Trek Sensor computer wheel size
Old 10-20-19, 10:33 PM
rseeker
rseeker's Avatar
Quoted: 256 Post(s)
Liked 79 Times in 56 Posts
I have this old Trek Sensor computer. Any idea how big it thinks my wheels are, used to calculate distance? (I don't see a way to tell it.)
rseeker is offline
Old 10-21-19, 02:59 AM
Pompiere
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T
Quoted: 233 Post(s)
Liked 23 Times in 20 Posts
Usually, when you remove the battery, the computer resets and will walk through the setup when it powers up. Most of them use the wheel circumference to compensate for different tire sizes. The simple way to measure circumference is to put a mark on the floor and the tire, roll forward until the mark on the tire reaches the floor again, and measure.
Pompiere is offline
Likes For Pompiere:
Old 10-21-19, 03:46 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube, M Alloy Pro, Sprint 76; Amp Research B4; Colnago Crystal; Klein Pulse; Litespeed Catalyst, Fondriest Squadra Corse
Quoted: 354 Post(s)
Liked 78 Times in 56 Posts
^ this.
Just to add, it's normally measured and entered in millimeters, something like 2115 (=2.115 meters) etc.
ridelikeaturtle is offline
Old 10-21-19, 04:01 AM
Prowler
Quoted: 169 Post(s)
Liked 40 Times in 25 Posts
I shudder to suggest folks read the instructions but, when I had one of these a few years ago, I found the manual someplace on line and printed it (PRINTED it!!!!!! How 1940s). As I have 8 or 9 different cycle computers I have to print out one for each. They're all a bit different.
Prowler is offline
Old 10-21-19, 04:50 AM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 757 Post(s)
Liked 117 Times in 77 Posts
Being something of a detail nerd I usually enlist my wife to aid in this procedure. Set the Mark, make sure the tire is inflated to you normal pressure, I sit on the bike and roll forward and then measure again when the Mark comes around. Weight and deflection introduce a minor difference that increases over long rides.
Told you I was a detail nerd.
"Skepticism is the first step in critical thinking." -- Me
bobwysiwyg is offline
Old 10-21-19, 07:33 AM
Chuckk
Groupetto Dragon-Ass
Chuckk's Avatar
Bikes: http://mcaf.ee/hsm2z
Quoted: 197 Post(s)
Liked 38 Times in 31 Posts
Google is always your friend - Looks like a rebranded Avocet to me, and you can't beat that.
Chuckk is offline
Likes For Chuckk:
Old 10-21-19, 01:26 PM
rseeker
rseeker's Avatar
Quoted: 256 Post(s)
Thanks everybody, and especially for the scanned manual @Chuckk .
I did try a web search but came up empty. I was using DuckDuckGo though, so for due diligience I tried Google and again came up with a lot of results that didn't match. It turns out Trek has had many computers called Sensor but they're not all the same. I found one result on Scribd that looks like a match, but first they wanted my email, and I said OK, then they wanted me to sign up for a "free trial" recurring monthly $9.99 membership, which I'd then have to go to war with them to cancel. So, not doing that.
I tried the remove the battery thing but mine just comes back up to operational mode with all values reset to defaults and no opportunity to enter a wheel size. (There is something that may be a reset switch on the back above and to the right of the battery. I didn't try it because it was labeled ambiguously "AC", but from reading I guess that means "Auto Clear".)
But on a guess I selected the ODOmeter view, then pressed and held the left button, then it showed the wheel distance (2124 as apparent default) and let me enter a new value (2180 in my case). Left button to go from one digit to the next, selected digit shows as blinking, right button to increment the selected digit. Left button on the last digit ends edit mode, and a final left button takes you back to ODO and normal operation.
rseeker is offline
Likes For rseeker:
Old 10-21-19, 01:49 PM
Pompiere
Quoted: 233 Post(s)
That's why I switched to a Garmin, too many different computers with different operating procedures. I can switch the Garmin between bikes without re-calibrating.
Pompiere is offline
Old 10-21-19, 02:05 PM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 747 Post(s)
Liked 44 Times in 36 Posts
Sheldon Brown has entire charts of info on the subject. I would be surprised if you don't find what you need there... even with the lack of recent updates.
USAZorro is offline
