Replacing cassette, RD adjustment necessary?
Bikes: 2011 Spec Roubaix Elite Apex, 2010 Jamis Coda Sport, 04 Trek 6000, 79 Peugeot UO10
Maybe an obvious question, but I searched and wasn't able to find an answer...
I've got an '11 Roubaix with a SRAM PG1050 (Apex) 11-32 cassette. I just ordered a 12-27 PG1070 (Rival/Force) cassette and the tools to change it with. Should I expect to have to adjust the RD or should things just line up the same?
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times
If you have the tools, and, seemingly, the ability, why not just wait and see?
to answer your question though, no, you shouldn't expect to adjust.
Quoted: 2026 Post(s)
Liked 1,095 Times
Not necessarily. I've run into several cases where installing the exact same configured cassette by the same manufacturer required minor adjusting of the limit screws and/or minor adjusting of the shift cable tension. There are manufacturing tolerances and it doesn't take much variability to make the shifting deteriorate. As IthaDan noted, wait and see but don't be surprised if you have to do a bit of tweaking.
Quoted: 1438 Post(s)
Liked 1,092 Times
You might need to make a few touch-up adjustments due to manufacturing tolerances. You might also tweak the B-screw adjustment to bring the derailleur somewhat closer to the cassette which will aid shifting. Finally, if your chain was properly sized with the 32 tooth cassette it will now be somewhat long with the smaller 27 tooth cassette.
Thanks all. Pretty much what I expected to hear. Mostly was wondering if it would be easy to swap back and forth between both cassettes as needed. Sounds like a little tweak might be necessary which is no biggie.
Though it's usually the subtle adjustments that give me the most trouble
Liked 1,095 Times
Brad
Follow-up question based on the mention of chain length... would it be any advantage to use a different chain with each cassette? That would at least keep the wear consistent on each chain/cassette pair, but the crank gears would still be wearing relative to overall mileage.
Sorry, I'm an engineer, so I tend to overthink things :-)
Geck, wo ist mein Fahrrad
if your RD is apex, if it's the long cage it might/should be able to handle the extra links.
would chain suck become an issue?
if you do go to two chains I'd suggest the wipperman connex link, or chains. very easy to remove.
