls at Sam's club. I use mineral spirits or camp stove fuel for degreaser, never anything water based. Crown brand camp stove fuel at Wal-Mart is a lot cheaper than mineral spirits and evaporates faster.
With my home brew wax based lube, I can easily go 120 miles with no wiping. Then I wipe the chain with a shop towel that has a little camp stove fuel on it and reapply the dry lube. This gives me the cleanest drivetrain I've ever had.
DaveSSS is online now
Old 08-26-19, 02:07 PM
alcjphil
alcjphil's Avatar
Quoted: 622 Post(s)
Liked 60 Times in 43 Posts
I don't buy any disposable product for cleaning my bike chain. I have found that old terrycloth towels are the best thing to clean chains. They are absorbent and the nap of the towel gets well in between chain links. One facecloth sized piece of towel can be used many times after having been used many times before for many other things. I used to use old towels to dry my car after having washed it, this after years of use drying me off after a shower. They were also great for washing windows, could be used many times for that. Once they became more frayed, I would cut them up to clean my bike chains, they wore much better than a plain rag. Once they are saturated with dirt and oil from chain cleaning, it is time to dispose of them. I would never buy a one time use product for wiping my bike chain
alcjphil is online now
Old 08-26-19, 03:15 PM
hhk25
Bikes: 2017 Marinoni Tourismo Extreme, 1984 Trek 520, 1987 Niskhiki International, 2013 Brompton M6R, 2016 Brompton P6R
Quoted: 108 Post(s)
Liked 4 Times in 4 Posts
Nobody here uses a chain cleaner? I've been using one for 20 years. I use Simple Green or Citrus based cleaner and then dispose of the waste using household hazardous waste pickup.
Edit: I noticed CarloM uses one.
hhk25 is offline
Likes For hhk25:
Old 08-26-19, 03:40 PM
DaveSSS
Quoted: 164 Post(s)
An on the bike cleaner takes at least two times to really clean a chain. If water based products are used, they leave residue on the chain. They also have to leave cleaning fluid residue on the sprockets, chain rings, and hub . Cleaning the chain is best done with it off the bike.
Old 08-26-19, 06:03 PM
Gresp15C
Gresp15C's Avatar
Quoted: 701 Post(s)
Liked 109 Times in 80 Posts
I use worn-out socks. They're pretty small, and I don't miss them when I've saturated one with grease and throw it in the trash.
Gresp15C is offline
Old 08-26-19, 06:56 PM
CarloM
Quoted: 194 Post(s)
Major missed opportunity for me. About a month before I got into cycling I discarded a bunch of old white cotton undershirts and socks that had gotten hole-y with age. I would have had chain rags for months if I hadn't discarded those...
CarloM is offline
Old 08-26-19, 10:12 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 474 Post(s)
Liked 55 Times in 41 Posts
They can be trained to check spoke tension, too:
(From the https://www.bikeforums.net/classic-v...ur-cat-72.html thread.)
Jeff Wills
Jeff Wills is offline
Likes For Jeff Wills:
Old 08-26-19, 10:50 PM
vuduthmb
Quoted: 7 Post(s)
Fenwick's Bicycle Chain Cleaner
vuduthmb is offline
Old 08-27-19, 05:47 AM
zacster
Quoted: 22 Post(s)
Liked 62 Times in 52 Posts
I use the Park cleaner myself, but since I went to a wax lube the chain doesn't get nearly as dirty. You need to apply it more often but it really makes for a quiet and clean ride. You can run your hand over my chain and not have a semi-permanent tattoo on it, just a little smudge. Squirt brand is what I'm using, specially designed to do exactly this. I apply every 100-150 miles on two different bikes.
zacster is offline
Old 08-27-19, 08:28 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 474 Post(s)
Liked 122 Times in 92 Posts
I keep one very dirty rag just for wiping my dirty chain, when there are no more clean surfaces on it I throw it away. I also have clean rags handy for jobs that require it - cleaning bearing surfaces before relubing, for instance, and most of these will eventually graduate to being chain wiping rags.
Wilfred Laurier is offline
Old 08-27-19, 10:08 AM
woodcraft
woodcraft's Avatar
Quoted: 1116 Post(s)
Liked 90 Times in 55 Posts
I use plain paper towels for initial chain-wiping, then rags.
One tee shirt cuts up into ~25 rags and since
they are used for progressively greasier tasks, that is a two year supply.
woodcraft is offline
